UNI-PAC™
Power Inductors
(Surface Mount)
Description
• Miniature surface mount design
• Inductance range from 0.470uH to 1000uH
• Current range from 19.2 to .47 Amps
• Maximum power density
• Ideal for applications requiring low inductance and high
current in a miniature package
• Modified standard products are available
• Protective case eliminates core breakage
• Meets UL 94V-0 flammability standard
Applications
• DC-DC converters on board level and industrial
products
Environmental Data
• Storage temperature range: -40C to +125C
• Operating ambient temperature range: -40C to +85C
(range is application specific)
• Infrared reflow temperature: +240C for 30 seconds
maximum
Part
Number
UP1B-R47
UP1B-1R0
UP1B-1R5
UP1B-2R2
UP1B-3R3
UP1B-4R7
UP1B-6R8
UP1B-100
UP1B-150
UP1B-220
UP1B-330
UP1B-470
UP1B-680
UP1B-101
UP1B-151
UP1B-221
UP1B-331
UP2B-R47
UP2B-1R0
UP2B-1R5
UP2B-2R2
UP2B-3R3
UP2B-4R7
UP2B-6R8
UP2B-100
UP2B-150
UP2B-220
UP2B-330
UP2B-470
UP2B-680
UP2B-820
UP2B-101
UP2B-151
UP2B-221
UP2B-331
UP2B-471
Inductance
µH (rated)
0.47
1.0
1.5
2.2
3.3
4.7
6.8
10.0
15.0
22.0
33.0
47.0
68.0
100.0
150.0
220.0
330.0
0.47
1.0
1.5
2.2
3.3
4.7
6.8
10.0
15.0
22.0
33.0
47.0
68.0
82.0
100.0
150.0
220.0
330.0
470.0
OCL(1)
µH±20%
0.569
1.20
1.61
2.62
3.79
5.15
6.87
11.00
16.00
23.50
36.00
48.50
73.52
112.67
152.40
223.10
331.90
0.595
1.00
1.46
2.56
3.23
4.77
6.63
9.73
15.43
22.50
33.13
48.65
68.17
84.1
102.60
150
223
338
471
Notes: (1) Open Circuit Inductance Test Parameters: 100KHz, .250Vrms, 0.0Adc.
(2) RMS current for an approximate ∆T of 40°C. at an ambient temperature
of 85˚C.
NO
PROW AVAIL
TECT ABL
I VE E WI
CAS TH A
E
Packaging
• Supplied in tape and reel packaging, 900 (UP1B), 550
(UP2B), 450 (UP3B), and 275 (UP4B) per reel
I RMS(2)
Amperes
6.0
4.4
4.2
3.1
2.9
2.2
1.7
1.5
1.2
1.0
0.82
0.72
0.58
0.47
0.40
0.36
0.28
10.6
9.3
8.3
7.2
6.5
5.5
5.0
4.3
3.5
2.8
2.1
1.7
1.5
1.34
1.2
1.0
0.773
0.676
0.553
I SAT(3)
Amperes
7.7
5.3
4.5
3.5
3.0
2.6
2.2
1.9
1.5
1.2
0.99
0.87
0.67
0.53
0.46
0.38
0.31
11.4
9.9
7.9
6.1
5.1
4.2
3.6
3.3
2.4
2.0
1.7
1.4
1.2
1.03
0.95
0.77
0.637
0.510
0.427
(3) Peak current for approximately 10% rolloff.
(4) DCR limits 20°C.
DCR(4)
Ohms max.
0.0097
0.0177
0.0200
0.0363
0.0428
0.0544
0.0897
0.1107
0.1747
0.2541
0.3670
0.4740
0.7320
1.11
1.61
1.96
3.10
0.0049
0.0065
0.0081
0.0107
0.0128
0.0165
0.0202
0.0267
0.0410
0.0617
0.0917
0.1388
0.1787
0.2235
0.2707
0.4100
0.6717
0.8783
1.31
UNI-PAC™
Power Inductors
(Surface Mount)
Part
Number
UP2B-681
UP2B-821
UP2B-102
UP3B-R47
UP3B-1R0
UP3B-1R5
UP3B-2R2
UP3B-3R3
UP3B-4R7
UP3B-6R8
UP3B-100
UP3B-150
UP3B-220
UP3B-330
UP3B-470
UP3B-680
UP3B-101
UP3B-331
UP4B-R47
UP4B-1R0
UP4B-1R5
UP4B-2R2
UP4B-3R3
UP4B-4R7
UP4B-6R8
UP4B-100
UP4B-150
UP4B-220
UP4B-330
UP4B-470
UP4B-680
UP4B-101
UP4B-151
UP4B-221
UP4B-331
UP4B-471
Inductance
µH (rated)
680.0
820.0
1000.0
0.47
1.0
1.5
2.2
3.3
4.7
6.8
10.0
15.0
22.0
33.0
47.0
68.0
100.0
330.0
0.47
1.0
1.5
2.2
3.3
4.7
6.8
10.0
15.0
22.0
33.0
47.0
68.0
100.0
150.0
220.0
330.0
470.0
OCL(1)
µH±20%
700
823
1005
0.452
1.34
2.08
3.01
3.96
5.00
7.70
11.00
16.38
23.93
33.85
51.00
69.50
101.40
332.80
0.473
0.916
1.52
2.27
3.14
5.34
6.66
9.77
15.61
22.61
34.30
48.10
69.14
99.42
146.90
221.40
330.00
470.10
of 85˚C.
I RMS(2)
Amperes
0.452
0.423
0.369
16.0
12.5
10.0
9.2
8.0
6.5
5.8
4.3
3.9
3.1
2.4
1.9
1.6
1.4
0.75
19.2
17.3
13.4
12.0
11.0
8.6
8.3
6.8
5.5
4.5
3.7
3.1
2.4
2.0
1.7
1.4
1.1
0.91
I SAT(3)
Amperes
0.355
0.334
0.300
25.1
15.3
12.0
10.2
9.3
7.7
6.2
5.2
4.3
3.7
3.0
2.4
2.0
1.8
0.98
51.7
37.3
28.9
23.7
20.2
15.6
14.1
11.5
9.1
7.6
6.1
5.2
4.3
3.6
3.0
2.4
2.0
1.7
DCR(4)
Ohms max.
1.97
2.24
2.96
0.0021
0.0034
0.0053
0.0074
0.0083
0.0114
0.0183
0.0260
0.0317
0.0490
0.0688
0.1082
0.1558
0.2053
0.7330
0.0019
0.0023
0.0039
0.0048
0.0057
0.0093
0.0100
0.0150
0.0230
0.0340
0.0520
0.0740
0.1200
0.1700
0.2392
0.3571
0.5800
0.8330
(3) Peak current for approximately 30% rolloff @ 20°C.
UNI-PAC™
Power Inductors
(Surface Mount)
Mechanical Diagrams
UP1B Series
PCB PAD LAYOUT
TOP VIEW
8.89
8.89
Max
5.08
FRONT VIEW
2.42
Ref
UP1B
XXX
wwllyy R
6.10
Max
4.04
Max
SCHEMATIC
1
5.0
Max
4.1
2
0.762
Min
1.9
COMPONENT VIEW
UP2B Series
PCB PAD LAYOUT
TOP VIEW
14.0
SCHEMATIC
13.97
Max
1
6.73
Max
UP2B
XXX
wwllyy R
10.41
Max
9.4
FRONT VIEW
4.22
Ref
6.0
Max
7.3
2
0.762
Min
2.3
COMPONENT VIEW
UP3B Series
TOP VIEW
PCB PAD LAYOUT
8.13
max
1
UP3B
XXX
wwllyy R
19.3
SCHEMATIC
SIDE VIEW
1
13.21
max
2
11.7
6.8
max
8.7
12.70
2
3.8
19.30
max
COMPONENT VIEW
UP4B Series
TOP VIEW
PCB PAD LAYOUT
11.18
max
1
UP4B
XXX
wwllyy R
22.1
SCHEMATIC
SIDE VIEW
2
15.00
max
13.5
1
7.87
max
12.0
2
14.61
4.3
22.10
max
Dimensions in Millimeters.
COMPONENT VIEW
wwllyy = (date code) R = revision level
xxx = Inductance value per family chart
UNI-PAC™
Power Inductors
(Surface Mount)
Packaging Information
UP1B Series
2.0
4.0
1.5 Dia.
A
1.75
1
7.5
16
9.3
ACTUAL SIZE
UNI-PAC 1B
2
4.4
5.6
A
2.3
6.4
12.0
SECTION A-A
Parts packaged on 13" Diameter reel,
900 parts per reel.
Direction of feed
Dimensions in millimeters.
UP2B Series
2.0
4.0
A
1.5 Dia.
1.75
1
11.5
24
14.3
ACTUAL SIZE
UNI-PAC 2B
2
5.4
6.8
A
5.1
10.7
16.0
SECTION A-A
UP3B Series
Direction of feed
550 parts per reel.
2.0
4.0
1.5 Dia.
A
1.75
1
14.2
19.6
28.4 32
ACTUAL SIZE
UNI-PAC 3B
2
5.9
7.7
SECTION A-A
A
5.8
13.5
16.0
Direction of feed
450 parts per reel.
UP4B Series
2.0
4.0
1.5 Dia.
A
1.75
1
14.2
22.3
2
7.2
9.0
SECTION A-A
11.1
15.3
A
28.4 32
ACTUAL SIZE
UNI-PAC 4B
24.0
Direction of feed
275 parts per reel.
UNI-PAC™
Power Inductors
(Surface Mount)
Mechanical Diagrams
UP1B-100
TypicalInductance
Inductance&&Energy
Energy vs
vs Saturation
SaturationCurrent
Current
Typical
100.0
10.0
1.0
0.1
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
5.5
m Henries or m Watt-Seconds
UP1B-1R0
100.0
Typical
Inductance & Energy
yp
gy vs Saturation Current
10.0
1.0
0.1
6.0
0.0
0.2
0.4
0.6
Amperes (Peak)
10.0
1.0
0.2
0.3
0.4
Inductance
0.5
0.6
0.7
0.8
0.9
1.0
0.1
0.0
1.0
2.0
3.0
4.0
5.0
6.0
Energy
10.0
1.0
1.5
2.0
2.5
3.0
Amperes (Peak)
Inductance
8.0
9.0
10.0
Energy
UP2B-470
Typical Inductance
Inductance&& Energy
Energy vs
vs Saturation
Current
Typical
Saturation Current
0.5
7.0
Amperes (Peak)
UP2B-100
0.0
2.0
Energy
Inductance
1.0
1.8
10.0
Amperes (Peak)
100.0
1.6
Typical
yp Inductance & Energy
100.0
100.0
0.1
1.4
UP2B-1R0
Typical Inductance & Energy vs Saturation Current
0.0
1.2
Inductance
UP1B-470
0.1
1.0
Amperes (Peak)
Energy
Inductance
0.8
Energy
3.5
4.0
4.5
100.0
Typical
10.0
1.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
Amperes (Peak)
Inductance
Energy
1.4
1.6
1.8
UNI-PAC™
Power Inductors
(Surface Mount)
Mechanical Diagrams
UP3B-1R0
UP3B-100
100.0
10.0
1.0
0.1
1000.0
Typical
Inductance && Energy
Energy vs
Current
Typical Inductance
vs Saturation
Saturation Current
1000.0
2
3
4
5
6
7
8
9
Typical
100.0
10.0
1.0
0.0
10 11 12 13 14 15 16
0.5
1.0
1.5
2.0
Amperes (Peak)
3.5
4.0
4.5
5.0
5.5
6.0
Energy
Inductance
UP3B-470
UP4B-1R0
1000.0
1000.0
3.0
Amperes (Peak)
Energy
Inductance
2.5
100.0
10.0
1.0
0.0
0.5
1.5
1.0
2.0
100.0
10.0
1.0
0.1
0 2
3.0
2.5
4
6
8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38
Amperes (Peak)
Amperes (Peak)
Energy
Inductance
UP4B-470
Typical
100.0
10.0
1.0
UP4B-100
1000.0
2
3
Energy
Inductance
4
5
6
7
8
Amperes (Peak)
Inductance
Energy
9
10
11
12
1000.0
100.0
10.0
1.0
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
Amperes (Peak)
Inductance
Energy
4.0
4.5
5.0
5.5
UNI-PAC™
Power Inductors
(Surface Mount)
UNI-PAC™
Power Inductors
(Surface Mount)
PM-4308 10/02
© Cooper Electronic
Technologies 2002
Visit us on the Web at www.cooperET.com
3601 Quantum Boulevard Boynton Beach, Florida 33426-8638
Tel: +1-561-752-5000 Toll Free: +1-888-414-2645 Fax: +1-561-742-1178
This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. Cooper
Electronic Technologies reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of
any products. Cooper Electronic Technologies also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
很抱歉,暂时无法提供与“UP1B-6R8-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.893711+1.84795
- 10+11.5647210+1.43490
- 25+10.4532525+1.29700
- 50+9.6849750+1.20167
- 100+8.97011100+1.11298
- 250+8.10368250+1.00547
- 国内价格 香港价格
- 900+7.26537900+0.90146
- 1800+6.721391800+0.83397
- 2700+6.421022700+0.79670
- 4500+6.112364500+0.75840
