17000205A
17000205A
    COMAIRROTRON
    CR1248UB-Y51-ALARM SENSOR
17000205A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR1248UB-Y51 17000205A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 48 VDC = 0.15 Amps = 7.20 Watts = 3200 RPM = Ball = 133.44 CFM = 0.32 Inch of H2O = 48.4 dB(A) = 213.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 280±10 mm Lead wires, AWG 24, UL 1007 Agency Approvals: UL, CUL, TUV, CE
17000205A 价格&库存
很抱歉,暂时无法提供与“17000205A”相匹配的价格&库存,您可以联系我们找货
