TCMB100STN
TCMB100STN
    ATG
    XCELITE/TOOL CASE WITH TOOLS
TCMB100STN 数据手册
ATTACHÊ TOOL CASES Model TCMB100ST and TCMB100MT • Contains 53 individual hand tools, 31 Series 99® interchangeable screwdriver/nutdriver blades and handles, and 2 specialized screwdriver/nutdriver kits (as listed) • Contains 3-panel hinged tool pallet in lid plus additional pallet in bottom • Super tough, black polyethylene with rich looking black anodized aluminum hardware • Size: 17 3/4" x 12 5/8" x 5 3/4"/451mm x 321mm x 146mm Cat No. UPC No. Description TCMB100ST 037103491990 Tool case with tools TCMB100MT 037103491206 Tool case only-NO TOOLS Cat No. UPC No. Cat No. UPC No. 1 57CG Needle nose pliers 5 1/2"/139mm 1 XST102 Phillips screwdriver 1 Handle – regular ratchet 1 59CG Handle – Tee ratchet 1 86CG Chain nose pliers 8"/203mm 1 P18 Hex socket screwdriver 1 Electronic snips 1 P19 Hex socket screwdriver 1 99X5 Extension 1 103S 99X10 Extension 1 K22 Wire stripper/cutter 1 HS6 Nutdriver—hollow shaft 1 Electrician's knife 1 HS8 Nutdriver—hollow shaft 1 9938 Reamer 1 99125 Slotted screw blade 1 M60 Mini drivers 1 HS10 Nutdriver—hollow shaft 1 XL75 Offset ratchet screwdrivers 1 HS11 Nutdriver—hollow shaft 1 99250 Slotted screw blade 99312 Slotted screw blade 1 600 Combination screwdriver-nutdriver tool 1 HS12 Nutdriver—hollow shaft 1 1 SB1 Dual reversible screwdriver blade 1 HS14 Nutdriver—hollow shaft 1 99811 99820 Slotted screw blade 1 R144 Slotted screwdriver 1 HS16 Nutdriver—hollow shaft 1 Phillips screw blade 1 R146 Slotted screwdriver 1 HS18 Nutdriver—hollow shaft 1 99821 Phillips screw blade 1 R181 Slotted screwdriver 1 8M Nutdriver—magnetic 1 99822 Phillips screw blade 1 R184 Slotted screwdriver 1 10M Nutdriver—magnetic 1 9961- 69 Bristol 6-flute multi. spline blades (9) 1 R3164 Slotted screwdriver 1 P3 Midget nutdriver 1 9920 - 26 Allen hex socket type blades (7) 1 R3166 Slotted screwdriver (insulated) 1 P4 Midget nutdriver 1 99764 Allen hex socket type blade 1 R3323 Slotted screwdriver 1 P5 Midget nutdriver 1 99964 Allen hex socket type blade 1 R5325 Slotted screwdriver 1 P6 Midget nutdriver 1 42H Straight nose seizer 1 S388 Slotted screwdriver 1 P7 Midget nutdriver 1 46CG Adjustable wrench 6"/152mm 1 S3161 Slotted screwdriver 1 P8 Midget nutdriver 1 50CG Midget slip joint pliers 5"/127mm 1 S5161 Slotted screwdriver 1 P9 Midget nutdriver 1 51CG Long nose pliers 6"/152mm 1 S5166 Slotted screwdriver 1 P10 Midget nutdriver 1 53CG Utility pliers 7"/178mm 1 SX101 Phillips screwdriver 1 P11 Midget nutdriver 1 54CG Diagonal pliers 4"/101mm 1 XST100 Phillips screwdriver 1 P12 Midget nutdriver 1 66CG Diagonal pliers 6"/152mm 1 XST101 Phillips screwdriver 1 TA2 Torque amplifier handle 1 Cat No. UPC No. 991 Handle – regular 991R 994R Qty. Qty. Qty.
TCMB100STN 价格&库存
很抱歉,暂时无法提供与“TCMB100STN”相匹配的价格&库存,您可以联系我们找货
