83160705
83160705
    CROUZET(高诺斯)
    检测开关 操作寿命1000万次 AC250V 6A
83160705 数据手册
Miniature Positive Break Switches Series 83 160 DIN 41635 A 1 Types General specifications Layout 83 160 7 POF TTF V A A V SPDT* 250 6 10 250 4 (14.1) 1.5 (3.5) 18 (63.5) 200 (70.5) 15.7 (.62) 14.8±0.3 (.58±0.012) 13.5 (.53) 1.3 (0.047) 0.5 (1.64) 5 -40+85 (-40+185) 107 1.2 (0.05) 7 (0.25) 4 (14.1) 1.5 (3.5) 18 (63.5) 200 (70.5) 15.7 (.62) 14.8±0.3 (.58±0.012) 13.5 (.53) 1.3 (0.047) 0.5 (1.64) 5 -40+85(-40+185) 107 1.2 (0.05) 7 (0.25) Mechanical characteristics Operating force - max. Release force - min. Min. positive opening force Permitted overtravel force - max. Maximum rest position Tripping point Maximum positive opening position Overtravel - min. Operating speed max. Operating rate max. Operating temperature Mechanical durability Contact gap Weight N (oz.) N (oz.) N(oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) m/s (ft/sec) (operation/s) °C (°F) Operations mm (in.) g (oz.) 2 Contact Type B B (NC) C (SPDT)* C 3 Connections 3 for 1/4˝ Quick Connects 2 solder 6 for 3/16˝ Quick Connects 4 Dimensions Actuators** 22.2 (.87) 2.8 (.11) Ø=no Actuator 20.2 (.8) 3 (.12) (Flat) E (Roller) L (Pushbutton) 3.4 (.13) 27.8 (1.09) RF 4 (.16) 10 (.39) OL A Ø 3.2 (Ø .125) DT PT TP X1 for printed circuit board Actuators and mounting positions OT OF Assigned working voltage (Ue) Assigned working current (Ie) Thermal current rating (Ith) Assigned circuit voltage (Ui) NC 250 6 10 250 15.8 (.62) Definitions P.O.F. Minimum Positive Opening Force. The operating force that has to be applied to the operating device to produce the positive opening action. P.O.P. Maximum Positive Opening Position. The position of the operating device at the moment when positive opening of the contacts occurs. For other definitions, see "Basic concepts". Electrical characteristics 3.2 (.125) Electrical characteristics Short-circuit test (from IEC 947-5-1 § 8.34) - Current peak 1000 A at 250 V a 0.5 < cos ϕ < 0.7 - Short-circuit protection (SCPD) : fuse 10 A gG - (IEC 60) (1.2/50 µs) : 2500 V Electrical life Max. operations : 20 cycles/min Resistive load at 250 V~ 16 A : 105 cycles Inductive load (IEC 947.5.1) : AC 15 : 250 V~ 6A : 0.3 x 105 operations DC 13 : 24 V c 20 W L/R = 40 ms : 3 x 105 operations 120 V c 20 W L/R = 40 ms : 5 x 105 operations With positive break operation 10.3 (.41) Components Material - Case : glass-filled polyamide - Cover : transparent polycarbonate - Contacts : nickel silver - Positive rocker : high temperature thermoplastic Actuators : stainless steel - polyamide roller Features OL=13.1 (.52) The contact conforms to NFC 63 143 and IEC 947.5.1 *The SPDT version conforms to standard IEC 947.5.1 if only the normally closed contact is used. The switch operating principle forces the contacts open even in the event of welding (positive break operation). RLP NC NO mm (in) Other information To order, specify : Example : 831607 B 3 • Ø For other accessories, connections : please consult us 1 *NO – contact is not positive break Switch Type 831607 ** Consult us for actuator length, forces and positions 2 Contact Type B C 3 Connection 2 3 6 X1 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/18 4 Actuator Type A L E Ø = No Actuator
83160705 价格&库存
很抱歉,暂时无法提供与“83160705”相匹配的价格&库存,您可以联系我们找货
