电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
83264636
    CROUZET(高诺斯)
83264636 数据手册
■ Timing applications ■ Valves ■ HVAC Mi c ro sw i t ch e s miniature V3D Microswitches miniature V3D Crouzet Presentation ■ Adaptation p. 3 ■ Customisation is our business p. 4 ■ V3D Advantages p. 5 ■ Ordering information p. 5 ■ Basic technical principles p. 5 ■ Main specifications p. 6 ■ Additional specifications p. 6 ■ Principle p. 7 ■ Dimensions p. 7 ■ Product adaptations p. 7 ■ Connections p. 8 ■ Actuators p. 9 ■ Mounting-Operation p. 9 To suit your design requirements, Crouzet continues to develop its capabilities as a specialist in customisation, offering you solutions specifically adapted to all your applications. Because our top most priority is nothing be left to chance, our quality and environmental management systems are certified to ISO 9001 and ISO 14001. About Custom Sensors & Technologies ■ Mechanical characteristics 2 Crouzet has been a recognised supplier of quality position sensors, micro-switches and limit switches for more than 30 years. Today, Crouzet offers you a new range of micro-switches designed to fulfill the toughest of OEMs’ requirements. with actuators p.10 ■ Selection guide p.11 Headquartered in Moorpark, CA - Custom Sensors & Technologies (CST) is comprised of industry-leading brands including Crouzet, Kavlico, Crydom, and former divisions of BEI Technologies – Newall and Systron Donner. CST provides sensors, controls, and actuation products for the Transportation, Industrial and Aerospace & Defense markets. Crouzet Adaptation To meet the growing demand for customisation, Crouzet’s expertise in terms of adapting products and their corresponding accessories is available to all customers. ■ All our expertise in sensing design and industrialisation placed at your service, to respond to a specific need dedicated to your application. ■ A complete range of standard microswitches available immediately to create your sensing application. Crouzet can customise its products for use in any type of environment or application to ensure perfect integration into any equipment. Because quality is at the heart of our approach, our quality control and environmental management system are certified to ISO 9001 and ISO 14001 respectively. Specific products Standard components Custom products Components with added value ■ Defined in coordination with our technical sales teams, these custom products have the corresponding performance and functionality. ■ Standard products complemented by factory-mounted auxiliaries or accessories (levers, cables, connectors, etc) in order to assist integration in your equipment, simplify your logistics and maximise the reliability of your installation. Crouzet Process ■ Customer needs ■ R&D department ■ Production ■ Quality 3 Microswitches miniature V3D Crouzet Customisation is our business ■ Control devices Even more adaptation for easier actuating 4 ■ Connections AConnections complete electrical function Special button shapes which compensate for any faults or positioning drift of the control actuator. Special connectors, customised wiring, customer bundles, dedicated terminals… ■ Seals ■ Special levers Even more solutions for demanding environments Obtain the control data Numerous components available to provide effective protection for your contacts, including caps, boot seals, membranes, sealing resin, wiper seals. Angled, curved, extended or retractable... these special lever types can be used to extend the control device for easier adjustment, increase the operating force, resist high actuation torque or provide totally safe electrical isolation. ■ Special contacts ■ Special fixings The right contact for every environment No effort is spared to make mounting easier High or low current, AC or DC, type of load (inductive or resistive), industrial or corrosive atmosphere, occasional or intensive use. The best metals, silver, silver nickel, silver palladium, goldplated silver, solid gold. Snap-on fixing, screw-fixing, crimping or pins are just a few examples of the numerous solutions available to meet all your requirements. V3D Advantages ■ Wide range of switching ratings from 0.1 A to 21 A ■ V3 standard size ■ Approved to ENEC (EN 61058-1) and UL/CSA ■ Compliant to RoHS ■ Glow wire test withstanding to EN 60335-1: GWFI 850°C and GWIT 775°C ■ Various applications areas: Industry, Consumer equipment, Home appliances, HVAC, … ■ A high capacity to adapt levers, connections, fixing elements, upon request Ordering Information Model Number Legend 8 3 2 6 X X X X 1 2 3 4 ■ 1 - Ratings / Operating force max ■ 2 - Functions ■ 3 - Connections ■ 4 - Actuators 1: 16 A / 2 N 0: Changeover 0: W1 screws 1: Plunger 2: 20 A / 2 N 6: Normally closed 1: W2 solder 2: Lever 260A R14.2 3: 16 A / 1 N 8: Normally open 2: W3 for 6.35 mm clips 3: Lever 260A R25.4 4: 12 A / 0.5 N 3: W3R5 for Rast 5 connector 4: Lever 260A R40 5: 5 A / 0.25 N 4: W6A5 for 4.8 x 0.5 mm clips 5: Lever 260A R60 8: 0.05 A / 1 N 5: W6D8 for 4.8 x 0.8 mm clips 6: Lever 260F R22.2 9: 0.05 A / 0.25 N 6: W7A5 for 2.8 x 0.5mm clips 7: Lever 260E R13.7 7: X2 rear side for PCB 8: Lever 260E R24.3 8: X3 front side for PCB 9: Lever 260G R13.8 9: X1 straight for PCB W3R2.5 for Rast 2.5 connector (SP9307): Contact us Basic technical principles ■ See our Position Sensors Catalogue 5 Microswitches miniature V3D ■ ■ ■ ■ Nominal ratings from 0.1 A to 21 A Operating temperature up to + 150°C Approved to ENEC and UL/CSA Large choice of actuators Main specifications Function I (changeover) R (normally closed) C (normally open) 83261 83262 83263 83264 W1 - W2 - W3 - W3R5 - W6A5 W6D8 - W7A5 - X1 - X2 - X3 W1 - W2 - W3 - W3R5 - W6A5 W6D8 - W7A5 ● ● ● ● ● ● ● ● W1 - W2 - W3 - W3R5 - W6A5 W6D8 - W7A5 ● ● ● ● Connections Electrical characteristics Rating nominal / 250 V AC (A) 16 20 16 12 Rating thermal / 250 V AC (A) 20 25 20 15 Rating nominal / 5 ➞ 24 V AC/DC (A) - - - - Mechanical characteristics Maximum operating force (N) 2 2 1 0.5 Min. Release force (N) 0.5 0.5 0.2 0.1 Maximum total travel force (N) 3 3 1.5 0.8 Max. permitted overtravel force (N) 20 20 20 20 Maximum rest position (mm) 16.2 16.2 16.2 16.2 Tripping point (mm) 14.7±0.5 14.7±0.5 14.7±0.5 14.7±0.5 Maximum differential travel (mm) 0.40 0.40 0.40 0.40 Min. overtravel (mm) 1.1 1.1 1.1 1.1 Ambient operating temperature (°C) -20 ➞ +125 -20 ➞ +125 -20 ➞ +125 -20 ➞ +125 Mechanical life for 2/3 OT (operations) 1 000 000 1 000 000 1 000 000 1 000 000 Contact gap (mm) 0.6 0.6 0.6 0.6 Weight (g) 6 6 6 6 Rating for T125°C ** T150°C *** T85°C 16 (4) A 250 V AC 20 (8) A 250 V AC 16 (4) A 250 V AC ***12 (6) A 250 V AC Number of cycles 50 000 50 000 50 000 Rating 16 A 125 / 250 V AC 16 A 125 / 250 V AC 8 A 1/4 HP 125 / 250 V AC Number of cycles 6 000 10 000 21 A 125 / 250 V AC 1/2 HP 125 V AC 1 HP 250 V AC 6 000 6 000 6 000 Approvals EN 61058-1 UL 1054 Additional specifications Component Materials ■ ■ ■ ■ ■ 6 Housing/cover/button: polyester UL 94V0 - GWIT 775°C / GWFI 850°C Blade/spring: copper alloy Contacts: silver alloy or gold plated Terminals: brass or silver plated brass Actuators: stainless steel, glass filled polyamide roller Principle Single break changeover switch 83265 83268 83269 ● ● ● 2 ● ● ● 4 ● ● ● 5 - - 7.5 - - - 0.001 ➞ 0.05 0.001 ➞ 0.05 1 Dimensions (mm) V3D 0.2 0.25 0.05 0.4 1.5 0.4 20 20 20 16.2 16.2 16.2 14.7±0.5 14.7±0.5 14.7±0.5 0.40 0.40 0.40 1.1 1.1 1.1 -20 ➞ +125 -20 ➞ +150 -20 ➞ +150 1 000 000 1 000 000 1 000 000 0.6 0.6 0.6 6 6 6 27.8 1 lever fixing position B 2.8 ** 0.1 (0.04) A 250 V AC 50 000 50 000 50 000 5 A 1/10 HP 125 / 250 V AC 0.1 A 125 V AC 0.1 A 30 V DC 0.1 A 125 V AC 0.1 A 30 V DC 6 000 6 000 6 000 22.2 ± 0.2 20.2 ± 0.2 2.8 Ø3.1 -+ 0.15 0.05 NC2 C1 3.1 -+ 0.15 0.05 ** 0.1 (0.04) A 250 V AC 8.1 2.8 2 ** 5 (1) A 250 V AC 1 10.3 ± 0.15 4.4 1 0.05 10.3 ± 0.1 0.25 3.4 NO4 9.8 2 Total Travel Position 13.2 max Product adaptations ■ ■ ■ ■ ■ ■ Rast 2.5 connection (SP9307): see Connections Other specific connections Specific levers Specific contacts Specific fixing High operating temperature 7 Microswitches miniature V3D Connections W1 W3 W2 8.3 4.3 6.3 Ø 2.1 +- 0.15 0 2.8 9.5 NC2 0.8 ± 0.05 W6D8 7.3min. 3.15 5.6 C1 9.6 0.2 0.8 ± 0.05 0.2 9.6 X1 W7A5 X2 15 ± 0.1 1.3 ± 0.1 6.35 2.85 Ø1.2 +0.1 -0 2.8 ± 0.1 1.6 ± 0.2 NO4 0.5 ± 0.05 5 ± 0.5 16.8 0.8 ± 0.05 NO4 NC2 C1 6 8.8 NC2 16.8 NC2 NO4 3.5 Max. NC2 0.2 NO4 9.4± 0.2 14.55 ± 0.2 0.5 ± 0.05 5 ± 0.5 4.95 ± 0.5 view A NC2 1.3 ± 0.1 C1 NO4 9.4 7.7 0.8 ± 0.05 0.5 ± 0.05 3.2 NO4 9.6 8 6 16.8 C1 C1 2.85 view A NC2 5.2 2.8 13.5 ± 0.2 3.2 2.8 7.1 +0.1 -0 16.8 1.4 2.8 13.5 ± 0.2 5.2 ± 0.2 14.1 5 ± 0.5 12min 7.1± 0.1 Ø1.4 +- 0.15 0 Ø 1.65 ± 0.1 16.8 ± 0.4 Ø1.4 ± 0.05 4.8 ± 0.1 3.1 ± 0.1 4.75 ± 0.1 6.3 4.25 9.8 1.9 9.8 W6A5 C1 NO4 1.6 8.2 3.3 W3R5 8.8 NO4 C1 3XM3.0 6.5 6 16.8 C1 0.8 6 16.5 NC2 NO4 1.4 9 NC2 C1 16.6 16.8 0.8 ± 0.05 2.8 9.3 Ø1.65 +- 00.15 X3 W3R2.5 (SP9307) 6.3 2.85 1.5 3.5 Max. +0 6 - 0.1 5 5.2 16.8 ± 0.4 12min. ± 0.5 1.3 3.2 15± 0.1 ± 0.2 ± 0.1 16.8 0.8 ± 0.05 9.8 5 9.4 NO4 ± 0.5 NO4 C1 7.7 0.8 ± 0.05 C1 NC2 5.2 NC2 Contact us Actuators 260 A 260 E 260 F Ø 4.8x3 R 5.7 3.4 0.7x4 R R 0. 90° 7x NC2 C1 4 NC2 NO4 C1 NC2 NO4 C1 NO4 260 G R13.8 12.3 5.15 R2 NC2 C1 NO4 Mounting - Operation Actuator mounting position To conform to the leakage paths and air gaps required in the standard EN/IEC 61058-1 - EN/IEC 60947-5-1: 0.85 11.75 NC2 C1 NO4 NC2 C1 NO4 ■ An insulation pad must be inserted between the microswitch and the fixing surface if the fixing surface is metal. ■ Manual operation of a metal actuator must only be carried out with the help of a secondary actuator made of insulating material. The installer must ensure adequate protection against direct contact with the output terminals. 9 Microswitches miniature V3D Mechanical characteristics with actuators Lever 260A R14.2 Pos B Lever 260A R25.4 Pos B Lever 260A R40 Pos B Lever 260A R60 Pos B Lever 260F R22.2 Pos B Lever 260E R13.7 Pos B 10 Length of actuator (mm) Maximum operating force (N) Minimum release force (N) Tripping point (mm) Minimum overtravel (mm) Maximum differential travel (mm) Maximum total travel (mm) 83261 14.2 2 0.5 15.4±0.5 1.1 0.4 3 83262 14.2 2 0.5 15.4±0.5 1.1 0.4 3 83263 14.2 1 0.2 15.4±0.5 1.1 0.4 3 ±0.5 83264 14.2 0.5 0.1 15.4 1.1 0.4 3 83265 14.2 0.25 0.05 15.4±0.5 1.1 0.4 3 83268 14.2 1 0.2 15.4±0.5 1.1 0.4 3 ±0.5 83269 14.2 0.25 0.05 15.4 1.1 0.4 3 83261 25.4 1 0.25 15.4±1 2 0.8 5.8 83262 25.4 1 0.25 15.4±1 2 0.8 5.8 ±1 83263 25.4 0.5 0.1 15.4 2 0.8 5.8 83264 25.4 0.25 0.05 15.4±1 2 0.8 5.8 ±1 83265 25.4 0.13 0.02 15.4 2 0.8 5.8 83268 25.4 0.5 0.1 15.4±1 2 0.8 5.8 83269 25.4 0.13 0.02 15.4±1 2 0.8 5.8 ±1.8 83261 40 0.6 0.15 15.4 3.3 1.3 9.6 83262 40 0.6 0.15 15.4±1.8 3.3 1.3 9.6 83263 40 0.3 0.06 15.4±1.8 3.3 1.3 9.6 ±1.8 83264 40 0.15 0.03 15.4 3.3 1.3 9.6 83265 40 0.08 0.01 15.4±1.8 3.3 1.3 9.6 83268 40 0.3 0.06 15.4±1.8 3.3 1.3 9.6 ±1.8 83269 40 0.08 0.01 15.4 3.3 1.3 9.6 83261 60 0.4 0.1 15.4±2.5 5 2 14.5 83262 60 0.4 0.1 15.4±2.5 5 2 14.5 ±2.5 14.5 83263 60 0.2 0.04 15.4 5 2 83264 60 0.1 0.02 15.4±2.5 5 2 14.5 83265 60 0.05 0.01 15.4±2.5 5 2 14.5 83268 60 0.2 0.04 15.4±2.5 5 2 14.5 83269 60 0.05 0.01 15.4±1 5 2 14.5 83261 22.2 1.06 0.26 20.4±1 1.8 0.75 5.2 83262 22.2 1.06 0.26 20.4±1 1.8 0.75 5.2 83263 22.2 0.53 0.1 20.4±1 1.8 0.75 5.2 83264 22.2 0.27 0.05 20.4±1 1.8 0.75 5.2 ±1 83265 22.2 0.13 0.02 20.4 1.8 0.75 5.2 83268 22.2 0.53 0.1 20.4±1 1.8 0.75 5.2 83269 22.2 0.13 0.02 20.4±1 1.8 0.75 5.2 ±0.8 83261 13.7 2 0.5 20.5 1.1 0.4 3 83262 13.7 2 0.5 20.5±0.8 1.1 0.4 3 83263 13.7 1 0.2 20.5±0.8 1.1 0.4 3 ±0.8 3 83264 13.7 0.5 0.1 20.5 1.1 0.4 83265 13.7 0.25 0.05 20.5±0.8 1.1 0.4 3 83268 13.7 1 0.2 20.5±0.8 1.1 0.4 3 83269 13.7 0.25 0.05 20.5±0.8 1.1 0.4 3 Length of actuator (mm) Maximum operating force (N) Minimum release force (N) Tripping point (mm) Minimum overtravel (mm) Maximum differential travel (mm) Maximum total travel (mm) 24.3 1 0.25 20.5±1.5 2 0.8 5.8 ±1.5 83261 Lever 260E R24.3 Pos B Lever 260G R13.8 Pos B 83262 24.3 1 0.25 20.5 2 0.8 5.8 83263 24.3 0.5 0.1 20.5±1.5 2 0.8 5.8 83264 24.3 0.25 0.05 20.5±1.5 2 0.8 5.8 ±1.5 83265 24.3 0.13 0.02 20.5 2 0.8 5.8 83268 24.3 0.5 0.1 20.5±1.5 2 0.8 5.8 83269 24.3 0.13 0.02 20.5±1.5 2 0.8 5.8 ±0.7 83261 13.8 2 0.5 19.9 1.1 0.4 3 83262 13.8 2 0.5 19.9±0.7 1.1 0.4 3 83263 13.8 1 0.2 19.9±0.7 1.1 0.4 3 ±0.7 83264 13.8 0.5 0.1 19.9 1.1 0.4 3 83265 13.8 0.25 0.05 19.9±0.7 1.1 0.4 3 ±0.7 1.1 0.4 3 1.1 0.4 3 83268 13.8 1 0.2 19.9 83269 13.8 0.25 0.05 19.9±0.7 Selection guide Rating / Force Type Actuators Plunger 16 A / 2 N 20 A / 2 N 16 A / 1 N 12 A / 0.5 N 5 A / 0.25 N 0.05 A / 1 N 0.05 A / 0.25 N 83261 83262 83263 83264 83265 83268 83269 Function Connection I W1 83261001 83262001 83263001 83264001 83265001 83268001 83269001 I W2 83261011 83262011 83263011 83264011 83265011 83268011 83269011 I W3 83261021 83262021 83263021 83264021 83265021 83268021 83269021 I W3R5 83261031 83262031 83263031 83264031 83265031 83268031 83269031 I W6A5 83261041 83262041 83263041 83264041 83265041 83268041 83269041 I W6D8 83261051 83262051 83263051 83264051 83265051 83268051 83269051 I W7A5 83261061 - 83263061 83264061 83265061 83268061 83269061 I X2 83261071 - 83263071 83264071 83265071 83268071 83269071 I X3 83261081 - 83263081 83264081 83265081 83268081 83269081 I X1 83261091 - 83263091 83264091 83265091 83268091 83269091 R W1 83261601 83262601 83263601 83264601 83265601 83268601 83269601 R W2 83261611 83262611 83263611 83264611 83265611 83268611 83269611 R W3 83261621 83262621 83263621 83264621 83265621 83268621 83269621 R W3R5 83261631 83262631 83263631 83264631 83265631 83268631 83269631 R W6A5 83261641 83262641 83263641 83264641 83265641 83268641 83269641 R W6D8 83261651 83262651 83263651 83264651 83265651 83268651 83269651 R W7A5 83261661 - 83263661 83264661 83265661 83268661 83269661 C W1 83261801 83262801 83263801 83264801 83265801 83268801 83269801 C W2 83261811 83262811 83263811 83264811 83265811 83268811 83269811 C W3 83261821 83262821 83263821 83264821 83265821 83268821 83269821 C W3R5 83261831 83262831 83263831 83264831 83265831 83268831 83269831 C W6A5 83261841 83262841 83263841 83264841 83265841 83268841 83269841 C W6D8 83261851 83262851 83263851 83264851 83265851 83268851 83269851 C W7A5 83261861 - 83263861 83264861 83265861 83268861 83269861 11 Microswitches miniature V3D Rating / Force Type Actuators Lever 260A R14.2 Pos B Lever 260A R25.4 Pos B 16 A / 2 N 20 A / 2 N 16 A / 1 N 12 A / 0.5 N 5 A / 0.25 N 0.05 A / 1 N 0.05 A / 0.25 N 83261 83262 83263 83264 83265 83268 83269 Function Connection I W1 83261002 83262002 83263002 83264002 83265002 83268002 83269002 I W2 83261012 83262012 83263012 83264012 83265012 83268012 83269012 I W3 83261022 83262022 83263022 83264022 83265022 83268022 83269022 I W3R5 83261032 83262032 83263032 83264032 83265032 83268032 83269032 I W6A5 83261042 83262042 83263042 83264042 83265042 83268042 83269042 I W6D8 83261052 83262052 83263052 83264052 83265052 83268052 83269052 I W7A5 83261062 - 83263062 83264062 83265062 83268062 83269062 I X2 83261072 - 83263072 83264072 83265072 83268072 83269072 I X3 83261082 - 83263082 83264082 83265082 83268082 83269082 I X1 83261092 - 83263092 83264092 83265092 83268092 83269092 R W1 83261602 83262602 83263602 83264602 83265602 83268602 83269602 R W2 83261612 83262612 83263612 83264612 83265612 83268612 83269612 R W3 83261622 83262622 83263622 83264622 83265622 83268622 83269622 R W3R5 83261632 83262632 83263632 83264632 83265632 83268632 83269632 R W6A5 83261642 83262642 83263642 83264642 83265642 83268642 83269642 R W6D8 83261652 83262652 83263652 83264652 83265652 83268652 83269652 R W7A5 83261662 - 83263662 83264662 83265662 83268662 83269662 C W1 83261802 83262802 83263802 83264802 83265802 83268802 83269802 C W2 83261812 83262812 83263812 83264812 83265812 83268812 83269812 C W3 83261822 83262822 83263822 83264822 83265822 83268822 83269822 C W3R5 83261832 83262832 83263832 83264832 83265832 83268832 83269832 C W6A5 83261842 83262842 83263842 83264842 83265842 83268842 83269842 C W6D8 83261852 83262852 83263852 83264852 83265852 83268852 83269852 C W7A5 83261862 - 83263862 83264862 83265862 83268862 83269862 I W1 83261003 83262003 83263003 83264003 83265003 83268003 83269003 I W2 83261013 83262013 83263013 83264013 83265013 83268013 83269013 I W3 83261023 83262023 83263023 83264023 83265023 83268023 83269023 I W3R5 83261033 83262033 83263033 83264033 83265033 83268033 83269033 I W6A5 83261043 83262043 83263043 83264043 83265043 83268043 83269043 I W6D8 83261053 83262053 83263053 83264053 83265053 83268053 83269053 I W7A5 83261063 - 83263063 83264063 83265063 83268063 83269063 I X2 83261073 - 83263073 83264073 83265073 83268073 83269073 I X3 83261083 - 83263083 83264083 83265083 83268083 83269083 I X1 83261093 - 83263093 83264093 83265093 83268093 83269093 R W1 83261603 83262603 83263603 83264603 83265603 83268603 83269603 R W2 83261613 83262613 83263613 83264613 83265613 83268613 83269613 R W3 83261623 83262623 83263623 83264623 83265623 83268623 83269623 R W3R5 83261633 83262633 83263633 83264633 83265633 83268633 83269633 R W6A5 83261643 83262643 83263643 83264643 83265643 83268643 83269643 R W6D8 83261653 83262653 83263653 83264653 83265653 83268653 83269653 R W7A5 83261663 - 83263663 83264663 83265663 83268663 83269663 C W1 83261803 83262803 83263803 83264803 83265803 83268803 83269803 C W2 83261813 83262813 83263813 83264813 83265813 83268813 83269813 C W3 83261823 83262823 83263823 83264823 83265823 83268823 83269823 C W3R5 83261833 83262833 83263833 83264833 83265833 83268833 83269833 C W6A5 83261843 83262843 83263843 83264843 83265843 83268843 83269843 C W6D8 83261853 83262853 83263853 83264853 83265853 83268853 83269853 C W7A5 83261863 - 83263863 83264863 83265863 83268863 83269863 Note: Function: I = Changeover - R = Normally closed - C = Normally open Connection: W1 = screws - W2 = solder - W3 = for 6.35 mm clips - W3R5 = for Rast 5 connector W6A5 = for 4.8 x 0.5 mm clips - W6D8 = for 4.8 x 0.8 mm clips - W7A5 = for 2.8 x 0.5 mm clips X2 = rear side for PCB - X3 = front side for PCB - X1 = straight for PCB 12 Rating / Force Type Actuators Lever 260A R40 Pos B Lever 260A R60 Pos B 16 A / 2 N 20 A / 2 N 16 A / 1 N 12 A / 0.5N 5 A / 0.25 N 0.05 A / 1 N 0.05 A / 0.25 N 83261 83262 83263 83264 83265 83268 83269 Function Connection I W1 83261004 83262004 83263004 83264004 83265004 83268004 83269004 I W2 83261014 83262014 83263014 83264014 83265014 83268014 83269014 I W3 83261024 83262024 83263024 83264024 83265024 83268024 83269024 I W3R5 83261034 83262034 83263034 83264034 83265034 83268034 83269034 I W6A5 83261044 83262044 83263044 83264044 83265044 83268044 83269044 I W6D8 83261054 83262054 83263054 83264054 83265054 83268054 83269054 I W7A5 83261064 - 83263064 83264064 83265064 83268064 83269064 I X2 83261074 - 83263074 83264074 83265074 83268074 83269074 I X3 83261084 - 83263084 83264084 83265084 83268084 83269084 I X1 83261094 - 83263094 83264094 83265094 83268094 83269094 R W1 83261604 83262604 83263604 83264604 83265604 83268604 83269604 R W2 83261614 83262614 83263614 83264614 83265614 83268614 83269614 R W3 83261624 83262624 83263624 83264624 83265624 83268624 83269624 R W3R5 83261634 83262634 83263634 83264634 83265634 83268634 83269634 R W6A5 83261644 83262644 83263644 83264644 83265644 83268644 83269644 R W6D8 83261654 83262654 83263654 83264654 83265654 83268654 83269654 R W7A5 83261664 - 83263664 83264664 83265664 83268664 83269664 C W1 83261804 83262804 83263804 83264804 83265804 83268804 83269804 C W2 83261814 83262814 83263814 83264814 83265814 83268814 83269814 C W3 83261824 83262824 83263824 83264824 83265824 83268824 83269824 C W3R5 83261834 83262834 83263834 83264834 83265834 83268834 83269834 C W6A5 83261844 83262844 83263844 83264844 83265844 83268844 83269844 C W6D8 83261854 83262854 83263854 83264854 83265854 83268854 83269854 C W7A5 83261864 - 83263864 83264864 83265864 83268864 83269864 I W1 83261005 83262005 83263005 83264005 83265005 83268005 83269005 I W2 83261015 83262015 83263015 83264015 83265015 83268015 83269015 I W3 83261025 83262025 83263025 83264025 83265025 83268025 83269025 I W3R5 83261035 83262035 83263035 83264035 83265035 83268035 83269035 I W6A5 83261045 83262045 83263045 83264045 83265045 83268045 83269045 I W6D8 83261055 83262055 83263055 83264055 83265055 83268055 83269055 I W7A5 83261065 - 83263065 83264065 83265065 83268065 83269065 I X2 83261075 - 83263075 83264075 83265075 83268075 83269075 I X3 83261085 - 83263085 83264085 83265085 83268085 83269085 I X1 83261095 - 83263095 83264095 83265095 83268095 83269095 R W1 83261605 83262605 83263605 83264605 83265605 83268605 83269605 R W2 83261615 83262615 83263615 83264615 83265615 83268615 83269615 R W3 83261625 83262625 83263625 83264625 83265625 83268625 83269625 R W3R5 83261635 83262635 83263635 83264635 83265635 83268635 83269635 R W6A5 83261645 83262645 83263645 83264645 83265645 83268645 83269645 R W6D8 83261655 83262655 83263655 83264655 83265655 83268655 83269655 R W7A5 83261665 - 83263665 83264665 83265665 83268665 83269665 C W1 83261805 83262805 83263805 83264805 83265805 83268805 83269805 C W2 83261815 83262815 83263815 83264815 83265815 83268815 83269815 C W3 83261825 83262825 83263825 83264825 83265825 83268825 83269825 C W3R5 83261835 83262835 83263835 83264835 83265835 83268835 83269835 C W6A5 83261845 83262845 83263845 83264845 83265845 83268845 83269845 C W6D8 83261855 83262855 83263855 83264855 83265855 83268855 83269855 C W7A5 83261865 - 83263865 83264865 83265865 83268865 83269865 Note: Function: I = Changeover - R = Normally closed - C = Normally open Connection: W1 = screws - W2 = solder - W3 = for 6.35 mm clips - W3R5 = for Rast 5 connector W6A5 = for 4.8 x 0.5 mm clips - W6D8 = for 4.8 x 0.8 mm clips - W7A5 = for 2.8 x 0.5 mm clips X2 = rear side for PCB - X3 = front side for PCB - X1 = straight for PCB 13 Microswitches miniature V3D Rating / Force Type Actuators Lever 260F R22.2 Pos B Lever 260E R13.7 Pos B 16 A / 2 N 20 A / 2 N 16 A / 1 N 12 A / 0.5 N 5 A / 0.25 N 0.05 A / 1 N 0.05 A / 0.25 N 83261 83262 83263 83264 83265 83268 83269 Function Connection I W1 83261006 83262006 83263006 83264006 83265006 83268006 83269006 I W2 83261016 83262016 83263016 83264016 83265016 83268016 83269016 I W3 83261026 83262026 83263026 83264026 83265026 83268026 83269026 I W3R5 83261036 83262036 83263036 83264036 83265036 83268036 83269036 I W6A5 83261046 83262046 83263046 83264046 83265046 83268046 83269046 I W6D8 83261056 83262056 83263056 83264056 83265056 83268056 83269056 I W7A5 83261066 - 83263066 83264066 83265066 83268066 83269066 I X2 83261076 - 83263076 83264076 83265076 83268076 83269076 I X3 83261086 - 83263086 83264086 83265086 83268086 83269086 I X1 83261096 - 83263096 83264096 83265096 83268096 83269096 R W1 83261606 83262606 83263606 83264606 83265606 83268606 83269606 R W2 83261616 83262616 83263616 83264616 83265616 83268616 83269616 R W3 83261626 83262626 83263626 83264626 83265626 83268626 83269626 R W3R5 83261636 83262636 83263636 83264636 83265636 83268636 83269636 R W6A5 83261646 83262646 83263646 83264646 83265646 83268646 83269646 R W6D8 83261656 83262656 83263656 83264656 83265656 83268656 83269656 R W7A5 83261666 - 83263666 83264666 83265666 83268666 83269666 C W1 83261806 83262806 83263806 83264806 83265806 83268806 83269806 C W2 83261816 83262816 83263816 83264816 83265816 83268816 83269816 C W3 83261826 83262826 83263826 83264826 83265826 83268826 83269826 C W3R5 83261836 83262836 83263836 83264836 83265836 83268836 83269836 C W6A5 83261846 83262846 83263846 83264846 83265846 83268846 83269846 C W6D8 83261856 83262856 83263856 83264856 83265856 83268856 83269856 C W7A5 83261866 - 83263866 83264866 83265866 83268866 83269866 I W1 83261007 83262007 83263007 83264007 83265007 83268007 83269007 I W2 83261017 83262017 83263017 83264017 83265017 83268017 83269017 I W3 83261027 83262027 83263027 83264027 83265027 83268027 83269027 I W3R5 83261037 83262037 83263037 83264037 83265037 83268037 83269037 I W6A5 83261047 83262047 83263047 83264047 83265047 83268047 83269047 I W6D8 83261057 83262057 83263057 83264057 83265057 83268057 83269057 I W7A5 83261067 - 83263067 83264067 83265067 83268067 83269067 I X2 83261077 - 83263077 83264077 83265077 83268077 83269077 I X3 83261087 - 83263087 83264087 83265087 83268087 83269087 I X1 83261097 - 83263097 83264097 83265097 83268097 83269097 R W1 83261607 83262607 83263607 83264607 83265607 83268607 83269607 R W2 83261617 83262617 83263617 83264617 83265617 83268617 83269617 R W3 83261627 83262627 83263627 83264627 83265627 83268627 83269627 R W3R5 83261637 83262637 83263637 83264637 83265637 83268637 83269637 R W6A5 83261647 83262647 83263647 83264647 83265647 83268647 83269647 R W6D8 83261657 83262657 83263657 83264657 83265657 83268657 83269657 R W7A5 83261667 - 83263667 83264667 83265667 83268667 83269667 C W1 83261807 83262807 83263807 83264807 83265807 83268807 83269807 C W2 83261817 83262817 83263817 83264817 83265817 83268817 83269817 C W3 83261827 83262827 83263827 83264827 83265827 83268827 83269827 C W3R5 83261837 83262837 83263837 83264837 83265837 83268837 83269837 C W6A5 83261847 83262847 83263847 83264847 83265847 83268847 83269847 C W6D8 83261857 83262857 83263857 83264857 83265857 83268857 83269857 C W7A5 83261867 - 83263867 83264867 83265867 83268867 83269867 Note: Function: I = Changeover - R = Normally closed - C = Normally open Connection: W1 = screws - W2 = solder - W3 = for 6.35 mm clips - W3R5 = for Rast 5 connector W6A5 = for 4.8 x 0.5 mm clips - W6D8 = for 4.8 x 0.8 mm clips - W7A5 = for 2.8 x 0.5 mm clips X2 = rear side for PCB - X3 = front side for PCB - X1 = straight for PCB 14 Rating / Force Type Actuators Lever 260E R24.3 Pos B Lever 260G R13.8 Pos B 16 A / 2 N 20 A / 2 N 16 A / 1 N 12 A / 0.5 N 5 A / 0.25 N 0.05 A / 1 N 0.05 A / 0.25 N 83261 83262 83263 83264 83265 83268 83269 Function Connection I W1 83261008 83262008 83263008 83264008 83265008 83268008 83269008 I W2 83261018 83262018 83263018 83264018 83265018 83268018 83269018 I W3 83261028 83262028 83263028 83264028 83265028 83268028 83269028 I W3R5 83261038 83262038 83263038 83264038 83265038 83268038 83269038 I W6A5 83261048 83262048 83263048 83264048 83265048 83268048 83269048 I W6D8 83261058 83262058 83263058 83264058 83265058 83268058 83269058 I W7A5 83261068 - 83263068 83264068 83265068 83268068 83269068 I X2 83261078 - 83263078 83264078 83265078 83268078 83269078 I X3 83261088 - 83263088 83264088 83265088 83268088 83269088 I X1 83261098 - 83263098 83264098 83265098 83268098 83269098 R W1 83261608 83262608 83263608 83264608 83265608 83268608 83269608 R W2 83261618 83262618 83263618 83264618 83265618 83268618 83269618 R W3 83261628 83262628 83263628 83264628 83265628 83268628 83269628 R W3R5 83261638 83262638 83263638 83264638 83265638 83268638 83269638 R W6A5 83261648 83262648 83263648 83264648 83265648 83268648 83269648 R W6D8 83261658 83262658 83263658 83264658 83265658 83268658 83269658 R W7A5 83261668 - 83263668 83264668 83265668 83268668 83269668 C W1 83261808 83262808 83263808 83264808 83265808 83268808 83269808 C W2 83261818 83262818 83263818 83264818 83265818 83268818 83269818 C W3 83261828 83262828 83263828 83264828 83265828 83268828 83269828 C W3R5 83261838 83262838 83263838 83264838 83265838 83268838 83269838 C W6A5 83261848 83262848 83263848 83264848 83265848 83268848 83269848 C W6D8 83261858 83262858 83263858 83264858 83265858 83268858 83269858 C W7A5 83261868 - 83263868 83264868 83265868 83268868 83269868 I W1 83261009 83262009 83263009 83264009 83265009 83268009 83269009 I W2 83261019 83262019 83263019 83264019 83265019 83268019 83269019 I W3 83261029 83262029 83263029 83264029 83265029 83268029 83269029 I W3R5 83261039 83262039 83263039 83264039 83265039 83268039 83269039 I W6A5 83261049 83262049 83263049 83264049 83265049 83268049 83269049 I W6D8 83261059 83262059 83263059 83264059 83265059 83268059 83269059 I W7A5 83261069 - 83263069 83264069 83265069 83268069 83269069 I X2 83261079 - 83263079 83264079 83265079 83268079 83269079 I X3 83261089 - 83263089 83264089 83265089 83268089 83269089 I X1 83261099 - 83263099 83264099 83265099 83268099 83269099 R W1 83261609 83262609 83263609 83264609 83265609 83268609 83269609 R W2 83261619 83262619 83263619 83264619 83265619 83268619 83269619 R W3 83261629 83262629 83263629 83264629 83265629 83268629 83269629 R W3R5 83261639 83262639 83263639 83264639 83265639 83268639 83269639 R W6A5 83261649 83262649 83263649 83264649 83265649 83268649 83269649 R W6D8 83261659 83262659 83263659 83264659 83265659 83268659 83269659 R W7A5 83261669 - 83263669 83264669 83265669 83268669 83269669 C W1 83261809 83262809 83263809 83264809 83265809 83268809 83269809 C W2 83261819 83262819 83263819 83264819 83265819 83268819 83269819 C W3 83261829 83262829 83263829 83264829 83265829 83268829 83269829 C W3R5 83261839 83262839 83263839 83264839 83265839 83268839 83269839 C W6A5 83261849 83262849 83263849 83264849 83265849 83268849 83269849 C W6D8 83261859 83262859 83263859 83264859 83265859 83268859 83269859 C W7A5 83261869 - 83263869 83264869 83265869 83268869 83269869 Note: Function: I = Changeover - R = Normally closed - C = Normally open Connection: W1 = screws - W2 = solder - W3 = for 6.35 mm clips - W3R5 = for Rast 5 connector W6A5 = for 4.8 x 0.5 mm clips - W6D8 = for 4.8 x 0.8 mm clips - W7A5 = for 2.8 x 0.5 mm clips X2 = rear side for PCB - X3 = front side for PCB - X1 = straight for PCB 15 AMERICA BRAZIL Custom Sensors & Technologies Crouzet Latinoamerica Alameda Rio Negro 1084 - cj.A31 CEP 06454-000 - Alphaville SP BRASIL Tel. : +55 (11) 4191 9797 Fax : +55 (11) 4191 9136 E-mail : info@cst-latinoamerica.com www.crouzet.com.br www.cst-latinoamerica.com USA/CANADA/MEXICO Custom Sensors & Technologies - Crouzet 7230 Hollister Avenue Goleta, CA, 93117 USA Tel. : +1 (800) 677 5311 Fax : +1 (800) 677 3865 FRANCE Crouzet Automatismes SAS 2 rue du Docteur Abel - BP 59 26902 Valence CEDEX 9 FRANCE Tel. : +33 (0) 4 75 44 88 44 Fax : +33 (0) 4 75 55 98 03 E-mail : com-fr@crouzet.com www.crouzet.fr Customer service 0 825 333 351 0 810 610 102 GERMANY Crouzet GmbH Otto-Hahn-Str. 3, 40721 Hilden Postfach 203, 40702 Hilden DEUTSCHLAND Tel. : +49 (0) 21 03 9 80-171 Fax : +49 (0) 21 03 9 80-222 E-mail : info-direkt@crouzet.com www.crouzet.de E-mail : customer.service@us.crouzet.com www.crouzet.com OTHER COUNTRIES Custom Sensors & Technologies Crouzet Latinoamerica Alameda Rio Negro 1084 - cj.A31 CEP 06454-000 - Alphaville SP BRASIL Tel. : +55 (11) 4191 9797 Fax : +55 (11) 4191 9136 E-mail : info@cst-latinoamerica.com www.crouzet.com.br www.cst-latinoamerica.com EUROPE MIDDLE EAST AFRICA Headquartered in Moorpark, California-USA, Custom Sensors & Technologies (CST) is made up of the leading brands of Crouzet, Kavlico and Crydom, as well as the former divisions of BEI Technologies, including Newall and Systron Donner. CST provides sensors, controls, and actuation products to the transportation, industrial, and aerospace & defense markets. www.cstsensors.com AUSTRIA Crouzet GmbH Zweigniederlassung Österreich Spengergasse 1/3 1050 Wien ÖSTERREICH Tel. : +43 (0) 1 36 85 471 Fax : +43 (0) 1 36 85 472 ITALY Crouzet Componenti s.r.l. Via Viganò De Vizzi, 93/95 20092 Cinisello Balsamo (Mi) ITALIA Tel. : +39 (02) 66 599 250 Fax : +39 (02) 66 599 258 E-mail : crz-it-sensori-micro@crouzet.com www.crouzet.it SPAIN/PORTUGAL Crouzet Ibérica C/ Aragón 224, 2° 2a 08011 Barcelona ESPAÑA Tel. : +34 (93) 484 39 70 Fax : +34 (93) 484 39 73 E-mail : es-consultas@crouzet.es www.crouzet.es THE NETHERLANDS Crouzet BV Industrieweg 17 2382 NR Zoeterwoude NEDERLAND Tel. : +31 (0) 71-581 20 30 Fax : +31 (0) 71-541 35 74 E-mail : com-nl@crouzet.com www.crouzet.nl E-mail : info-direkt@crouzet.com www.crouzet.at BELGIUM Crouzet NV/SA Dieweg 3 B B - 1180 Uccle BELGIUM Tel. : +32 (0) 2 462 07 30 Fax : +32 (0) 2 461 00 23 E-mail : com-be@crouzet.com www.crouzet.be UNITED KINGDOM Crouzet Ltd 8 Cedarwood Chineham Business Park Crockford Lane Basingstoke, Hampshire RG24 8WD UNITED KINGDOM Tel. : +44 (0)1256 318 900 Fax : +44 (0)1256 318 901 E-mail : info@crouzet.co.uk www.crouzet.co.uk Distributed by: SWITZERLAND Crouzet AG Gewerbepark - Postfach 56 5506 Mägenwil SCHWEIZ Tel. : +41(0) 62 887 30 30 Fax : +41(0) 62 887 30 40 E-mail : info-direkt@crouzet.com www.crouzet.ch Crouzet Automatismes SAS 2 rue du Docteur Abel - BP 59 26902 Valence CEDEX 9 FRANCE www.crouzet.com CRZ BR 42/A EN Ref. 67231008 EN 11/2009 Creation-Design: 3C Evolution, Crouzet Automatismes Editing-Publishing: 3C Evolution Photos-Graphics: Ginko, Daniel Lattard, Schneider Electric Printing: OTHER COUNTRIES Crouzet Automatismes SAS 2 rue du Docteur Abel - BP 59 26902 Valence CEDEX 9 FRANCE Tel. : +33 (0) 475 802 102 Fax : +33 (0) 475 448 126 E-mail : com-ex@crouzet.com www.crouzet.com ASIA PACIFIC CHINA & HONG KONG Custom Sensors & Technologies Asia (Shanghai) Limited Crouzet 2 Floor, Innovation Building No. 1009, Yi Shan Road Shanghai 200233 CHINA Tel. : +86 (21) 2401 7766 Fax : +86 (21) 6249 0701 E-mail : china@cstsensors.com www.crouzet.cn www.cstsensors.com INDIA Custom Sensors & Technologies - Crouzet Prestige Meridian II No. 30, 13th Floor, Unit No: 1301 & 1302 Mahatma Gandhi Road Bangalore 560 001 INDIA Tel. : +91 (0) 80 4113 2204/05 Fax : +91 (0) 80 4113 2206 E-mail : crz_bangalore@crouzet.com www.crouzet.co.in www.cstsensors.com TAIWAN Custom Sensors & Technologies - Crouzet 3F, No. 39, Ji-Hu Road Nei-Hu Dist. - Taipei 114 TAIWAN Tel. : +886 (0)2 8751 6388 Fax : +886 (0)2 2657 8725 E-mail : taiwan@cstsensors.com www.crouzet.tw www.cstsensors.com KOREA & JAPAN Custom Sensors & Technologies - Crouzet 5F, Jeil Bldg. 94-46 Youngdeungpo-dong 7-ga Youngdeungpo-gu Seoul 150-037 SOUTH KOREA Tel. : +82 (0)2 2629 8312 Fax : +82 (0)2 2629 8310 E-mail : korea@cstsensors.com www.crouzet.tw www.cstsensors.com SOUTH EAST ASIA & PACIFIC Custom Sensors & Technologies - Crouzet 3F, No. 39, Ji-Hu Road Nei-Hu Dist. - Taipei 114 TAIWAN Tel. : +886 (0)2 8751 6388 Fax : +886 (0)2 2657 8725 E-mail : eap@cstsensors.com www.crouzet.tw www.cstsensors.com Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. CROUZET Automatismes and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
83264636 价格&库存
很抱歉,暂时无法提供与“83264636”相匹配的价格&库存,您可以联系我们找货
  • 1+ 5.511 1+ 0
  • 100+ 4.587 100+ 0
  • 1000+ 4.235 1000+ 0
  • 2000+ 4.037 2000+ 0
  • 4000+ 3.85 4000+ 0
库存:1631
  • 1+ 36.63 1+ 0
库存:641
    • 1+ 3.1218 1+ 0
    库存:1877
      • 1+ 6.4239 1+ 0
      库存:1352
        • 1+ 9.016 1+ 0
        库存:708
          • 1+ 10.8244 1+ 0
          库存:130
            • 1+ 11.5685 1+ 0
            库存:127
              • 1+ 11.8387 1+ 0
              库存:541
                • 1+ 25.3888 1+ 0
                库存:864
                  • 1+ 26.6899 1+ 0
                  库存:565
                    • 1+ 56.35 1+ 0
                    库存:435
                      • 1+ 278.1346 1+ 0
                      库存:973
                        • 1+ 8.478 1+ 1.0798
                        • 10+ 6.2856 10+ 0.8006
                        • 100+ 4.2098 100+ 0.5362
                        • 500+ 3.3002 500+ 0.4203
                        • 1000+ 2.997 1000+ 0.3817
                        • 3000+ 2.6005 3000+ 0.3312
                        • 6000+ 2.414 6000+ 0.3074
                        库存:4650
                          • 1+ 8.8162 1+ 1.1229
                          • 10+ 7.2069 10+ 0.9179
                          • 100+ 5.6209 100+ 0.7159
                          • 500+ 4.7579 500+ 0.606
                          • 1000+ 3.8833 1000+ 0.4946
                          • 2000+ 3.7784 2000+ 0.4812
                          • 4000+ 3.4285 4000+ 0.4367
                          • 8000+ 3.3002 8000+ 0.4203
                          库存:4548
                            • 1+ 12.4313 1+ 1.5833
                            • 10+ 8.0232 10+ 1.0219
                            • 100+ 5.5976 100+ 0.7129
                            • 500+ 4.4081 500+ 0.5614
                            • 1000+ 3.825 1000+ 0.4872
                            • 2000+ 3.6151 2000+ 0.4604
                            • 5000+ 3.3469 5000+ 0.4263
                            库存:3647
                              • 1+ 69.5018 1+ 8.8519
                              • 10+ 46.5705 10+ 5.9314
                              • 25+ 40.5905 25+ 5.1697
                              • 100+ 33.8295 100+ 4.3086
                              • 250+ 30.4856 250+ 3.8827
                              • 500+ 29.2652 500+ 3.7273
                              库存:735
                                • 500+ 29.3506 500+ 3.7382
                                • 2500+ 29.2652 2500+ 3.7273
                                库存:2550
                                • 1+ 291.0654 1+ 37.0709
                                库存:1057
                                • 1+ 410.8382 1+ 52.3255
                                • 10+ 410.7449 10+ 52.3137
                                • 25+ 410.6632 25+ 52.3033
                                • 100+ 381.0311 100+ 48.5292
                                • 250+ 376.658 250+ 47.9723
                                库存:158
                                • 1+ 1471.624 1+ 187.4303
                                • 10+ 1353.9118 10+ 172.4382
                                • 25+ 1353.7485 25+ 172.4174
                                • 50+ 1353.3287 50+ 172.3639
                                库存:80
                                • 1+ 1503.0286 1+ 191.4301
                                • 10+ 1325.2009 10+ 168.7815
                                库存:100
                                  • 750+ 1.8163 750+ 0
                                  • 1500+ 1.3161 1500+ 0
                                  • 7500+ 1.1846 7500+ 0
                                  库存:4862
                                    • 10+ 2.6626 10+ 0
                                    • 200+ 1.9913 200+ 0
                                    • 800+ 1.5439 800+ 0
                                    • 3000+ 1.1187 3000+ 0
                                    • 6000+ 1.0628 6000+ 0
                                    • 30000+ 0.9845 30000+ 0
                                    库存:1819
                                    • 10+ 3.4819 10+ 0
                                    • 200+ 2.6041 200+ 0
                                    • 500+ 2.0189 500+ 0
                                    • 1500+ 1.463 1500+ 0
                                    • 3000+ 1.3899 3000+ 0
                                    • 15000+ 1.2874 15000+ 0
                                    库存:6128
                                    • 10+ 3.6652 10+ 0
                                    • 200+ 2.7412 200+ 0
                                    • 500+ 2.1252 500+ 0
                                    • 1500+ 1.54 1500+ 0
                                    • 3000+ 1.463 3000+ 0
                                    • 15000+ 1.3552 15000+ 0
                                    库存:24213
                                    • 10+ 4.0317 10+ 0
                                    • 200+ 3.0153 200+ 0
                                    • 500+ 2.3377 500+ 0
                                    • 1500+ 1.694 1500+ 0
                                    • 3000+ 1.6093 3000+ 0
                                    • 15000+ 1.4907 15000+ 0
                                    库存:11042
                                    • 10+ 36.652 10+ 0
                                    • 200+ 27.412 200+ 0
                                    • 500+ 21.252 500+ 0
                                    • 1500+ 15.4 1500+ 0
                                    • 3000+ 14.63 3000+ 0
                                    • 15000+ 13.552 15000+ 0
                                    库存:1162
                                    • 10+ 36.652 10+ 0
                                    库存:86
                                    • 10+ 183.26 10+ 0
                                    • 200+ 137.06 200+ 0
                                    • 500+ 106.26 500+ 0
                                    • 1500+ 77 1500+ 0
                                    • 3000+ 73.15 3000+ 0
                                    • 15000+ 67.76 15000+ 0
                                    库存:649
                                    • 10+ 183.26 10+ 0
                                    • 1500+ 77 1500+ 0
                                    库存:474
                                    • 1+ 292.1907 1+ 0
                                    • 10+ 255.2045 10+ 0
                                    • 100+ 218.2183 100+ 0
                                    • 1000+ 184.9308 1000+ 0
                                    库存:635
                                    • 100+ 2.3429 100+ 0
                                    • 200+ 2.21713 200+ 0
                                    库存:1163
                                      • 10+ 2.59204 10+ 0
                                      库存:1534
                                      • 10+ 4.39832 10+ 0
                                      • 40+ 3.0496 40+ 0
                                      • 110+ 2.8831 110+ 0
                                      库存:2142
                                        • 1+ 4.0824 1+ 0
                                        • 10+ 3.6288 10+ 0
                                        • 30+ 3.402 30+ 0
                                        • 100+ 3.0564 100+ 0
                                        • 500+ 2.9268 500+ 0
                                        • 1000+ 2.862 1000+ 0
                                        库存:1888
                                        • 1+ 4.9788 1+ 0
                                        • 10+ 4.4928 10+ 0
                                        • 30+ 4.2228 30+ 0
                                        • 100+ 3.9312 100+ 0
                                        • 500+ 3.7908 500+ 0
                                        • 1000+ 3.726 1000+ 0
                                        库存:1124
                                          • 1+ 287.496 1+ 0
                                          • 30+ 273.24 30+ 0
                                          库存:787
