6412
6412
    SENSATA(森萨塔)
    AC OUTPUT MODULE 3.5A
6412 数据手册
AC Output Buffered Modules • Compatible with 5 & 15 Volt Logic Systems • Buffered Inverting and Non-Inverting Modules • Zero Voltage AC Switching INPUT SPECIFICATIONS Buffered output modules contain additional internal amplification to reduce drive requirements to a level suitable for the MOS devices used in many microprocessor systems. To further reduce the need for additional interface components, they are available with both inverting and non-inverting inputs, for 5 volt or 15 volt logic. 6411 6421 6412 6422 Nominal Input Voltage [Vdc] Output Module Type Must Turn On Voltage Range @ pin 4 [Vdc] 5 Non-Inverting 0.0 - 0.8 5 Inverting 2.4 - 6.0 5 Non-Inverting 0.0 - 0.8 5 Inverting 2.4 - 6.0 Must Turn Off Voltage Range @ pin 4 [Vdc] Max. Input On-Current (Sink) @ pin 4 [µA] 2.4 - 6.0 75 @ 0.8V 100 @ 0.0V — — 10 3.5 - 6.0 20 15 0.0 - 0.8 — — 75 @ 2.4V 250 @ 6.0V 10 3.5 - 6.0 20 15 2.4 - 6.0 75 @ 0.8V 100 @ 0.0V — — 10 3.5 - 6.0 20 15 0.0 - 0.8 — — 75 @ 2.4V 250 @ 6.0V 10 3.5 - 6.0 20 15 6441 6451 6442 6452 15 Non-Inverting 0.0 - 2.0 8.0 - 18 175 @ 2.0V 250 @ 0.0V — — 10 10 - 18 25 22 15 Inverting 8.0 - 18 0.0 - 2.0 — — 75 @ 8.0V 200 @ 18V 10 10 - 18 25 22 15 Non-Inverting 0.0 - 2.0 8.0 - 18 175 @ 2.0V 250 @ 0.0V — — 10 10 -18 25 22 15 Inverting 8.0 - 18 0.0 - 2.0 — — 75 @ 8.0V 200 @ 18V 10 10 -18 25 22 0.02 - 3.5 12 - 140 80 1.5 5.0 1/2 Cycle 1/2 Cycle 400 0.02 - 3.5 12 - 140 80 1.5 5.0 1/2 Cycle 1/2 Cycle 400 0.02 - 3.5 24 - 280 80 1.5 5.0 1/2 Cycle 1/2 Cycle 600 0.02 - 3.5 24 - 280 80 1.5 5.0 1/2 Cycle 1/2 Cycle 600 (All voltages referenced to pin 5) Max. Input On-Current (Source) @ pin 4 [µA] Max. Output Off-State Input Current @ pin 4 [µA] ➁ Logic Supply Voltage Range [Vdc] Max. Logic Supply Current @ 5Vdc (w/o LED) [mA] ➀ Max. Logic Supply Current @ 5Vdc (w/ LED) [mA] ➀ Nominal Input Voltage [Vdc] Output Module Type Must Turn On Voltage Range @ pin 4 [Vdc] Must Turn Off Voltage Range @ pin 4 [Vdc] Max. Input On-Current (Sink) @ pin 4 [µA] Max. Input On-Current (Source) @ pin 4 [µA] Max. Input Current for Output Off-State @ pin 4 [µA] ➁ Logic Supply Voltage Range [Vdc] Max. Logic Supply Current @ 5Vdc (w/o LED) [mA] ➀ Max. Logic Supply Current @ 5Vdc (w/ LED) [mA] ➀ OUTPUT SPECIFICATIONS Load Current Range @ 45˚ C [A] Load Voltage Range [Vdc] Max. Surge Current 1 Cycle (Non-Rep) [Apk] Max. On-State Voltage [Vdc] Max. Off-State Leakage [mA] Max. Turn On Time Max. Turn Off Time Transient Overvoltage [Vpk] GENERAL NOTES ➀ LED optional. Placed in series with pin 3 for status indication. ➁ Max. allowable leakage current from driver maintain output off-state. FastFax Document No. 308 081398, PAGE 1 OF 2 ©1998 CRYDOM CORP Specifications subject to change without notice. For recommended applications and more information contact: USA: (800) 8 CRYDOM • (800) 827-9366 • (619) 715-7200 • fax (619) 715-7280 Crydom Corp, 9525 Chesapeake Drive, San Diego, CA 92123 • e-mail: sales@crydom.com WEB SITE: http://www.crydom.com FASTFAX Product Information: (888) 267-9191 UK: (44)1202 812300 • fax (44)1202 812340 Crydom International Ltd., 85, Condor Close, Woolsbridge Industrial Estate, Three-Legged Cross. Wimborne, Dorset, England BH21 6SU GERMANY: (49) (0)6874 182580 • fax (49)(0)6874 182585 Crydom GmbH, Gewerbegebiet Im Schachen, D-66687 Nunkirchen, Germany • e-mail: vertrieb@crydom.com 9002 AC Output Buffered Modules GENERAL SPECIFICATIONS Min. Dielectric Input/Output (1 Minute) 4,000 VRMS Min. Isolation Resistance Input/Output (@ 500V) 1010 Ohms Capacitance input to output 8 pF Temperature Range — Operating -40˚ C to 80˚ C Temperature Range — Storage -40˚ C to 125˚ C C U R R E N T D E R AT I N G C U RV E WIRING & MECHANICAL DIAGRAMS LOAD CURRENT (AMPS) 3.5 DC LOGIC SUPPLY STATUS LED ① AC OUTPUT 3 1 (+) LOAD 3.0 DC LOGIC INPUT 2.5 INV or NON-INV LOGIC 4 Zero Switch ~ 2.0 2 5 COM (-) 1.5 1.0 BOTTOM VIEW 0 20 40 60 80 .30 (7.6) AMBIENT TEMPERATURE (ºC) Max. Load Current vs. Temp. CAPTIVE #4-40. PHILLIPS HEAD HOLD DOWN SCREW BUFFERED OUTPUT MODULES A buffered non-inverting module turns on when pin 4 is held in the low state (logic 0), the same as standard modules driven in the sink mode. A buffered inverting module conversely turns on when pin 4 is held high (logic 1). In the absence of an input signal and/or logic supply (open Circuit), all models will be in the off-state. Buffered modules may be used with standard 5 pin PB or MS mounting boards. However, the 3.3K pull-up resistor will add to the logic drive current of a non-inverting module and may be removed. For an inverting module, the resistor must be removed to avoid a false “on” command, unless a “normally closed” condition is desirable for use with a ground seeking (logic 0) signal source. 1.70 (43.1) .60 (15.2) .100 (2.5) 1.00 (25.4) 1.25 (31.7) .25 (6.3) 5 4 3 2 1 .30 (7.6) .040 (1.0) DIA. (5 PLACES) .70 (17.8) 1.20 (30.5) 1.40 (35.5) 1.60 (40.6) All dimensions are in inches (millimeters) ©1998 CRYDOM CORP Specifications subject to change without notice. FastFax Document No. 308 081398, PAGE 2 OF 2 For recommended applications and more information contact: USA: (800) 8 CRYDOM • (800) 827-9366 • (619) 715-7200 • fax (619) 715-7280 Crydom Corp, 9525 Chesapeake Drive, San Diego, CA 92123 • e-mail: sales@crydom.com WEB SITE: http://www.crydom.com FASTFAX Product Information: (888) 267-9191 UK: (44)1202 812300 • fax (44)1202 812340 Crydom International Ltd., 85, Condor Close, Woolsbridge Industrial Estate, Three-Legged Cross. Wimborne, Dorset, England BH21 6SU GERMANY: (49) (0)6874 182580 • fax (49)(0)6874 182585 Crydom GmbH, Gewerbegebiet Im Schachen, D-66687 Nunkirchen, Germany • e-mail: vertrieb@crydom.com 9002
很抱歉,暂时无法提供与“6412”相匹配的价格&库存,您可以联系我们找货
  • 2+642.23777
  • 8+615.45620
  • 15+590.79056
  • 72+567.28565
库存:91
