PM2260D95VRH
PM2260D95VRH
    SENSATA(森萨塔)
    Module
    RELAY SSR 600V 95A PNL MNT
PM2260D95VRH 数据手册
Panel Mount DataSheet PM22 Series Panel Mount SSRs • Output ratings up to 95 Amps at 600VAC • Built-in overvoltage protection • DBC substrate for superior thermal performance • LED input status indicator • IP20 touch-safe housing • AC or DC control • 4000 VAC optical isolation • C-UL-US and TUV approved PRODUCT SELECTION Control Voltage 90-280 VAC/VDC 4-32 VDC 25A 50A 95A PM2260A25V PM2260D25V PM2260A50V PM2260D50V PM2260A95V PM2260D95V AVAILABLE OPTIONS Series PM22 Required for valid part number For options only and not required for valid part number Operating Voltage 60: 48-600 VAC 60 A Rated Load Current 25: 25 Amps 50: 50 Amps 95: 95 Amps [High I2t] 25 Control Voltage (1) A: 90-280 VAC/VDC D: 4-32 VDC U V Switching Type Blank: Zero Voltage Turn-On Thermal Pad R: Instantaneous Turn-On Blank: Not Included (Motor Rating Certified) H: Included R H U J Terminal Layout Input Connector V: Contactor Configuration Blank: Screw Terminal J: Spring Terminal OUTPUT SPECIFICATIONS (2) Description Operating Voltage (47-440Hz) [VRMS] Transient Overvoltage [Vpk] (3) Maximum Off-State Leakage Current @ Rated Voltage [mARMS] Minimum Off-State dV/dt @ Maximum Rated Voltage [V/μsec] Load Current, General Use UL508/LC A IEC 62314 @ 40°C [ARMS] (4) Load Current, Motor Starting UL508 FLA/LC B IEC 62314 @ 40°C [ARMS] (4) Minimum Load Current [mARMS] Maximum 1 Cycle Surge Current (50/60Hz) [Apk] Maximum On-State Voltage Drop @ Rated Current [Vpk] Thermal Resistance Juntion to Case (Rjc) [°C/W] Maximum 1/2 Cycle I² t for Fusing (50/60Hz) [A² sec] Minimum Heat Sink for Rated Current @ 40ºC [°C/W] Minimum Power Factor (at Maximum Load) Motor Rating UL 508/IEC62314 [HP (kW)]: 120 VAC Motor Rating UL 508/IEC62314 [HP (kW)]: 240 VAC Motor Rating UL 508/IEC62314 [HP (kW)]: 480 VAC 25A 50A 95A 48-600 1200 1 500 25 8.5/4.8 100 286/300 1.35 0.49 409/375 2 0.5 0.5 (0.37) 1.5 (1.1) 3 (2.24) 48-600 1200 1 500 50 14/7.6 100 716/750 1.35 0.27 2563/2343 0.7 0.5 1 (0.74) 3 (2.2) 5 (3.7) 48-600 1200 1 500 95 26/14 150 1290/1350 1.30 0.2 8320/7593 0.23 0.5 2 (1.5) 5 (3.73) 10 (7.4) INPUT SPECIFICATIONS (2) Description Control Voltage Range Maximum Reverse Voltage Minimum Turn-On Voltage Must Turn-Off Voltage Minimum Input Current (for on-state) Maximum Input Current Nominal Input Impedance Maximum Turn-On Time [msec] Maximum Turn-Off Time [msec] Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. PM2260DxxV 4-32 VDC (5) -32 VDC 4 VDC 1 VDC 10 mA 15 mA Current Limited 1/2 Cycle (7) 1/2 Cycle PM2260AxxV 90-280 VAC/VDC (6) 90 VAC/VDC 5 VAC/VDC 6 mA 10 mA Current Limited 20 30 Panel Mount DataSheet GENERAL SPECIFICATIONS (2) Description Parameters Dielectric Strength, Input to Output (50/60Hz) Dielectric Strength, Input/Output to Baseplate (50/60Hz) Minimum Insulation Resistance (@ 500 VDC) Maximum Capacitance, Input/Output Ambient Operating Temperature Range (8) Ambient Storage Temperature Range Short Circuit Current Rating (9) Weight (typical) Housing Material Baseplate Material Hardware Finish Input Terminal Screw Torque Range (in-lb/Nm) Load Terminal Screw Torque Range (in-lb/Nm) SSR Mounting Screw Torque Range (in-lb/Nm) Humidity LED Input Status Indicator 4000 VRMS 4000 VRMS 109 Ohms 8 pF -40 to 80 °C -40 to 100 °C 100kA 2.3 oz (65 g) UL94 V-0 Aluminum Nickel Plating 5/0.5 (10) 18-20/2-2.2 20-25/2.2-2.8 85% non-condensing Green INPUT CURRENT INFORMATION 90-280 VAC/VDC Input 7 12 6 Input Current (mA) Input Current (mA) 4-32 VDC Input 14 10 8 6 4 2 0 5 4 3 2 1 0 5 10 15 20 25 30 0 35 0 Input Voltage (VDC) 40 80 120 160 200 240 280 Input Voltage (VAC/VDC) SURGE CURRENT INFORMATION PM2260x50V Surge Current (Amp) AC Peak Surge Current (Amp) AC Peak PM2260x25V 300 250 200 150 100 50 0 0.01 0.1 1 700 600 500 400 300 200 100 0 0.01 10 Surge Duration (sec) Surge Current (Amp) AC Peak PM2260x95V 1200 1000 Single Pulse (11) 800 600 400 200 0.01 0.1 1 Surge Duration (sec) 1400 0 0.1 1 10 Surge Duration (sec) Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. 10 Panel Mount DataSheet THERMAL DERATE INFORMATION (8) 2.5ºC/W 0.7ºC/W 5ºC/W 0.25ºC/W 2.5ºC/W 1ºC/W 15 10 5 20 30 40 50 60 Ambient Temperature (ºC) 70 40 30 20 10 0 80 Load Current (Amps) 20 20 30 40 50 60 Ambient Temperature (ºC) 70 EQUIVALENT CIRCUIT BLOCK DIAGRAMS/WIRING DIAGRAM DC Control +3/A1 DC V - OUTPUT 1/L1 INPUT + Trigger Circuit 2/T1 -4/A2 Current Limiter Load A V AC B Load Load can be wired in position A or B AC/DC Control Current Limiter +3/A1 V AC/DC Converter Trigger Circuit -4/A2 OUTPUT INPUT -/ 1/L1 Load A +/ AC/DC 2/T1 V AC B Load Load can be wired in position A or B Recommended Wire Sizes Terminal Configuration Output Screw Input Spring Wire Size (Solid / Stranded) 0.5ºC/W 0.36ºC/W 2.5ºC/W 100 50 Load Current (Amps) Load Current (Amps) 25 0 PM2260x95V PM2260x50V PM22xxx25x 2ºC/W Wire Pull-Out Strength (lb)[N] 20 AWG (0.5 mm2) [minimum] 25 [111] 2 x 10 AWG (5.3 mm2) 110 [490] 2 x 8 AWG (8.4 mm2) [maximum] 90 [400] 30 AWG (0.2 mm2) [minimum] 4.5 [20] 12 AWG (2.5 mm2) [maximum] 55 [245] 26 AWG (0.2 mm2) [minimum] 5 [22] 12 AWG (2.5 mm2) [maximum] 20 [89] Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. 80 80 60 40 20 0 20 30 40 50 60 Ambient Temperature (ºC) 70 80 Panel Mount DataSheet MECHANICAL SPECIFICATIONS Tolerances: ±0.02 in / 0.5 mm All dimensions are in: inches [millimeters] 1.87 [47.5] Input Connector 1/L1 2.85 [72.3] +3/A1 1.88 [47.8] -4/A2 Screw Terminal 3.62 [91.9] Spring Terminal 2/T1 1.19 [30.2] 0.89 [22.5] ACCESSORIES New Accessories! Recommended Accessories Connectors Part number: CP201, CP202 Connectors ID Marker Hardware Kit Heat Sink Part No. Thermal Resistance Thermal Pad [ºC/W] CP201 CNLB HK8 HS501DR 5.0 CP202 CNLN HS301 / HS301DR 3.0 CNL2 HS251 2.5 HS259DR 2.5 HS202 / HS202DR 2.0 HS201 / HS201DR 2.0 HS172 1.7 HS151 / HS151DR 1.5 HS122 / HS122DR 1.2 HS103 / HS103DR 1.0 HS101 1.0 HS073 0.7 HS072 0.7 HS053 0.5 HS033 0.36 HS023 0.25 Pluggable input connectors, 2 position, with screw terminals (CP201) or spring type terminals (CP202). Compatible with Contactor configuration NOVA22 SSRs. HSP-7 Hardware Kit Part number: HK8 Bag with 2 SSR mounting screws 8-32 x 3/8, Hex Socket Cap, compatible with PM22 Series Panel Mount SSRs. Used to mount the SSR onto any of our compatible heat sinks. Heat Sink Part number: HS259DR DIN Rail mountable heat sink with 2.5°C/W thermal resistance. Heat sink material is aluminum with black anodized finish. Suitable for mounting a single PM22 Series Panel Mount SSRs. Lug Terminal Part number: TRM0 Copper wire lug for AWG 6 (13.3 mm2) to AWG 0 (53.5 mm2) wire size. For use with “Elevator” screw option (”W” suffix) NOVA22 SSRs. Thermal Pad Part number: HSP-7 Non-adhesive thermal pad for half-puck package SSRs. Compatible with PM22 Series Panel Mount SSRs. Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. Panel Mount DataSheet AGENCY APPROVALS Certification in accordance with: United States Standard for Industrial Control Equipment - UL 508 and Canadian Standard Association for Industrial Control Equipment – C22.2 No. 14. TUV Certified in accordance to EN62314 Electromagnetic Compatibility: IEC 61000-4-2 : Electrostatic Discharge – Level 3 IEC 61000-4-4 : Electrically Fast Transients – Level 3 IEC 61000-4-5 : Electrical Surges – Level 3 Vibration Resistance: IEC 60068-2-6: Amplitude Range 10-55 Hz, Displacement 0.75mm Shock Resistance: IEC 60068-2-27: Peak Acceleration 15g, Duration11ms. E116949 NOVA22 series has Environmental Product declarations type III conforming to ISO 14025. GENERAL NOTES (1) Control voltage 18-52 VAC/VDC is available upon request. (2) All parameters at 25°C unless otherwise specified. (3) Output will self trigger between 900-1200 Vpk, not suitable for capacitive loads. (4) Heat sinking required, see derating curves. (5) Increase minimum voltage by 1 V for operations from -20 to -40°C. (6) For ambient temperatures above 40°C the maximum control voltage must not exceed 250 VAC/VDC. (7) Turn-on time for Instantaneous turn-on versions is 0.1 msec. (8) AC input models operating range is -20 to 60°C. (9) When protected with the appropriate class and rated fuse. For detailed info please contact Crydom Technical Support. (10) Input torque to screw terminals Connector. (11) For single surge pulse Tc=25°C; Tj=125°C. For AC Output SSRs, AC RMS value of surge current equals the peak value divided by √2 (1.414). Rev. 100715 Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. Panel Mount DataSheet DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险 HAZARD OF ELECTRIC SHOCK, EXPLOSION, OR ARC FLASH. • Disconnect all power before installing or working with this equipment. • Verify all connections and replace all covers before turning on power. Failure to follow these instructions will result in death or serious injury. RIESGO DE DESCARGA ELECTRICA O EXPLOSION. • Desconectar todos los suministros de energia a este equipo antes de trabajar con este equipo. • Verificar todas las conexiones y colocar todas las tapas antes de energizer el equipo. El incumplimiento de estas instrucciones puede provocar la muerte o lesiones serias. RISQUE DE DESCHARGE ELECTRIQUE OU EXPLOSION • Eteindre toutes les sources d'énergie de cet appareil avant de travailler dessus de cet appareil • Vérifier tous connections, et remettre tous couverts en olace avant de mettre sous De non-suivi de ces instructions provoquera la mort ou des lésions sérieuses sérieuses. GEFAHR EINES ELEKTRISCHE N SCHLAGES ODER EINER EXPLOSION. • Stellen Sie jeglichen Strom ab, der dieses Gerät versorgt, bevor Sie an dem Gerät Arbeiten durchführen • Vor dem Drehen auf Energie alle Anschlüsse überprüfen und alle Abdeckungen ersetzen. Unterlassung dieser Anweisungen können zum Tode oder zu schweren Verletzungen führen. RISCHIO DI SCOSSA ELETTRICA O DELL’ESPLOSIONE. • Spenga tutta l'alimentazione che fornisce questa apparecchiatura prima di lavorare a questa apparecchiatura 存在电击、 爆炸或电弧 闪烁危险 • 在操作此设 备之前请先 关闭电源。 若不遵守这些说明, 可能会导致严重的 人身伤害甚至死亡。 • Verificare tutti i collegamenti e sostituire tutte le coperture prima dell’accensione L'omissione di queste istruzioni provocherà la morte o lesioni serie WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告 RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE RISQUE DE DOMMAGE MATERIEL ET DE SURCHAUFFE DU BOITIER GEFAHR VON MATERIALSCHÄDEN UND GEHÄUSEERHITZUNG • The product's side panels may be hot, allow the product to cool before touching. • Follow proper mounting instructions including torque values. • Do not allow liquids or foreign objects to enter this product. • Les panneaux latéraux du produit peuvent être chauds. Laisser le produit refroidir avant de le toucher. • Respecter les consignes de montage, et notamment les couples de serrage. • Ne pas laisser pénétrer de liquide ni de corps étrangers à l'intérieur du produit. • Die Seitenwände können heiß sein. Lassen Sie das Produkt abkühlen, bevor Sie es berühren. • Beachten Sie die Montageanweisungen, • Führen Sie keine Flüssigkeiten oder Fremdkörper in das Produkt ein. Le non-respect de cette directive peut entraîner, Failure to follow these instructions can result in des lésions corporelles graves ou des serious injury, or equipment damage. dommages matériels. Die Nichtbeachtung dieser Anweisung kann Körperverletzung oder Materialschäden zur Folge haben. RIESGO DE DAÑOS MATERIALES Y DE SOBRECALENTAMIENTO DE LA UNIDAD RISCHIO DI DANNI MATERIALI E D'INVOLUCRO CALDO 材料损坏和高温外壳的危险性 • Los paneles laterales del producto pueden estar calientes. Esperar que el producto se enfríe antes de tocarlo. • Respetar las instrucciones de montaje, y en particular los pares de apretado. • No dejar que penetren líquidos o cuerpos extraños en el producto. • I pannelli laterali dell'apparecchio possono scottare; lasciar quindi raffreddare il prodotto prima di toccarlo. • Seguire le istruzioni di montaggio corrette. • Non far entrare liquidi o oggetti estranei in questo apparecchio. Si no se respetan estas precauciones pueden producirse graves lesiones, daños materiales. La mancata osservanza di questa precauzione può causare gravi rischi per l'incolumità personale o danni alle apparecchiature. Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. • 产品的一侧面板可能很热,在其冷却前请 不要触碰。 • 遵照正确的安装说明,包括扭矩值。 • 请勿让液体及其他异物进入本产品。 如不能正确执行这些操作说明, 极有可能造成严重人体伤害或者设备的损坏。 Panel Mount DataSheet ANNEX - ENVIROMENTAL INFORMATION The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products. Part Name Toxic or hazardous Substance and Elements Lead (Pb) Mercury (Hg) Cadmium (Cd) Hexavalent Chromium (Cr (VI)) Polybrominated biphenyls (PBB) Polybrominated diphenyl ethers (PBDE) Semiconductor die Solder 附件 - 环保信息 此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006, 电子信息产品污染控制标识要求。 部件 名称 铅 汞 镉 有毒有害物质或元素 六价铬 多溴联苯 (Pb) (Hg) (Cd) (Cr (VI)) 半导体芯片 焊接点 50 Do not forget to visit us at: www.crydom.com Copyright © 2015 Crydom Inc. Specifications subject to change without notice. (PBB) 多溴二苯醚 (PBDE)
PM2260D95VRH
物料型号:PM22系列,包括不同控制电压和负载电流等级的型号,例如PM2260A25V、PM2260A50V、PM2260A95V等。
器件简介:PM22系列是面板安装型固态继电器,具有高达95安培的输出额定值,内置过电压保护,使用DBC基板以获得优越的热性能,LED输入状态指示器,IP20防触电外壳,交流或直流控制,以及4000伏交流光电隔离。
引脚分配:文档提供了详细的输入连接器和输出端子布局,包括接触器配置和弹簧端子选项。
参数特性:包括操作电压、瞬态过电压、最大关断状态漏电流、最小关断状态dV/dt、负载电流、最小负载电流、最大单周期浪涌电流、最大导通状态下的电压降、热阻、最大1/2周期I2t用于熔断、最小散热器、最小功率因数和电机额定值。
功能详解:文档详细描述了SSR的工作原理,包括触发电路、电流限制器、AC/DC控制选项。
应用信息:适用于需要高负载电流和高电压隔离的应用场合。
封装信息:提供了机械规格、公差、输入连接器、螺丝端子、弹簧端子的尺寸和推荐配件。
PM2260D95VRH 价格&库存
很抱歉,暂时无法提供与“PM2260D95VRH”相匹配的价格&库存,您可以联系我们找货
