FIT0016
FIT0016
    DFROBOT
    MICRO DC GEARED MOTOR W/ BACK SH
FIT0016 数据手册
    TT Geared Motor with Back Shaft (180rpm 6v L Shape) SKU: FIT0016 Brand: DFRobot INTRODUCTION This is a TT Micro DC Geared Motor with Back Shaft working at 6V with 180rpm. The TT motor series the most popular DC motors for DIY enthusiasts. It is designed to easily incorporate the DFRobot Encoder. These motors are inexpensive, small, easy to install, and ideally suited for use in a mobile robot. The DFRobot ROMEO microcontroller is able to complete the closed-loop PID making use of the optional encoders. We recommend this rubber wheel for this motor. SPECIFICATION Electrical Characteristics:       Operating Voltage Range: 3~7.5V Rated Voltage: 6V Max. No-load Current(3V): 140 mA Max. No-load Current(6V): 170 mA No-load Speed(3V): 90 rpm No-load Speed(6V): 160 rpm   Max. Output Torque: 0.8 kgf.cm Max. Stall Current: 2.8 A Operating Conditions:     Rated Load: 0.2 kgf.cm Operating Temperature: -10~+60 Ԩ Storage Temperature: -30~+85 Ԩ Motor Type: 130 Mechanical Characteristics:     Output Mode: 2 sides Gear Ratio: 1:120 Max. Diameter of Output Axle: 5.4 mm Net Weight: 45 g SHIPPING LIST  Micro DC Geared Motor with Back Shaft x1 Powered By DFRobot © 2008-2016
FIT0016 价格&库存
很抱歉,暂时无法提供与“FIT0016”相匹配的价格&库存,您可以联系我们找货
FIT0016
  • 1+34.894061+4.52000
  • 3+30.794003+3.98890
库存:49
