FIT0094
FIT0094
    DFROBOT
    MICRO METAL GEARMOTOR 50:1
FIT0094 数据手册
  Micro Metal Gearmotor 50:1 SKU:FIT0094 INTRODUCTION This motor has a long (0.365" or 9.27 mm), D-shaped metal output shaft that matches the Pololu wheel 42x19mm and 32x7mm. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6 mm diameter, 0.35 mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gearmotor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the wheel 42×19 mm. SPECIFICATION       Motor speed (No gearbox):13000 rpm Gear ratio: 50:1 Motor speed (with gearbox): 260 rpm Rated current: 30mA @ 6V Stall current: 350mA @ 6V Stall torque: 0.39kg*cm @ 6V SHIPPING LIST  Micro Metal Gearmotor x1 https://www.dfrobot.com/product-354.html 5-30-17
FIT0094 价格&库存
很抱歉,暂时无法提供与“FIT0094”相匹配的价格&库存,您可以联系我们找货
FIT0094
  • 1+124.377481+16.06860
  • 3+109.770563+14.18150
库存:5
