FIT0302
FIT0302
    DFROBOT
    GEARMOTOR 500 RPM 6V MICRO METAL
FIT0302 数据手册
      Micro Metal Gearmotor 30:1 SKU:FIT0302 INTRODUCTION This motor has a long (0.365" or 9.27 mm), D-shaped metal output shaft that matches the Pololu wheel 42x19mm and 32x7mm. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6 mm diameter, 0.35 mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gearmotor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the wheel 42×19 mm. This motor is suitable to be used in the mini mobile platform. As the 2 wheels miniQ platform, it can directly work with the MiniQ Robot chassis Encoder, mounting bracket and directly compatible wheels. SPECIFICATION        Working voltage: 3 or 6 volts 15000 rpm @6v No load 30:1 Gear ratio 500rpm @ 6V No load 40mA @ 6V 100mA stall current @ 6V Torque:1.2Kg*cm @ 6V https://www.dfrobot.com/product-874.html 5-30-17
FIT0302 价格&库存
很抱歉,暂时无法提供与“FIT0302”相匹配的价格&库存,您可以联系我们找货
FIT0302
  • 1+82.144361+10.67850
  • 3+72.495653+9.42420
库存:21
