Micro Metal DC Geared Motor with Lead Screw (6V 150RPM M4*55)
SKU:FIT0491
INTRODUCTION
This DC gearmotor has an integrated M4*55mm threaded rod as its output shaft, turn it into a linear actuator. 6V rated voltage,
the no-load speed could arrive 150RPM, equivalent to 1.75mm/s. The brass faceplate has two mounting holes threaded for M1.6
screws (1.6mm diameter, 0.35mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are
specifically designed to securely mount the gear motor while enclosing the exposed gears.
Romeo BLE with Motors connection
SPECIFICATION
Reduction Ratio: 100:1
Rated voltage: 6.0 V
No-load speed: 150 RPM
Rated load speed: 120 RPM
Rated Torque: 0.3 kg.cm
Rated Current: 160 mA
Stall Torque: 2.4 kg.cm
Stall Current: 200 mA
Weight: 16 g
SHIPPING LIST
Micro Metal DC Geared Motor with Lead Screw (6V 150RPM M4*55) x1
https://www.dfrobot.com/product-1479.html 5-30-17
很抱歉,暂时无法提供与“FIT0491”相匹配的价格&库存,您可以联系我们找货
