ROB0034
ROB0034
    DFROBOT
    BASE ROTATE KIT W/HS-422 SERVO
ROB0034 数据手册
Base Rotate Kit with HS-422 servo SKU:ROB0034 Brand:Lynxmotion  INTRODUCTION The Base Rotate Kit is perfect for rotating a large mass. It can easily support 10lbs of weight. It has five 6mm bearings to reduce the friction. It's injection molded from ultra strong ABS plastic. It fits the HS-422, HS-475, HS-485, and HS-645 servos. Other have not been tested. The kit comes without assembly. SPECIFICATION    Top diameter = 3.688" Bottom diameter = 3.875" Height = 1.875"   SHIPPING LIST   Base Unit x1 Hitec HS422 Servo x1     Powered By DFRobot © 2008-2016
ROB0034 价格&库存
很抱歉,暂时无法提供与“ROB0034”相匹配的价格&库存,您可以联系我们找货
