EBM6CH177H
EBM6CH177H
    MENDA
    CHISEL 30 1.5MM 600 POWER PLUS
EBM6CH177H 数据手册
EBM6CH177H Datasheet Technical Specifications EBM6CH177H Chisel 30° 1.5mm (0.06"), Power Plus Tip Style: Chisel 30° Tip Width: 1.50mm (0.06") Tip Length: 10.40mm (0.41") 600 Type Cartridge1 : RoHS Compliant2 / Lead Free: For Use With: 325°C - 358°C YES EB-9000S, EB-9000S-2, MX500 and MX5000 Material Composition All components are RoHS compliant and Lead-Free. 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2012 Easy Braid Co. All Rights Reserved
EBM6CH177H
物料型号: - 型号名称:XXXX - 制造商:XXXX
器件简介: - 该器件是一个高性能的XXXX,主要用于XXXX领域。
引脚分配: - 引脚1:功能描述 - 引脚2:功能描述 - 引脚3:功能描述 - 引脚4:功能描述
参数特性: - 工作电压:XXXXV - 工作频率:XXXXHz - 工作温度:XXXX°C
功能详解: - 功能1:XXXX - 功能2:XXXX - 功能3:XXXX
应用信息: - 应用领域:XXXX - 典型应用:XXXX
封装信息: - 封装类型:XXXX - 封装尺寸:XXXXmm x XXXXmm
EBM6CH177H 价格&库存
很抱歉,暂时无法提供与“EBM6CH177H”相匹配的价格&库存,您可以联系我们找货
