EBM7K100H
EBM7K100H
    MENDA
    KNIFE 4.50MM 700 POWER PLUS
EBM7K100H 数据手册
EBM7K100H Datasheet Technical Specifications EBM7K100H Knife 4.50mm (0.177"), Power Plus Tip Style: Knife Tip Width: 4.50mm (0.18") Tip Length: 16.65mm (0.66") 700 Type Cartridge1 : RoHS Compliant2 / Lead Free: For Use With: 350°C - 398°C YES EB-9000S, EB-9000S-2, MX500 and MX5000 Material Composition All components are RoHS compliant and Lead-Free. 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2012 Easy Braid Co. All Rights Reserved
EBM7K100H 价格&库存
很抱歉,暂时无法提供与“EBM7K100H”相匹配的价格&库存,您可以联系我们找货
