EBM7LR400
EBM7LR400
    MENDA
    LONG REACH BEVEL SLD TIP 700DEG
EBM7LR400 数据手册
EBM7LR400 Datasheet Technical Specifications EBM7LR400 Long Reach Bevel 60° 1.0mm (0.04") Tip Style: Long Reach Bevel 60° Tip Width: 1.00mm (0.04") Tip Length: 14.60mm (0.57") 700°F Type Cartridge 1 : 350°C - 398°C 2 RoHS Compliant / Lead Free: YES Equivalent to: STTC-146 For Use With: EB-9000S Material Composition All components are RoHS compliant and Lead-Free. 1 Easybraid tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easybraid offers a wide variety of tip geometries from 0.4mm fine point tip to 5m chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010 Easybraid Co. All Rights Reserved
EBM7LR400 价格&库存
很抱歉,暂时无法提供与“EBM7LR400”相匹配的价格&库存,您可以联系我们找货
