EBM7MF375H Datasheet
Technical Specifications
EBM7MF375H
Micro Fine 0.25mm (0.01"), Power
Plus
Tip Style:
Micro Fine
Tip Width:
0.25mm (0.01")
Tip Length: 13.60mm (0.54")
700 Type Cartridge1 :
RoHS Compliant2 / Lead Free:
For Use With:
350°C - 398°C
YES
EB-9000S, EB-9000S-2, MX500 and MX5000
Material Composition
All components
are RoHS
compliant and
Lead-Free.
1
Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries
within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and
geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method,
technique and equipment used. Two different methods or the use of alternative equipment will produce different test results.
2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance.
Copyright © 2010-2012 Easy Braid Co. All Rights Reserved
很抱歉,暂时无法提供与“EBM7MF375H”相匹配的价格&库存,您可以联系我们找货
