Desoldering Braid & Desoldering Wick | Quick Braid, Sea Braid, One-Step
Home
About
MSDS
FEATURED PRODUCTS
CROSS REFERENCE
PRODUCT OVERVIEW
Compliance Documents
Distributors
Sales Reps
Request a Sample
Request a Quote
Page 1 of 3
Contact
News
REPLACEMENT SOLDERING TIPS
& SOLDERING STATIONS
SOLDER/REWORK STATION
DESOLDERING BRAID
STENCIL ROLLS
SOLDER SOAKERS
REPLACEMENT
SOLDERING TIPS &
SOLDERING STATIONS
SWABS
FUME EXTRACTION
SYSTEMS
VISUAL INSPECTION
SYSTEMS
PARMI SOLDER PASTE
INSPECTION
BGA/PCB Inspection
Endoscope Lens
BGA Software
Optical Inspection
Standards
The EB9000S Soldering/Rework Station,
using Curie Heat Technology, will provide
years of reliable performance. With this
very precise and self-regulating
technology, temperature calibration is not
required. Included in the EB9000S are a
13.56 MHz Power Supply, detachable
soldering iron stand with sponge and
brass curl, tip removal pad, and the
EBM8CH176 Solder Tip cartridge.
Soldering Station Technical Specifications
PROVIDE IMPROVED POWER,
PERFORMANCE AND RELIABILITY
z Increased plating results in longer
service life and cost savings
z Better connectivity through the
use of gold plated connectors
z Faster point to point soldering
z Stable tip temperature
Large PCBs
Optical Inspections vs.
X-Ray
http://www.easybraidco.com/replacementsoldering.htm
11/12/2012
EASY BRAID
PART #
600° Tips
EASY BRAID EASY BRAID
PART #
PART #
700° Tips
800° Tips
SIMILAR
METCAL®
Part #
Page 2 of 3
DESCRIPTION
EBM6CH175
EBM7CH175
EBM8CH175
STTC-X36
CHISEL 30° TIP 2.5mm
EBM6CH176
EBM7CH176
EBM8CH176
STTC-X37
CHISEL 30° TIP 1.78mm
EBM6CH177
EBM7CH177
EBM8CH177
STTC-X38
CHISEL 30° TIP 1.5mm
EBM6CH178
EBM7CH178
EBM8CH178
STTC-X25
CHISEL 30° TIP 1.0mm
EBM6CH179
EBM7CH179
EBM8CH179
STTC-X25P
CHISEL 30° EXTRA
CAPACITY TIP 1.0mm
EBM6CH181
EBM7CH181
EBM8CH181
STTC-X13
CHISEL 90° TIP 3.0mm
EBM6CH250
EBM7CH250
EBM8CH250
STTC-X17
Chisel Extra Large Tip
5.0mm (0.20")
EBM6CP200
EBM7CP200
EBM8CP200
STTC-X36P
CHISEL 30° EXTRA
CAPACITY TIP 2.5mm
EBM6CP201
EBM7CP201
EBM8CP201
STTC-X37P
CHISEL 30° EXTRA
CAPACITY TIP 1.8mm
EBM6CB225
EBM7CB225
EBM8CB225
STTC-X98
CHISEL BENT 30° TIP
1.78mm
EBM6CB226
EBM7CB226
EBM8CB226
STTC-X99
CHISEL BENT 30° TIP
1.5mm
EBM6LC650
EBM7LC650
EBM8LC650
STTC-X65
CHISEL 5.0mm
EBM6LR403
EBM7LR403
EBM8LR403
STTC-X42
CHISEL LONG
REACH 60° TIP
1.78mm
EBM6CS150
EBM7CS150
EBM8CS150
STTC-X06
CONICAL SHARP TIP
0.4mm (13.0mm tip
length)
EBM6CS151
EBM7CS151
EBM8CS151
STTC-X01
CONICAL SHARP TIP
1.0mm (13.4mm tip
length)
EBM6CS152
EBM7CS152
EBM8CS152
STTC-X22
CONICAL SHARP TIP
0.4mm (8.5mm tip
length)
EBM6CS154
EBM7CS154
EBM8CS154
STTC-X07
CONICAL SHARP TIP
1.0mm (16.4mm tip
length)
EBM6CS155
EBM7CS155
EBM8CS155
STTC-X43
CONICAL SHARP TIP
0.5mm
EBM6C300
EBM7C300
EBM8C300
STTC-X45
CONICAL TIP 0.4mm
EBM6C301
EBM7C301
EBM8C301
STTC-X16
CONICAL TIP 0.5mm
EBM6CP302
EBM7CP302
EBM8CP302
STTC-X45P
CONICAL EXTRA
CAPACITY TIP 0.4mm
EBM6CP303
EBM7CP303
EBM8CP303
STTC-X01P
CONICAL EXTRA
CAPACITY TIP
1.0mm
EBM6SB275
EBM7SB275
EBM8SB275
STTC-X26
SHARP BENT 30° TIP
0.4mm (8.4mm tip
length)
EBM6SB276
EBM7SB276
EBM8SB276
STTC-X44
SHARP BENT 30° TIP
0.5mm
EBM6B325
EBM7B325
EBM8B325
STTC-X40
SHARP BENT 30° TIP
0.4mm (16.0mm tip
length)
EBM6BV350
EBM7BV350
EBM8BV350
STTC-X47
BEVEL 60° TIP 1.78mm
EBM6BS602
EBM7BS602
EBM8BS602
STTC-X47P
BEVEL 60° TIP
1.8mm
EBM6K100
EBM7K100
EBM8K100
SMTC-X161
KNIFE 45° 2.03mm
EBM6DS526
EBM7DS526
EBM8DS526
SMTC-X173
KNIFE 45° 5.84mm
EBM6MD575
EBM7MD575
EBM8MD575
SMTC-X172
CONICAL FINE TIP 30°
0.51mm
EBM6DS525
EBM7DS525
EBM8DS525
SMTC-X147
HOOF 3.3mm
EBM6DS529
EBM7DS529
EBM8DS529
SMTC-X167
MINI-HOOF 1.5mm
EBM6LB125
EBM7LB125
EBM8LB125
SMTC-X60
LONG BLADE 10.41mm
EBM6LB126
EBM7LB126
EBM8LB126
SMTC-X61
LONG BLADE 15.75mm
EBM6LB127
EBM7LB127
EBM8LB127
SMTC-X62
LONG BLADE 22. 1mm
EBM6MF375
EBM7MF375
EBM8MF375
STTC-X90
Micro Fine Tip
0.25mm (0.01")
HAKKO®
11/12/2012
Part Number
EBH500
EBH501
EBH502
EBH503
EBH504
EBH505
EBH506
EBH507
EBH508
EBH509
EBH510
EBH511
EBH512
EBH513
EBH514
EBH515
EBH516
EBH517
Page 3 of 3
CROSS FOR HAKKO
900MT05C
900MT08D
900MT12D
900MT12LD
900MT16D
900MT18H
900MT1C
900MT24D
900MT2C
900MT2LD
900MT32D
900MT32LD
900MT3C
900MT4C
900MTB
900MTI
900MK
900MTLB
WELLER®
Part Number
EBW600
EBW601
EBW602
EBW603
EBW604
EBW605
EBW606
EBW607
EBW608
EBW609
EBW610
EBW611
EBW612
EBW613
EBW614
EBW615
EBW616
EBW617
EBW618
EBW619
EBW620
CROSS FOR WELLER
LHT5C
LHTC3.2
LHTD 45°5.0
LHTD5.0
LHTE7.0
LHTDX5.0
LHTF9.3
LHTFX9.0
LHTKN
LHTO 2.0
LT1 0.25
LT18XL
LT1L 0.25
LT1S 0.2
LT1SLX 0.4
LT1X 0.4
LT20 2.0
LT22S
LT4 1.2
LT4CP 1.2
LTALF 1.6
SOLDERING STATIONS
Part Number
EB9000S
EB9000PS
EBSPG5
EBMSPG50
EBRMP-1
EBSHP-1
EBSHH-1
EBSG-1-GR
EBSG-1-GY
EBBC-10
Description
Soldering Station
Soldering System Power Supply
Sponge
Sponge
Tip Removal Pad
Hand Piece
Workstand
Grip - Green
Grip - Gray
Copper Curls
Standard
Package
1
1
5
50
1
1
1
1
1
1
Featured Product Cross Reference Product Overview Desoldering Braid Stencil Rolls Solder Soakers
Replacement Soldering Tips & Soldering Stations Swabs Fume Extraction Systems Optical Inspection Systems
BGA/PCB Inspection BGA Software Endoscope Lens Standards Large PCBs Optical vs. X-Ray Site Map
©2012 EasyBraid Co. 11543 K-Tel Drive Minneapolis, Minnesota 55343
Phone: 1-952-929-3040 Fax: 1-952-929-2765
Contact Us Site Map
11/12/2012
很抱歉,暂时无法提供与“EBH500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+54.241055+7.01578
