LDB150-024SW
LDB150-024SW
    AE
    LED SUPPLY CC/CV AC/DC 12-24V
LDB150-024SW 数据手册
LED Power Supplies 150W LED Power 150W LDB150 LED Power Supply Constant Voltage /Current LDB Series The LDB150 series of constant voltage/current LED power supplies can deliver up to 150W output power in an extremely compact package size. FEATURES • Universal Input: 90-305VAC • Constant Voltage/Current • High Efficiency 92% • IP67 rated • Power Factor: Typical 0.95 • OCP, OVP, SCP, OTP • -30 to 60°C deg operation The LDB150 can deliver constant voltage single outputs 24V, 36V and 48V outputs in a compact package. At only 35mm high, the LDB150 offers the lowest profile LED driver solution. Furthermore, the LDB150 can operate as a constant current driver delivering the maximum output current range over the defined voltage range. Model Number Output Voltage Range Output Current (max) Efficiency LDB150-024SW 12V - 24V 6.25A 92.0% LDB150-036SW 18V - 36V 4.16A 92.0% LDB150-048SW 24V - 48V 3.125A 92.5% Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input Min 90 47 240VAC, 150W 240VAC in, 25°C, Cold Start 240VAC, 100VAC Nom Max 305 63 0.715 40 Units VAC Hz A A Max ±0.5 ±1.5 ±2.0 Units % % % 0.95 Output Specifications Parameter Line Regulation Load Regulation Voltage Accuracy Voltage Range Current Regulation Ripple and Noise Turn-on Delay Hold Up Time Short Circuit Protection Over Voltage Protection Over Temp Protection Conditions/Description Min Nom % of Vout See individual models Across Model Voltage Range 20MHz Bandwidth. See Note 1 Measured at 200VAC and full load ±3.0 2.0 0.5 % % pk-pk s ms 20 Hiccup, Auto Recovery Hiccup, Auto Recovery Hiccup, Auto Recovery 105% 85 Parameter Isolation Voltage Conditions/Description Input to Output See Note 2 Input to Chassis Min 3750 1500 Efficiency Safety Agency Approvals See individual models UL8750, CSA C22.2 No.223, EN61347-2-13, EN61347-1 Measured at 100VAC and 240VAC Telecordia SR-33, Full Load, 25°C T case = 60°C 130% 100 92 V °C General Specifications General Specifications No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Altitude Vibration Shock Note 1. Note 2. Note 3. Maximum T case = 80°C. See Note 3 Non-condensing (operating) Operating, Non Operating 10,000m 5-500Hz, random vibration Half-Sine, 11ms duration Nom Max 92 % 1.5 1,000,000 100,000 1 -30 -40 5 Units VAC VAC +60 +85 95 2000 1.0 10 W Hours Hours Kg °C °C %RH m Grms Grms 1 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. Isolation test may not be carried out on unit. Contact Applications Support for details Maximum allowable case temperature is 80°C Pre Release Sept 2011 Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com LED Power Supplies 150W EMC LED Power 150W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Input Line Surges Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Tessted To Level EN55015, EN55022 Class B EN55015, EN55022 Class B EN61000-3-2, Class C EN61000-3-3 Compliant Compliant Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Level 4 Level 3 Compliant Criterion B Units INPUT / OUTPUT WIRING INPUT CABLE Black (L), White(N) and Green/Yellow (E) 400±20mm SJTW 18AWG OUTPUT CABLE Red (+V) and Black (-V) 220±20mm SJTW 18AWG 2 Pre Release Sept 2011 Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LDB150-024SW
1. 物料型号:型号为MAX31855。
2. 器件简介:MAX31855是一款用于测量冷端温度和热电偶温度的集成电路。
3. 引脚分配:该芯片共有8个引脚,包括VCC、GND、SO、CS、CLK、DOUT、DGND、TH+、TH-。
4. 参数特性:工作温度范围为-40℃至+125℃,支持多种热电偶类型,包括K、J、T、E、R、S、B、N。
5. 功能详解:MAX31855能够通过SPI接口与微控制器通信,实现冷端和热电偶的高精度测量。
6. 应用信息:广泛应用于工业控制、医疗设备、环境监测等领域。
7. 封装信息:采用SOIC-8封装。
LDB150-024SW 价格&库存
很抱歉,暂时无法提供与“LDB150-024SW”相匹配的价格&库存,您可以联系我们找货
