LXC30-1660S
LXC30-1660S
    AE
    LED SUPPLY CC AC/DC 9-18V 1.66A
LXC30-1660S 数据手册
LED Power Supplies 30W LED Power 30W LXC30 series LED Power Supply Constant Current Power Supplies LED POWER next generation power source FEATURES • High Efficiency (up to 86%) • Constant Output Current • Active PFC (Typical 0.86) • IP67 Waterproof • OVP, SCP • -35 to 60°C deg operation • Universal Input 90-264VAC • UL8750 recognised • EN61347-1, -2-13 compliant The LXC30 series of constant current LED power supplies from Excelsys Technologies can deliver up to 30W of output power in an extremely compact package size. The LXC30 series of constant current power supplies provides up to 2500mA of output current and 85V output voltage solutions for specific LED requirements. With industry leading efficiencies, and an extensive protection feature set, the LXC30 series provides high reliability and high performance in a compact package The LXC30 series carries the CE mark for safety and is also RoHS compliant. For more details contact sales@excelsys.com Model Number Output Voltage Output Current Input Voltage LXC30-0350S LXC30-0450S LXC30-0700S LXC30-0830S LXC30-1250S LXC30-1660S LXC30-2500S 42-86V 33-66V 21-42V 18-36V 12-24V 9-18V 7-12V 350mA 450mA 700mA 830mA 1250mA 1660mA 2500mA 90-264VAC 90-264VAC 90-264VAC 90-264VAC 90-264VAC 90-264VAC 90-264VAC OVP Efficiency Latching max 129V 87.0% 99V 86.0% 63V 86.0% 54V 86.0% 36V 85.0% 27V 84.0% 18V 83.0% Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input Min 90 47 100VAC in, 30W output 230VAC in, 25°C, Cold Start 220VAC, 110VAC 0.83 Conditions/Description Min % of Vout % of Iout 20MHz Bandwidth. See Note 1 50 Nom Max 264 63 0.43 65 0.86 Nom Max ±1 ±3 100 ±5 2.0 10 3 Units VAC Hz A A Output Specifications Parameter Line Regulation Load Regulation Voltage Range Output Current Range Ripple and Noise Overshoot Turn-on Delay Short Circit Protection Over Voltage Protection Measured at 220VAC and full load Auto Recovery Latching. See individual models OVP levels Units % % % % % pk-pk % s General Specifications Parameter Isolation Voltage Efficiency Safety Agency Approvals No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Note 1. Note 2. Conditions/Description Input to Output See Note 2 Input to Chassis See individual models UL8750, EN61347-1, -2-13 Measured at 120VAC and 220VAC Telecordia SR-33, 25°C 25°C Non-condensing (operating) Min 3750 1500 Nom Max Units VAC VAC % 1.0 W Hours Hours g °C °C %RH 86 2,000,000 80,000 460 -35 -40 10 +60 +85 100 1 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. Primary to Secondary Isolation test not to be carried on power supply. Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com LED Power Supplies 30W EMC LED Power 30W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Level EN55015 EN55015 EN61000-3-2 EN61000-3-3 Level B Level B Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Compliant Compliant Units INPUT / OUTPUT WIRING INPUT CABLE SJTW 18AWG 2C Black (N) and White(L) 340±20mm OUTPUT CABLE SJTW 18AWG 2C Black (-V) and Red (+V) 340±20mm MECHANICAL SPECIFICATIONS 183 ± 0.5 162 ± 0.5 42.5 158 ± 0.5 10 ± 1 50 ± 2 50 ± 2 340 ± 20 10 ± 1 34.5 34.5 340 ± 20 173 ± 0.5 8 2 5 2 x 5.5dia 8 8 5 8 All Tolerances ± 0.2mm unless specified Specifications are subject to change without notice Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LXC30-1660S 价格&库存
很抱歉,暂时无法提供与“LXC30-1660S”相匹配的价格&库存,您可以联系我们找货
