Finisar
Product Specification
Multi-Rate CWDM GBIC Transceiver with APD Receiver
FTL-1621-XX
PRODUCT FEATURES
All Metro data protocols from
125Mb/s to 2.7 Gb/s
RoHS compliant and Lead Free
Standard GBIC footprint
Uncooled CWDM-rated DFB
laser transmitter
Class 1 laser safety
Very low jitter
Metal enclosure for lower EMI
Extended voltage range
Low power dissipation
Extended operating temperature
range: 0°C to 60°C
APPLICATIONS
Metro Access Rings and Pointto-Point networking for SONET,
Gigabit Ethernet Networks and
Fibre Channel SANs
Finisar’s FTL-1621-xx CWDM GBIC transceivers are designed for operation in Metro
Access Rings and Point-to-Point networks using Gigabit Ethernet1 and Fibre Channel2
networking equipment. The FTL-1619-xx is also designed to comply to GBIC
Specification Revision 5.53*. The transceiver is available in eight different CWDM
wavelengths; and is RoHS compliant and lead-free per Directive 2002/95/EC4 and Finisar
Application Note AN-20385. Digital diagnostics functions are available via an I2C serial
bus.
PRODUCT SELECTION
Color Code Dot
Wavelength XX
1470 nm
47
Gray
1490 nm
49
Violet
1510 nm
51
Blue
1530 nm
53
Green
© Finisar Corporation February 2007 Rev.B
Wavelength
1550 nm
1570 nm
1590 nm
1610 nm
XX
55
57
59
61
Color Code Dot
Yellow
Orange
Red
Brown
Page 1
FTL-1621-XX CWDM GBIC
I.
Product Specification – February 2007
Finisar
Pin Out
Pin Name
Pin #
Sequence
RX_LOS
1
2
GND
2
2
GND
3
2
MOD_DEF(0)
4
2
MOD_DEF(1)
5
2
MOD_DEF(2)
6
2
TX_DISABLE
7
2
GND
8
2
GND
9
2
TX_FAULT
10
2
GND
11
1
-RX_DAT
12
1
+RX_DAT
13
1
GND
14
1
VCC
15
2
VCC
16
2
GND
17
1
+TX_DAT
18
1
-TX_DAT
19
1
GND
Table 1. GBIC to host connector pin assignment
“Sequence” indicates the order in which pins make contact when the device is hot
plugged. See “Table 3: Signal Definitions” in the GBIC Specification Revision 5.53
for a description of the function of each pin listed above.
Page 2
Finisar
II. Electrical Power Interface
The GBIC specification calls for a range of 4.75V to 5.25 volts as described in Table 2.
The maximum voltage of 6V is not to be applied continuously.
Parameter
Supply Current
Maximum Voltage
Symbol
Is
Vmax
Min
Surge Current
Isurge
Input Voltage
Vcc
4.75
Power Supply Rejection
PSR
100
Typ
280
5.00
Max
350
6
Units
mA
V
400
mA
5.25
V
mV
Notes/Conditions
Referenced to GND
See Note 1. Peak to Peak
Table 2. Electrical power interface
Note 1: Receiver sensitivity is compliant with power supply sinusoidal of 20 Hz to 1.5Mhz up to specified
value applied through the recommended power supply filtering network
III. Low Speed Signals
RX_LOS, TX_DISABLE, and TX_FAULT are TTL signals as described in Table 3.
MOD_DEF(1) (SCL) and MOD_DEF(2) (SDA) are open drain CMOS signals (see
section VIII, “Serial Communication Protocol”). Both MOD_DEF(1) and MOD_DEF(2)
must be pulled up to host_Vcc. For more detailed information, see sections 5.3.1 – 5.3.8
in the GBIC Specification Revision 5.53.
Parameter
GBIC Output LOW
GBIC Output HIGH
GBIC Input LOW
GBIC Input HIGH
Symbol
VOL
Min
Units Notes/Conditions
V
4.7k to 10k pull-up to host_Vcc,
measured at host side of connector
VOH
host_Vcc - host_Vcc +
V
0.5
0.3
VIL
V
4.7k to 10k pull-up to Vcc,
measured at GBIC side of
connector
VIH
2
Vcc + 0.3
V
connector
Table 3. Low speed signals – electronic characteristics
Max
0.5
Page 3
Parameter
RX_LOS Assert Level
RX_LOS Deassert Level
RX_LOS Hysteresis
RX_LOS Assert Delay
Symbol Min
--42
--t_loss_on
RX_LOS Negate Delay
100
Units
dBm
dBm
dB
µsec
t_loss_off
150
µsec
TX_DISABLE Assert Time
t_off
1000
µsec
TX_DISABLE Negate Time
t_on
1000
µsec
TX_DISABLE Reset Time
t_reset
Typ
-39
-37
1.0
Max
-32
µsec
10
Finisar
Notes/Conditions
Measured on Finisar Eval Card
From detection of loss of signal
to assertion of RX_LOS
From detection of presence of
signal to negation of RX_LOS
Rising edge ot TX_DISABLE to
fall of output signal below 10%
of nominal
Falling edge of TX_DISABLE
to rise of output signal above
90% of nominal
TX_DISABLE HIGH before
TX_DISABLE set LOW
Table 4. Low speed signal parameters
IV. High Speed Electrical Interface
All high-speed PECL signals are AC coupled internally.
Parameter
Data Input Voltage
Data Output Voltage
Duty Cycle
PECL rise/fall
Bit Error Rate
Symbol
Vin
Vout
-Tr,Tf
BER
Tx Input Impedance
Rx Output Impedance
Zin
Zout
Min
650
370
Typ
Max
2000
2000
50
150
10-12
75
75
Units
mV
mV
psec
ohm
ohm
Notes/Conditions
PECL differential peak - peak
20%-80% Differential
PRBS 223 - 1 test data pattern
Singled ended impedance
Table 5. High speed electrical interface
Page 4
V.
Finisar
Optical Parameters
Parameter
Transmitter
Transmitter Center Wavelength
Symbol
λc
Min
Transmitter Extinction Ratio
Transmitter Eye Opening
Max
nm
0.09
nm/°C
1
SMSR
30
tr/tf
Pout
+1.0
ER
(x-6.5) (x+1) (x+6.5)
Wavelength Temperature
Dependence
Spectral Width
Side Mode Suppression Ratio
(SMSR)
Optical Rise/Fall Time
Transmitter Optical Output Power
Typ
nm
+3.0
200
+5.0
8.2
10
ps
Unfiltered, 80% -20%
dBm Average power coupled
into single mode fiber
dB
OC-48 eye mask
margin
ps
Peak to peak, filtered
100
Dispersion Penalty at 100km
3.0
dB
1620
100
dB
nm
ps
Receiver Optical Input Power
(BER < 10-12 w/ PRBS 223-1)
ORL
λin
Pin
14
1450
-28
Full Width, -20dB from
peak
dB
Transmitter Jitter
Receiver
Optical Return Loss
Optical Input Wavelength
Receiver Jitter Generation
Over temperature 0 to
60 °C case temperature.
See Note 1 below.
-7
See Note 4
See Note 5.
Peak to peak
dBm @ 2.488Gb/s,
PRBS 223-1 pattern
Table 6. Optical parameters
Note 1: The Transmitter Center Wavelength “x” is as specified by the customer. The current available
wavelengths are: 1470, 1490, 1510, 1530, 1550, 1570, 1590, and 1610 nm. Please see the “Product
Selection” section on page 1.
Note 2: Parameters are specified over temperature and at end of life unless otherwise noted.
Note 3: All parameters are measured on a Finisar GBIC Evaluation Card unless otherwise noted.
Note 4: SMF-28 fiber used. 100kms represents 2000ps/nm at 1610nm. Measured at 2.488Gb/s with a
PRBS 223-1 pattern at a BER
很抱歉,暂时无法提供与“FTL-1621-53”相匹配的价格&库存,您可以联系我们找货
