MO-FIN-A-A116-F11-1010-33-0-P
    II-VI
    PLC SPLITTER 1X16 P-GRADE SC/APC
MO-FIN-A-A116-F11-1010-33-0-P 数据手册
Finisar Product Specification Optical PLC Splitter 1. Introduction 1.1 General This specification covers the standards and requirements for the construction, properties, testing and packing of the Optical Splitter. 1.2 Description The optical Splitter is divided uniformity optical signals from input ports to multiple outputs. The optical Splitters are used in distribution equipment like FTTH Ethernet PON System 1.3 Reference Telcordia Technologies Generic Requirements GR-1209-CORE & GR-1221-CORE 2. Optical Specification ■ Optical performance shows without Connector state. Parameter Unit Insertion Loss (Max) S/P Uniformity (Max) S/P PDL (Max) S/P Return Loss / Directivity dB Operating Wavelength nm Operating Temperature 1x2 1x4 1x8 1x16 1x32 1x64 ≤4.0/3.8 ≤7.3/7.0 ≤10.5/10.2 ≤13.8/13.5 ≤16.8/16.5 ≤20.4/20.0 ≤0.5/0.5 ≤0.6/0.5 ≤0.8/0.6 ≤1.0/0.7 ≤1.2/1.0 ≤1.5/1.5 ≤0.2/0.15 ≤0.20/015 ≤0.2/0.2 ≤0.25/0.2 ≤0.25/0.2 ≤0.3/0.2 ≥55 1260 ~ 1650 -40 ~ +85 ℃ Storage Temperature - -40 ~ +85 S : Standard Grade / P : Premium Grade  Finisar Corporation Page 1 Finisar ■ Optical performance shows without Connector state. Parameter Unit Insertion Loss (Max) S/P Uniformity (Max) S/P PDL (Max) S/P Return Loss / Directivity dB Operating Wavelength nm Operating Temperature 2x2 2x4 2x8 2x16 2x32 2x64 ≤4.4/4.1 ≤7.5/7.3 ≤11.0/10.5 ≤14.5/14.0 ≤18.0/17.5 ≤21.5/21.0 ≤1.1/0.9 ≤1.2/1.0 ≤1.2/1.0 ≤1.8/1.5 ≤1.8/1.5 ≤2.3/2.0 ≤0.25/0.2 ≤0.25/0.2 ≤0.25/0.2 ≤0.3/0.25 ≤0.3/0.25 ≤0.4/0.4 ≤0.4/0.35 ≥55 1260 ~ 1650 -40 ~ +85 ℃ Storage Temperature - -40 ~ +85 S : Standard Grade / P : Premium Grade 3. Mechanical Specification 3.1. Mechanical Specification (Pigtail Type) Parameter Package Material Dimension (L x W x H mm) Parameter Package Material Dimension (L x W x H mm) 1x2, 1x4, 1x8 1x16, 1x32 1x64 Stainless Steel 40 x 4 x 4 2x2 47 x 7 x 4 2x4, 2x8 58 x 12 x 4 2x16, 2x32 2x64 Stainless Steel 40 x 4 x 4 55 x 7 x 4 60 x 7 x 4 40x4x4 (L x W x H) 1000mm 1000mm 3.1.1. Characteristics of Ribbon Fiber Color (ISO Color)  Finisar Corporation Page 2 70 x 12 x 4 Finisar 3.2. Mechanical Specification (Fan-out Type) Parameter Package Fanout Kit Material Dimension (L x W x H mm) Material Dimension (L x W x H mm) Parameter Package Fanout Kit Material Dimension (L x W x H mm) Material Dimension (L x W x H mm) 1x2, 1x4, 1x8 1x16, 1x32 1x64 Stainless Steel 40 x 4 x 4 47 x 7 x 4 58 x 12 x 4 Plastic 35 x 12 x 7 2x2 2x4, 2x8 2x16, 2x32 Stainless Steel 50 x 5 x 4 55 x 7 x 4 60 x 7 x 4 Plastic 35 x 12 x 7 3.2.1. Optical Fiber Type and Length Parameter Input Output (Ribbon Part) Output (Break Part) Optical Fiber Furcation Tube Description 900um Tight Buffered tube ≤1.0m 4ch or 8ch Ribbon Fiber ≤1.0m Fanout Kit with 900um Loose Tube ≤1.0m Bend intensive G.657A fiber 900um Loose Tube R15 Hytrel  Finisar Corporation Page 3 Finisar 40x4x4(LxWxH) 35x12x7(LxWxH) - Top View 1,000mm 500mm 500mm - Side View 4.0mm±0.5mm 3.3. Mechanical Specification (Mini module Type) Parameter 1x2, 1x4, 1x8 Material Dimension (L x W x H mm) 2x2, 2x4, 2x8 1x16, 2x16 1x32, 2x32 1x64, 2x64 SUS (only with 900um Loose tube) 55 x 7 x 4 60 x 7 x 4 60 x 12 x 4  Finisar Corporation Page 4 80 x 20 x 6 100 x 40 x 6 Finisar 3.3.1. Optical Fiber Type and Length Parameter Input Output (Ribbon Part) Output (Break Part) Optical Fiber Furcation Tube Description 900um Tight Buffered tube ≤1.0m 4ch or 8ch Ribbon Fiber ≤1.0m 900um Loose Tube ≤1.0m Bend intensive G.657A fiber 900um Loose Tube R15 Hytrel 55x7x4 (L x W x H) 1000mm 1000mm 3.4. Mechanical Specification (Cascade module Type) Parameter 1x2, 1x4, 1x8, 1x16, 1x32, 2x2, 2x4, 2x8, 2x16, 2x32 Material Package Dimension (L x W x H mm) 1x64, 2x64 Aluminum & ABS Plastic 100 x 80 x 10  Finisar Corporation Page 5 100 x 80 x 20 Finisar 3.4.1. Optical Fiber Type and Length Parameter Description In/output 900um Loose tube or 2.0mm cord jacket ≤1.0m Optical Fiber Bend intensive G.657A fiber 900um Loose Tube & 2.0mm cord PVC jacket R15 Furcation Tube Hytrel, PVC 100x80x10 (L x W x H) 1000mm 3.5. Mechanical Specification (Rack mountable Type) Parameter Package Material Dimension (L x W x H mm) 2x2, 1x16, 1x32 EGI (Electrolytic Galvanized Iron) ETSI standard require (Custom design)  Finisar Corporation Page 6 Finisar 4. Connector Specification Parameter Unit Condition Specification dB Mated Pair UPC APC ≤0.3 ≥55 ≥55 Insertion Loss Return Loss Ferrule Material nm Zirconia - Connector must guarantee with normal SM inspection criteria. 5. Splitter Label 1x8 Splitter S/N:XXXXXXXXXX 6. Reliability - Qualification Requirement Compliant with following requirements and provide the qualification reports. 1) Telcordia GR-1209, Generic Requirements for Fiber Optic Branching Components. 2) Telcordia GR-1221, Generic Reliability Assurance Requirement for Passive Optical Components. 7. Test Report A test report shall be provided with each module including the following measured data in a paper document; - Insertion Loss (wavelength at 1310nm and 1550) (@25℃) - Uniformity (@25℃) - PDL (@25℃) - Dimension of the protective case and length of pigtails. - Visual inspection (Pass or Fail) - Component packing dimensions (Pass or Fail) 8. Packing The final shipping cartons shall be of sufficient strength and durability to protect the contents from handling during storage and shipping by air. - Each Splitter will be conditioned by unit. - The Splitter is maintained in the packaging and the fibers are arranged by respecting the minimum bend radius of 15mm.  Finisar Corporation Page 7 Finisar - The packaging protects the Splitter from the drop. 9. Marking The details given below shall be distinctively marked in English with a weatherproof material, on at least two sides of the shipping cartons. - The company to be delivered The product item Country of origin Manufacturer’s name and / or trademark Date of manufacture Other information can be present on the packaging according to the customer’s request. End of Specification  Finisar Corporation Page 8 Finisar Part number Information  Finisar Corporation Page 9 Finisar  Finisar Corporation Page 10
1. 物料型号:文档中没有直接列出具体的物料型号,但提到了不同配置的光分路器,例如1x2、1x4、1x8等。
2. 器件简介:光分路器用于将输入端口的光信号均匀分配到多个输出端口。它们被用于FTTH以太网PON系统等分配设备中。
3. 引脚分配:文档中没有提到引脚分配,因为光分路器是无源设备,不涉及电子引脚。
4. 参数特性:文档详细列出了不同配置光分路器的插入损耗、均匀性、偏振相关损耗(PDL)、回波损耗/直接性、工作波长和工作温度等参数。
5. 功能详解:光分路器的功能是将光信号分配,文档中提到了其在FTTH以太网PON系统中的应用。
6. 应用信息:光分路器用于FTTH以太网PON系统等光网络分配设备。
7. 封装信息:文档提供了不同类型光分路器的机械规格,包括尺寸、材料和包装类型。
8. 其他信息:文档还包含了连接器规格、标签、可靠性要求、测试报告、包装、标记和部件编号信息。
MO-FIN-A-A116-F11-1010-33-0-P 价格&库存
很抱歉,暂时无法提供与“MO-FIN-A-A116-F11-1010-33-0-P”相匹配的价格&库存,您可以联系我们找货
