1X9 1310nm FP OC-3 XCVR
PRODUCT NUMBER: TSP-DxAA2-H21
Specification
1X9 Form Factor
Duplex SC Receptacle – DSC
Optical Transceivers
STM-1 / OC-3 / 100BASE
155.52Mbit/s
Ordering Information
T S P - D x A A 2 - H 2 1
Voltage / Temperature
1 : 3.3V / +0 ~ +70
2 : 3.3V / -40 ~ +85
Model Name
TSP-D1AA2-H21
Voltage Category Device type Interface
3.3 V
W/O DDMI
TSP-D2AA2-H21
FP / PIN
DC / DC
Coupling
SD/LOS
LVPECL
Temperature
Distance
+0°°C~+70°°C
30km
-40°°C~+85°°C
Formerica Optoelectronics Inc .
4F, No.31, Xintai Rd, Zhubei City,
Hsinchu County 302, Taiwan
Ph: +886-3-5512858 Fax: +886-3-5537118
Version 01
Page
1
Features
ROHS Compliant
Standard 1X9 Form Factor
SONET/SDH Standard Compliant
Fast Ethernet Standard Compliant
Laser Class 1 Product – IEC60825-1 Compliant
Standard Duplex SC Receptacle Optical Interface
Single + 3.3 V Power Supply
Differential LVPECL Data Input and Output
LVPECL Signal Detect
Low Power Consumption
Absolute Maximum Ratings
Parameter
Symbol
Min
Typ
Max
Unit
Storage temperature
TS
-40
85
°C
Supply voltage
VCC
V
5
95
VIN
VCC
V
Symbol
Min
Typ
Max
Unit
VCC
3.1
3.3
3.5
V
Operating Relative Humidity
Input voltage
Operating Conditions
Parameter
Supply Voltage
Operating Case temperature ( TSP-D1AA2-H21 )
Tc
Operating Case temperature (TSP-D2AA2-H21 )
ºC
-40
85
Total Current ( Transmitter + Receiver )
Icc
250
mA
Hand Lead Soldering Temperature / Time
Th
260/10
ºC /sec
Wave Lead Soldering Temperature / Time
Tw
260/10
ºC /sec
Version 01
Page
2
Transmitter Specifications ( VCC=3.1V~3.5V Tc= 0oC~70oC / Tc= -40oC~85oC )
Parameter
Symbol
Min
Typ
Max
Unit
Output Optical Power
Pout
-9
-3
dBm
Extinction Ratio
ER
9
dB
Center Wavelength
λC
1270
1310
1355
nm
3
nm
Optical Characteristics
Spectral Width (RMS)
σ
Rise/Fall time (10-90%)
Tr,f
2
ns
Relative Intensity Noise
RIN
-120
dB/Hz
Compliant with ITU-T G.957
Output Eye
Electrical Characteristics
Transmitter Data Input Voltage - High
VIH -Vcc
-1.1
Transmitter Data Input Voltage - Low
VIL -Vcc
-2.0
-0.74
V
-1.58
V
Receiver Specifications ( VCC=3.1V~3.5V Tc= 0oC~70oC/ Tc= -40oC~85oC)
Parameter
Symbol
Min
Typ
Max
Unit
PSATIN
-3
dBm
PSAN
-34
dBm
λc
1260
1610
nm
Signal Detect – Asserted
PSA
-34
dBm
Signal Detect – De-asserted
PSD
-45
dBm
Signal Detect – Hysteresis
PSH
0.5
6
dB
VDIFF
0.4
2.0
V
Signal Detect Output Voltage - High
VOH -Vcc
-1.1
-0.74
V
Signal Detect Output Voltage - Low
VOL -Vcc
-2.0
-1.58
V
Optical Input Power-maximum
23
;BER≦10
Receiver Sensitivity ( PRBS=2 -1
Operating Center Wavelength
-10
Differential Output Voltage
Version 01
Page
3
Pin Definition and Descriptions
9. TX GNDr
8. TD+
7. TD6. VCCT
5. VCCR
4. SD
3. RD2. RD+
1. RX GND
N/C
N/C
Bottom VIEW
Pin
Name
Description
1
RX GND
Receiver Signal Ground
2
RD+
Receiver Data Out
3
RD-
Receiver Data Out Bar
4
SD
Signal Detect
5
VCCR
Receiver Power Supply
6
VCCT
Transmitter Power Supply
7
TD-
Transmitter Data In Bar
8
TD+
Transmitter Data In
9
TX GND
Transmitter Signal Ground
Version 01
Page
4
Recommended Circuit Diagram
Version 01
Page
5
Mechanical Outlines
( Unit : mm)
Version 01
Page
6
很抱歉,暂时无法提供与“TSP-D1AA2-H21”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+628.71120
- 200+250.86240
- 500+242.48160
- 1000+238.33440
