FM CRIMPER 105-H/MS
FM CRIMPER 105-H/MS
    HRS(广濑)
    TOOL CIRCULAR CONTACTS
FM CRIMPER 105-H/MS 数据手册
Circular Connectors Supporting TÜV and MIL spec. H/MS Series Features 1. Compatible with MIL spec. standard products 2. A ground circuit is provided in the TÜV approved connectors 3. Waterproof The mated plug/receptacle combinations and un-mated receptacles are compliant to IP67F and IP68F ratings. IP67: Left in water at a depth of 1 m for 30 minutes IP68: Left in water at a depth of 2 m for 14 days Product Specifications Ratings Standard products Shell size Contact arrangement Number of contacts Rated current (A)/contact The figure in [ ] indicates the total capacity of the connector. Rated voltage Operation temperature range Storage temperature range 4 2 10SL 3 3 18 10 4 15 7 20 29 17 14 19 22 22 4 23 8 24 10 7 13 [24.5] 13 [34.5] 23 [76.2] 23 [105.7] 13 [44.2] 13A [49.4] 46 [152.5] 23 [100.4] 46 [211.5] AC500V, DC700V -40 to +125℃ -10 to +60℃ Ratings TÜV approved products Shell size Contact arrangement Number of contacts Rated current (A)/contact Wire size (mm2) Rated voltage (V) Degree of pollution Conducting voltage category Operation temperature range Storage temperature range 10SL 18 3 10 3 4 7 10 13 17 23 17 23 23 35 0.5 0.75 1.25 2 3.5 2 3.5 3.5 5.5 200 500 250 500 3 2 3 2 Ⅲ Ⅱ Ⅲ Ⅱ -40 to +125℃ -10 to +60℃ 22 22 4 46 8 23 3.5 24 10 7 35 5.5 250 3 Ⅲ 46 8 23 35 3.5 5.5 250 2 Ⅱ Performance Items 2. Insulation resistance Specifications 10SL, 20-29, 22-14: 5 mø max. 18-10, 20-15, 22-23: 3 mø max. 22-22, 24-10: 1 mø max. 5,000 Mø min. 3. Withstanding voltage No flashover or dielectric breakdown 1. Contact resistance 4. Vibration Resistance 5. Shock resistance 6. Mating Cycles 7. Temperature cycle 8. Moisture resistance 9. Waterproof Conditions Measured at DC 1 A Measured at DC 500 V AC 2,250 V for one minute 10 to 500 Hz/cycle, full amplitude: 0.75 mm, with 98 m/s2, 3 directions, 3 hours each No electrical discontinuity for 10 µs min. 10 to 500 Hz/cycle, full amplitude: 0.75 mm, with 98 m/s2, 3 axis directions, 3 hours each Acceleration: 490 m/s2, duration: 11 ms, No electrical discontinuity for 10 µs min. 3 axis directions, 3 cycles each Contact resistance : Initial value x for 1.5 mø max. 500 times -55ç: 30 minutes ➝ Normal temperature: 10 Insulation resistance: a minimum of 500 Mø to 15 minutes ➝ 125ç: 30 minutes ➝ Normal temperature: 10 to 15 minutes, left for 5 cycles Insulation resistance: Temperature: 71ç, relative humidity: 95%, left for a minimum of 50 Mø (at high humidity min. 336 hours 500 Mø (when dry) min. Left in water at a depth of 1 m for 0.5 hours in the No water penetration into the connector. mated state. 2014.11w 1 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Materials Material Finish Remarks ---------------------- Shell Aluminum alloy (Zinc alloy: H/MS3108B plug cord tube) Black chromate treatment Insulator PPS resin, PBT resin, or silicone rubber Black Contact Copper alloy Acrylonitrile-butadiene rubber (Chloroprene rubber: H/MS08A plug) Bushing Silver plating UL94V-0 (Excluding silicone rubber) ---------------------- Black ---------------------- Ordering information ● Plug and receptacle H/MSA 3102 A 18 - 10 P X - D - T (01) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ ● Clamp H/MSA 3057 - 4A (01) ❶ ❷ qModel name: H/MS Series. wShape : Indicates the shape of the connector. 3102 : Receptacle 3106 : Straight plug 3108 : Right angle shaped plug 08: Low-profile, right angle shaped plug 3057 : Cord clamp eStructure: Indicates the structure of the connector. A: Integrated shell B: Separated shell rShell size: This is the diameter of the screw (inches) at the termination end multiplied by the constant of 16. (Example: The shell size of 18 is calculated by 1 1/8” x 16 = 18.) tContact arrangement: See pages 10 and 11 for details on contact arrangement. yContact form: Indicates the termination style. P : Soldered, male contact S : Soldered, female contact PC : Crimped, male contact SC : Crimped, female contact uVariations of insert position: The letters W, X, Y, or Z are used for any changes in the insert position from that of the standard type. iGround contact number: Notes the grounded contact for TÜV approved products. The ground contact position corresponds to contacts C, D, or G, and varies depending on shell size. Part numbers without this symbol indicate that the part does not include a ground contact. oTÜV approved product: TÜV approved products that are compliant with DIN VDE 0627. !0Clamp size: Indicates both clamp size and structure. !1Other specifications: A two-digit number such as (01) or (02) is added to indicate other specifications. 2 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Straight plug Spanner/wrench flat width (mm) E D A ØA D B 18−10S C X Y C H/MS3106A18-10S-D-T(73) B (Representative example) Standard products HRS No. 120-0601-3 73 120-0603-9 73 120-0605-4 73 120-0611-7 73 120-0611-7 77 120-0613-2 73 120-0615-8 73 120-0619-9 73 Part No. H/MS3106A10SL-4S(73) H/MS3106A10SL-3S(73) H/MS3106A18-10S(73) H/MS3106A20-29S(73) H/MS3106A20-29SW(77) H/MS3106A22-14S(73) H/MS3106A22-22S(73) H/MS3106A24-10S(73) ØA B 22 33.5 No. of contacts 2 3 4 17 37 19 4 7 C D E 36.8 5/8-24UNEF-2A ---- 50 1-20UNEF-2A 27 54.5 1 3/16-18UNEF-2A 32 43 57.7 1 7/16-18UNEF-2A 37 ØA 22 33.5 39.5 43 B 36.8 50 54.5 57.7 D 5/8-24UNEF-2A 1-20UNEF-2A 1 3/16-18UNEF-2A 1 7/16-18UNEF-2A E ---27 32 37 10 39.5 TÜV approved products HRS No. 120-0326-0 73 120-0323-2 73 120-0324-5 73 120-0325-8 73 Part No. H/MS3106A10SL-3S-C-T(73) H/MS3106A18-10S-D-T(73) H/MS3106A22-22S-D-T(73) H/MS3106A24-10S-G-T(73) No. of contacts 3 4 7 C 10 Right-angled plug B D E ØA C 18 Spanner/wrench flat width (mm) F H/MS3108B18-10S-D-T(73) (Representative example) Standard products HRS No. 120-0701-8 73 120-0703-3 73 120-0705-9 73 120-0709-0 73 120-0711-1 73 120-0711-1 74 120-0713-7 73 120-0715-2 73 120-0719-3 73 Part No. H/MS3108B10SL-4S(73) H/MS3108B10SL-3S(73) H/MS3108B18-10S(73) H/MS3108B20-15S(73) H/MS3108B20-29S(73) H/MS3108B20-29SW(74) H/MS3108B22-14S(73) H/MS3108B22-22S(73) H/MS3108B24-10S(73) No. of contacts 2 3 4 7 ØA B C 22 37.3 33.5 19 4 7 E F 24.5 5/8-24UNEF-2A 20 54.5 32 1-20UNEF-2A 32 60.7 34 37 17 D 11.6 35 1 3/16-18UNEF-2A 39.5 43 38 67.1 39.6 1 7/16-18UNEF-2A 41 TÜV approved products HRS No. 120-0421-1 73 120-0422-4 73 120-0423-7 73 120-0424-0 73 Part No. No. of contacts H/MS3108B10SL-3S-C-T(73) 3 H/MS3108B18-10S-D-T(73) 4 H/MS3108B22-22S-D-T(73) H/MS3108B24-10S-G-T(73) 7 ØA 22 33.5 39.5 43 B 37.3 54.5 60.7 67.1 C 24.5 32 34 39.6 D 11.6 E 5/8-24UNEF-2A 1-20UNEF-2A 1 3/16-18UNEF-2A 1 7/16-18UNEF-2A F 20 32 38 41 (Note) With some models it may be difficult to push the cable through the connector, even when the cable is within the applicable range. Waterproof performance and cable clamp capability may differ depending on the cable specification. Please make sure all specifications are met before actual use. 3 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Low-profile, right-angled plug (with cord clamp) 18 size: Ø33.5 18 18 size: 45.5 (22 size: 67.5) A Y B18−10S D C X 3057−10 H/MS08A18-10S-DT10D(73) (22 size: Ø39.5) 18 size: 41 (22 size: 45.8) 18 size: 31 (22 size: 36) (Representative example) TÜV approved products HRS No. Part No. 120-0476-3 73 H/MS08A18-10S-DT10D(73) 120-0481-3 73 H/MS08A18-10S-DT10D1(73) 120-0477-6 73 H/MS08A22-22S-DT12D(73) 120-0477-6 74 H/MS08A22-22S-DT12D(74) 120-0482-6 74 H/MS08A22-22S-DT12D1(74) No. of contacts Weight 4 89g 4 127g Applicable cable diameter Ø12 ∼ 14.3mm Solder pot diameter Ø2.5 Ø10 ∼ 12.5mm Ø13 ∼ 15.9mm Ø4.5 Ø10 ∼ 13.5mm Ø33.5 A Y B 18−10S D C X 35.5 18 41 H/MS08A18-10S-DT10C(74) Ø30 (Representative example) TÜV approved products HRS No. 120-0480-0 74 Part No. H/MS08A18-10S-DT10C(74) No. of contacts Weight Applicable cable diameter Solder pot diameter 4 77.6g Ø13 ∼ 14.3mm Ø2.5 1.Part number suffix (73) Specification: products with a wire hole in the locking ring to prevent loosening of the ring. (74) Specification: products without a wire hole in the locking ring. 4 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Single block (waterproof) This connector is designed for use with flexible conduit or cabtire cable connectors.(See page 8 for the table of compatibilities for H/MS connectors and other connectors.) D A ØA D X Y B C 18−10S C H/MS3106A-18-10S-D-T(76) B (Representative example) Standard products HRS No. 120-0601-3 76 120-0603-9 76 120-0605-4 76 120-0611-7 76 120-0611-7 78 120-0613-2 76 120-0615-8 76 120-0619-9 76 Part No. H/MS3106A10SL-4S(76) H/MS3106A10SL-3S(76) H/MS3106A18-10S(76) H/MS3106A20-29S(76) H/MS3106A20-29SW(78) H/MS3106A22-14S(76) H/MS3106A22-22S(76) H/MS3106A24-10S(76) No. of contacts 2 3 4 ØA B C 22 24 6.5 33.5 31.2 8 17 37 9/16-24UNEF-2A 1-20UNEF-2A 1 1/8-18UNEF-2A 33.2 19 4 7 D 10 39.5 43 34.7 ØA 22 33.5 39.5 43 B 24 31.2 33.2 34.7 1 1/4-18UNEF-2A 1 3/8-18UNEF-2A TÜV approved products HRS No. 120-0326-0 76 120-0323-2 76 120-0324-5 76 120-0325-8 76 Part No. H/MS3106A10SL-3S-C-T(76) H/MS3106A18-10S-D-T(76) H/MS3106A22-22S-D-T(76) H/MS3106A24-10S-G-T(76) No. of contacts 3 4 7 C 6.5 8 D 9/16-24UNEF-2A 1-20UNEF-2A 1 1/4-18UNEF-2A 1 3/8-18UNEF-2A 10 Receptacle (solder type) B A A ØH B A D ØC B C X Y 18−10 D I E F H/MS3102A18-10P-D-T1(73) G (Representative example) Standard products HRS No. 120-0111-4 73 120-0113-0 73 120-0101-0 73 120-0115-5 73 120-0103-6 73 120-0103-6 74 120-0107-7 73 120-0109-2 73 Part No. H/MS3102A10SL-4P(73) H/MS3102A10SL-3P(73) H/MS3102A18-10P(73) H/MS3102A20-15P(73) H/MS3102A20-29P(73) H/MS3102A20-29PW(74) H/MS3102A22-22P(73) H/MS3102A24-10P(73) No. of contacts A B ØC D E F G ØH I 2 18.26 25.4 14.5 2.2 23.6 28.3 15.6 5/8-24UNEF-2A 3 30 26.6 1 1/8-18UNEF-2A 4 26.97 34.92 35 3.3 7 19.3 29.36 38.1 29.6 1 1/4-18UNEF-2A 2.8 29.4 33 17 4 7 31.75 41.28 34.92 44.45 3.75 21 38 32.6 1 3/8-18UNEF-2A 31.6 41 36 1 1/2-18UNEF-2A TÜV approved products HRS No. 120-0231-6 73 120-0259-5 73 120-0227-9 73 120-0228-1 73 Part No. No. of contacts H/MS3102A10SL-3P-C-T(73) 3 H/MS3102A18-10P-D-T1(73) 4 H/MS3102A22-22P-D-T(73) H/MS3102A24-10P-G-T(73) 7 A 18.26 26.97 31.75 34.92 B ØC D E F 25.4 14.5 2.2 23.6 30 34.92 3.3 19.3 2.8 29.4 41.28 44.45 3.75 21 31.6 G 28.3 35 38 41 ØH 15.6 26.6 32.6 36 I 5/8-24UNEF-2A 1 1/8-18UNEF-2A 1 3/8-18UNEF-2A 1 1/2-18UNEF-2A 5 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Receptacle (crimp type) B A M ØC A B T N C Z P B A W K S J D R 20−29P H G ØH L E F D I E F G H/MS3102A20-29PC(73) (Representative example) Standard products HRS No. No. of A B contacts 17 29.36 38.1 Part No. 120-0501-9 73 H/MS3102A20-29PC(73) 120-0502-1 73 H/MS3102A22-14PC(73) 19 31.75 41.28 ØC D E F G 3.3 19.3 2.8 29.4 37 ØH I 29.6 1 1/4-18UNEF-2A 32.6 1 3/8-18UNEF-2A Contact Ø2.8 Male contact 28.5 Type HRS No. Part No. Reel contacts Loose piece contacts 120-0533-5 H/MS-PC1-212 120-0534-8 H/MS-PC1-112 Applicable wire size AWG#24 ∼ 28 (Note) Reel contacts are packaged 7,000 pcs/reel. Loose piece contacts are packaged 100 pcs/pack. Receptacle mounting method When installing a waterproof receptacle, please insert the appropriate O-ring (to be placed between the receptacle and panel), as shown in the figure on the right. Mounting panel Recommended O-ring dimensions. ØA O-ring Inner diameter Thickness of of O-ring (Ø) O-ring (Ø) H/MS3102A10SL-** 17.5 17.5 H/MS3102A18-** 28.5 28.5 H/MS3102A20-** 31.5 31.5 H/MS3102A22-** 34.5 34.5 H/MS3102A-24 ** 37.8 37.5 1.5 ØA Part No. 2 H/MS connector 6 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. ØA ØD Cord clamp B Spanner/wrench flat width (mm) E C H/MS3057-10A(73) (Representative example) Waterproof type 120-0801-2 73 H/MS3057-4A(73) 20 26.8 83.8 5.6 17 Range of applicable cable diameters (reference) Ø3.1 ∼ 5.6 120-0802-5 73 H/MS3057-10A(73) 30 28.8 72.8 14.3 27 Ø10.3 ∼ 14.3 18 120-0803-8 73 H/MS3057-12A(73) 34 29.8 70.8 15.9 30 Ø11.4 ∼ 15.9 20.22 120-0804-0 73 H/MS3057-16A(73) 40 33.8 69.3 19 36 Ø14 ∼ 19 24 HRS No. Part No. ØA B C ØD E Applicable shell size 10SL (Remarks) For various cable diameters, clamping force and waterproof performance may differ depending on the cable type selected. Please make sure all specifications are met before assembly. Applicable tools Type Item Manual Manual crimping tool Automatic Auto crimping press Applicator Extraction tool HRS No. Part No. 150-0206-0 H/MS/CC-HT 901-0005-4 CM-105 901-2027-8 AP105-H/MS-PC1-1 150-0076-7 H/MS-TP Applicable contact H/MS-PC1-112 ---------------------H/MS-PC1-212 H/MS-PC1-112 H/MS-PC1-212 Applicable wire size AWG#24 ∼ 28 ---------------------AWG#24 ∼ 28 ---------------------- Manual crimping tool Extraction tool Automatic crimping press (CM-105) 7 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Connector combinations Cord clamp Right-angled plug Connector for cabtire cable Straight plug Connector for flexible conduit Receptacle Low-height, right-angled plug Straight connector for flexible conduit and cabtire cable Single block Straight connector for flexible conduit and cabtire cable (Remarks) 1. Illustration represents connectors for flexible conduit and cabtire cable as a reference example. 2. The standard and TÜV approved products are compatible with each other. When using the TÜV approved products for TÜV applications, make sure to use both TÜV approved plugs and receptacles together. 8 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Table of compatibilities for H/MS connectors and the connectors for conduit and cabtire cable Connectors for flexible conduit H/MS connector Part No. Part number by Nippon Flex Co., Ltd. Straight type H/MS3106A10SL-□□(73) RCC10*CA12 (with O-ring) H/MS3108B10SL-□□(73) RCC10*CA12 H/MS3106A10SL-□□(76) RCC10*RL-MS10F H/MS3106A18-□□(73) --------RCC-30*RL-MS10F --------- * H/MS3106A18-□□(76) RCC10*RL-MS18F H/MS3106A20-□□(73) RCC10*CA2022 (with O-ring) H/MS3106B20-□□(73) RCC10*CA2022 H/MS3106A20-□□(76) RCC10*RL-MS20F RCC-30*RL-MS18F --------RCC-30*RL-MS20F --------- * RCC10 CA2022 H/MS3106A22-□□(76) RCC10*RL-MS22F H/MS3106A24-□□(73) CC10*CA2428 (with O-ring) H/MS3108B24-□□(73) RCC10*CA2428 H/MS3106A24-□□(76) RCC10*RL-M524F NBDC 12S** (with O-ring) NBDC 12S** BOS 10* RCC-30*RL-MS22F --------RCC-30*RL-MS24F Right angle type --------BOL 10* NBDC 18 (with O-ring) ** NBDC 18 BOS 18** --------BOL 18** NBDC 20(22)** (with O-ring) NBDC 20(22)** BOS 22** --------BOL 20** ** RCC10*CA2022 (with O-ring) H/MS3108B22-□□(73) Straight type ** RCC10 CA18 (with O-ring) RCC10 CA18 H/MS3106A22-□□(73) Right angle type * H/MS3108B18-□□(73) Part number by Daiwa Dengyo Co., Ltd. NBDC 20(22) (with O-ring) NBDC 20(22) BOS 22** --------BOL 22** NBDC 24** (with O-ring) NBDC 24** BOS 24** --------BOL 24** Connectors for cabtire cable H/MS connector Part No. Part number by Nippon Flex Co., Ltd. Straight type Right angle type --------- --------- H/MS3106A-10SL□□(73) H/MS3108B-10SL□□(73) H/MS3106A-10SL□□(76) H/MS3106A18-□□(73) H/MS3108B18-□□(73) H/MS3106A18-□□(76) H/MS3106A20-□□(73) H/MS3106B20-□□(73) H/MS3106A20-□□(76) H/MS3106A22-□□(73) H/MS3108B22-□□(73) H/MS3106A22-□□(76) H/MS3106A24-□□(73) H/MS3108B24-□□(73) H/MS3106A24-□□(76) ACS**RL-MS10F ACA**RL-MS10F Part number by Daiwa Dengyo Co., Ltd. Right angle Straight type type YDC 12S* (with O-ring) --------YDC 12S* YDO 10* ** ACS**CA18 ACS**RL-MS18F --------ACA**RL-MS18F ACS**CA2022 ACS**RL-MS20F --------ACA**RL-MS20F ACS**CA2022 ACS**RL-MS22F --------ACA**RL-MS22F YDC 18 ACS**RL-MS24F --------ACA**RL-MS24F (with O-ring) ** YDC 18 YDO 18** YDC 20(22)** YDC 20** YDC 20(22)** YDO 22** YDC 24 YDO 24** --------YLO 20* YDC 20(22)** (with O-ring) YDC 24** --------YLO 18* YDO 20(22)** (with O-ring) ** ACS**CA2428 YLO 10* --------YLO 22* (with O-ring) --------YLO 24* (Remarks) 1. □□ : Indicates contact arrangement/count. 2. **: The values differ depending on the cable used. 9 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Contact arrangement and electrical performance Shell size 10SL 18 20 4 3 10 15 29 2 3 4 7 17 Contact arrangement Number of contacts Withstanding voltage Current capacity Insulation resistance Contact resistance Inner diameter of solder pot Preliminary soldering AC 1,000 V for one minute 13A(24.5A) AC 2,000 V for one minute 13A(34.5A) 23A(76.2A) 23A(105.7A) 13A(44.2A) 5,000 Mø min. at 500V DC 5 mø max. 3 mø max. 5 mø max. Ø1.8 Ø2.9 Ø1.8 Not necessary Needed Not necessary Shell size 22 24 14 22 23 10 19 4 8 7 23A(100.4A) 46A(211.5A) Contact arrangement Number of contacts Withstanding voltage Current capacity Insulation resistance Contact resistance Inner diameter of solder pot Preliminary soldering AC 2,000 V for one minute 13A(49.4A) 46A(152.5A) 5,000 Mø min. at 500 V DC 5 mø max. 1 mø max. 3 mø max. 1 mø max. Ø1.8 Ø5.3 Ø2.9 Ø5.3 Not necessary Needed Remarks 1. Figure shows the receptacle contact arrangement as viewed from the interface mating side (plug's socket insert side). 2. Withstanding voltages are derived from test voltages 3. Current capacities are shown in a value per contact. The number in ( ) indicates the connector's total capacity. 4. Contact resistances are shown in a value when measured at DC 1 A. 5. Please contact us for more information. 10 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. Major specifications of TÜV approved products Applicable German standard: DIN VDE0627 (connector) Shell size 10SL 18 22 24 3 10 22 10 Number of contacts 3 4 4 7 Ground contact No. AC/DC rated voltage (V) Rated current (A) C D D G 7 10 13 17 23 17 23 23 35 46 23 35 46 23 46 Wire size (mm2) 0.5 0.75 1.25 2 3 2 3 3.5 5.5 8 3.5 5.5 8 3.5 5.5 Contact arrangement Degree of Pollution Conducting voltage category Inner diameter of solder pot (mm) 200 500 250 500 250 250 3 2 3 2 3 2 Ⅲ Ⅱ Ⅲ Ⅱ Ⅲ Ⅱ Ø1.8 Ø2.6 Ø4.5 Plug: Ø3.6 Receptacle: Ø5.3 Remarks 1. Figure shows the receptacle contact arrangement as viewed from the interface mating side (plug's socket insert side). 2. Current capacities are shown in a value per contact. 3. The contact numbers with a mark " ◎ " have contacts that are grounded to the outer shell, except for receptacles that are size 24-10. 4. For the receptacles that are size 20-10, the ground contact (contact No.: G) does not ground with the outer shell. Please use these connectors after grounding the outer shell of the connector with the corresponding contact No. 5. The degree of pollution and conducting voltage categories refer to the environmental condition in which a DIN VDE0110 (insulation coordination for the electric appliances in a constant voltage facility) electric appliance is used, and to the class of over voltage in the electric appliance. 6. Performance values for other than those shown above are the same as those of the general H/MS series. Usage Recommendations (1) The power to the circuit should always be off before mating/unmating a connector. (2) Always use a female connector for the power side of the circuit; this will prevent the likelihood of electric shocks. (3) Be sure to fully tighten the lock mechanism of the connectors. (4) Connector performance features such as cable clamping force, cable rotation force, or waterproof performance may differ depending on the cable construction. Please make sure all specifications are met before assembly. (5) This product uses silver-plated contacts. Please be aware that silver easily reacts to sulfur gases, causing discoloration or degradation when exposed to certain environmental conditions as shown below. These conditions include areas with: • A large amount of dust and dirt • High density of sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas, or other gas (Emission gases from vehicles and factories, etc.) • Highly fluctuating temperatures, such as close to a heating apparatus In addition, it is recommended to store the products in their original packaging or similar state in order to prevent discoloration. • Temperature: -10 to +60°C, relative humidity: 80% or lower (An environment where temperature and relative humidity are constant and there is less temperature difference is recommended.) • Please use the products within six months after delivery. (For the products in which the storage period is expired, please confirm the ease of soldering for your application beforehand.) 11 H/MS Series●Circular Connectors Supporting TÜV and MIL spec. USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6706 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/cn/ KOREA: SINGAPORE: HIROSE KOREA CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Kyunggi-Do 429-450 079903, Singapore Phone : +82-31-496-7000,7124 Phone : +65-6324-6113 Fax : +82-31-496-7100 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.co.kr/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +91-12-660-8018 Fax : +91-120-4804949 http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ ® 12 MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. (REPRESENTATIVE OFFICE) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
FM CRIMPER 105-H/MS 价格&库存
很抱歉,暂时无法提供与“FM CRIMPER 105-H/MS”相匹配的价格&库存,您可以联系我们找货
