PQ50-19(2517)-B(61)
PQ50-19(2517)-B(61)
    HRS(广濑)
    TOOL ACCY
PQ50-19(2517)-B(61) 数据手册
ITS-P-09009Q_1 PQ50 Series High Power Supply Die-Casting Connector for Industrial Machines ‹ Features 1. 600 V capability supporting NFPA79 compliant cables 2. Robust and enhanced shielding die-cast shell 3. Side lock with clear tactile click 4. In-line type is also avaialble. 5. 3-point contacts and sequential mate contact structure 6. Flexible and varieties of coding key system *This product satisfies halogen free requirements as 900 ppm maximum chlorine, 7. Security standard (TÜV/UL) to be approved defined 900 ppm maximum bromine, and 1500 ppm maximum total of chlorine and bromine. 8. RoHS compliant, Halogen-free product* 600 V Capability Robust Design High cable clamp strength UserFriendly Plug 20 pos. Flexible panel attachment Robust Zinc die-cast shell Flexible coding key system Receptacle ‹ Dimensions Panel Attachment Receptacle (Female Contact) Direct grounding Cable Plug (Male Contact) In-Line Receptacle (Female Contact) 48.8 48.8 63 82 82 .6 35.2 35.2 .8 43.2 35.1 All the dimensions in millimeters. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. Issued: July 6, 2012
PQ50-19(2517)-B(61)
- 物料型号:PQ50系列 - 器件简介:这是为工业机器设计的高功率供电压铸连接器,具有600V的承载能力,支持NFPA79合规电缆。 - 引脚分配:文档中提到了20个位置的连接器,但具体的引脚分配没有详细说明。 - 参数特性: - 600V的承载能力 - 增强的屏蔽和坚固的压铸壳体 - 侧面锁定机制,具有清晰的触觉反馈 - 提供直插型和内联型两种类型 - 三点接触和顺序配对接触结构 - 灵活多样的编码键系统 - 满足无卤素要求,定义为最大氯含量900ppm,最大溴含量900ppm,氯和溴的总含量不超过1500ppm - 符合TÜV/UL安全标准(待批准) - 符合RoHS标准,无卤素产品 - 功能详解:文档中没有提供详细的功能解释,但提到了连接器的高电缆夹紧力和用户友好的插头设计。 - 应用信息:适用于工业机器的高功率供电。 - 封装信息:提供了面板安装型插座(女性接触)和内联型插座(男性接触)的尺寸,所有尺寸单位为毫米。
PQ50-19(2517)-B(61) 价格&库存
很抱歉,暂时无法提供与“PQ50-19(2517)-B(61)”相匹配的价格&库存,您可以联系我们找货
PQ50-19(2517)-B(61)
  • 1+759.907291+98.75189
