DVK-AC4490-200A
DVK-AC4490-200A
    LAIRD(莱尔德)
    KIT DEVELOPER AC4490-200A
DVK-AC4490-200A 数据手册
RAMP-AC RF DVK Hardware USER’S GUIDE VERSION 1.0 Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp Ramp-AC RF DVK Hardware Version 1.0 REVISION HISTORY Version 1.0 Date 30 April 2014 Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp Changes Initial Release 2 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 CONTENTS Contents ..................................................................................................................................................... 3 Introduction ............................................................................................................................................... 4 Hardware ................................................................................................................................................... 4 AC Series DVK Board ............................................................................................................................... 4 Interfacing the AC DVK to RS232 Hardware ......................................................................................... 9 Interfacing the AC DVK to RS485 Hardware ......................................................................................... 9 Power Requirements .......................................................................................................................... 10 Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 3 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 INTRODUCTION The Laird RF RAMP-AC Development Kit board is the standard interface for software development on all Laird RAMP-AC products. This board is connected to a Windows PC via RS-232 connector and programmed via the Laird Configuration Utility. This guide covers the hardware specifications of the development board, HARDWARE This section details the Development Kit boards for the AC series RAMP modules including the following: AC4490-1000M AC4490-200M AC4490LR-1000M AC4490LR-200M AC4490-200A AC4790-1000M AC4790-200M AC4790LR-1000M AC4790LR-200M AC4790-200A AC4486-5A AC4486-5M AC5124 – EOL AC3124 – EOL AC4424 – EOL AC4868 - EOL AC Series DVK Board The SDK board is provided so the developer can use a standard PC interface to operate the transceivers and to aid in system integration. As shown in Figure 1, there are many features that enhance the functionality and usability of this board. It uses +5V TTL, RS232, RS485, and USB data formats for interfacing with the transceiver. The configuration and operation of the SDK board is continuously shown by the LEDs located on the edge of the board. See Table 1 and Table 2 for definitions of the LEDs and switches. Figure 1: SDK Board Assembly Drawing Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 4 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 Table 1: Switch and Jumper Settings Switch / Jumper Description When this switch is moved to the Program Mode position, the RTS pin from the DB9/USB connector is connected to the Command/Data pin (AC4490, AC4486, AC4424, AC4790, AC4868), the TE pin (AC3124, AC1524) and the Pktmode pin (AC5124) of the transceiver. RTS of the transceiver is also connected to GND which allows the SDK software to control these pins with RTS always enabled. Program Mode/ Normal Mode (S6) When the switch is moved to the Normal position, RTS at the DB9/USB connector is connected to RTS pin of the transceiver and Command/Data is left disconnected. The AC4424, AC4490, AC4790, AC4486, and AC4868 families all support AT commands for making changes to the EEPROM settings. If the Read/Write with AT Commands checkbox is enabled on the PC Settings page of the configuration software, then the Program/Normal switch can be set to Normal. The AC5124 family also supports AT Commands when that function is enabled in the transceiver EEPROM. RESET (S1) When this button is pressed, the transceiver hardware performs a soft reset. When this button is pressed, it takes the Write Enable pin (AC4424, AC5124, AC3124, and AC1524) or GI1 pin (AC4490, AC4486, AC4790, AC4868) low. WR ENABLE (S2) Note: RS485 or TTL Radio This button must be pressed and held during the write process for AC5124, AC3124, AC1524, and AC4424 product families. If using a transceiver module fitted with a RS-485 interface chip, select the RS485 Radio. This converts the transceiver’s RS-485 interface to serial, which is then converted to the interface selected by the COMM SELECT jumper. If not using a transceiver module fitted with a RS-485 interface chip, select the TTL Radio. When this jumper is moved to the RS232 Enable position, RS-232 communication is enabled through the DB9 connector (J2). When this jumper is moved to the RS485 Enable position, RS-485 communication is enabled through the RS-485 header pins. COMM SELECT (J12) When this jumper is moved to the Loopback Mode position, the transceiver TxD pin is tied to the transceiver RxD pin. This is only valid for AC5124, AC4424, AC4486, AC4490, AC4790, and AC4868 products. RTS mode must be disabled on the transceiver when Loopback Mode is enabled. This is incompatible with RS485 Radio selection. When this jumper is moved to the 40 Pin Header position, serial communication is enabled through the 40 pin header (J3). Depending on the transceiver used, signal levels must be either 3.3V or 5V. When this jumper is moved to the USB Enable position, USB communication is enabled through the USB Type B connector (J8). Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 5 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 Switch / Jumper Description RADIO VOLTAGE (J9) If this jumper is moved to the +5V Radio position, the transceiver is powered with 5V. If this jumper is moved to the +3.3V Radio position, the transceiver is powered with 3.3V. The AC4x90-1000, AC4868 and AC4x90-1x1 must have this jumper set to 3.3V. Note: FORCED CONFIGURATION (J11) Special care should be taken when setting this jumper. An improper setting can cause catastrophic damage to the transceiver. When this jumper is moved to the Normal Operation position, the transceiver communicates at the Baud Rate configured in the EEPROM. When the jumper is moved to the Forced 9600 Recovery position, the transceiver interface baud rate is forced to 9600 Baud upon reset. This is for EEPROM recovery only and should not be used in normal operation. POWER SOURCE (J7) When this jumper is moved to the Power Conn position, power is supplied to the SDK board through the power connector (J4). When this jumper is moved to the Batteries position, power is supplied to the SDK board through the two AA battery sockets on the bottom of the SDK board. Note: Special care should be taken when selecting batteries to power the SDK. High quality Alkaline batteries should be used. Do not mix battery types or batteries that have been used unequally as performance could suffer. Four Alkaline batteries produce a voltage of 6V. A minimum of 5.5V is required to power the SDK board. Power should be constantly monitored when using battery power. If USB Power is selected, the transceiver and development board receive power from the USB port. USB power should only be used for AC4486, AC4490, AC4790, and AC4868 product families. Most USB ports can only supply 500 mA of power max therefore it is recommended that USB power only be used with transceivers that draw less than 300 mA peak. Note: Though PCs should have over-current protection for their USB ports, drawing too much current through the USB port can cause damage to the PC and should be avoided. Table 2: Status LEDs LED Description +VCC Lights when power is applied to the serial adapter board. LOW POWER Monitors the 5V supply and lights when the supply dips below 4.8V. RESET Lights when the reset line to the processor is high, resetting the transceiver. TxD Lights when TXD line is low; a rapid flash occurs when data is sent from transceiver to host. RxD Lights when RXD line is low; a rapid flash occurs when data is received by transceiver from host. Forced 9600 Recovery Lights when 9600 Baud line is low; shows the FORCED CONFIGURATION jumper is set to force transceiver to 9600 Baud. The transceiver must be reset before it is forced to 9600. Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 6 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 LED Description IN RANGE With a client transceiver, it lights if the client transceiver is in range of a server transceiver with the same system ID and channel number. With a server transceiver, it always lights when the server is powered in normal mode and is ready to accept data. Status 1 Reflects the state of the Command/Data pin (AC4490, AC4486, AC4424, AC4790, AC4868), the TE pin (AC3124, AC1524) and the Pktmode pin (AC5124). This is controlled by the PC RTS pin when the Program Mode/Normal Mode switch is set to Program Mode. Lights when this pin goes low. Status 2 Lights when the Write Enable pin (AC4424 / 5124/ 3124 / 1524) or GI1 pin (AC4490 / 4486 / 4790 / 4868) goes low. Controlled by WR ENABLE and Gen IN 1 buttons. Table 3: AC4490 Only Section (AC4486, AC4790, and AC4868 Included) Description This varies the voltage (0 – 3.3V) presented to the AD In pin (pin 18). Will light when the GO0 pin (pin 1) is Low. Will light when the GO1 pin (pin 9) is Low. When depressed, will force the GI0 pin (pin 4) Low. When depressed, will force the GI1 pin (pin 14) Low. This probe point provides a location for measuring the DA_Out pin (pin 19). This probe point provides a GND reference location. Item Potentiometer/AD In Gen Out 0 LED Gen Out 1 LED Gen In 0 Pushbutton Gen In 1 Pushbutton DA_Out GND Table 4: DB9 (J2) Signal Definitions J2 Pin# J1 Pin# Signal Name Description 1 36 DCD Data Carrier Detect Direction I 2 14 RXD Receive Data I 3 16 TXD Transmit Data O 4 34 DTR Data Terminal Ready O 5 1,20,21,40 GND Ground 6 32 DSR Data Set Ready I 7 27 RTS Request To Send O 8 23 CTS Clear To Send I 9 19 RI Ring Indicator I Note: I/O direction is relative to the PC. Table 5: SDK Board to Transceiver Pin Definitions J1 Pin Type AC5124 Pin # # 1 2 GND I 1 2 AC5124 Signal Name GND PKTMODE Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp AC1524 AC3124 AC4424 AC4490 AC4486 AC4868 Pin # 5 AC1524 AC4424 AC3124 Signal Name Signal Name GND 17 TE 7 GND AC4490 AC4486 Signal Name GND Command/ Command/ Data Data AC4790 Signal Name AC4868 Signal Name GND GND Command/ Data Command/ Data CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 J1 Pin Type AC5124 Pin # # AC5124 Signal Name AC1524 AC3124 AC4424 AC4490 AC4486 AC4868 Pin # 10 AC1524 AC4424 AC3124 Signal Name Signal Name AC4490 AC4486 Signal Name AC4790 Signal Name AC4868 Signal Name 3 VCC 3 VCC VCC VCC VCC VCC VCC 4 NC 4 NC NC NC NC NC NC 5 VCC 5 VCC NC NC NC NC NC 6 NC 6 NC NC NC NC NC NC 7 NC 7 NC NC NC NC NC NC 8 NC 8 NC NC NC DA Out NC DA Out 9 NC 9 NC NC NC NC NC NC 10 NC 10 NC NC NC NC NC NC 11 O 11 RSSI RSSI RSSI RSSI RSSI NC 12 NC 12 NC NC NC NC NC NC 13 NC 13 NC NC NC NC NC NC 14 O 14 TXD 2 TXD TXD TXD TXD TXD 15 O 15 In Range 20 In Range In Range In Range Session Status In Range 16 I 16 RXD 3 RXD RXD RXD RXD RXD 17 I 17 RI_In NC NC NC NC NC 18 NC 18 NC NC NC NC NC NC 19 O 19 RI_Out 9 NC NC GO1 GO1 GO1 20 GND 20 GND 18 RE NC AD In AD In AD In 21 GND 21 GND NC NC NC NC NC 22 I 22 DCD_In NC NC NC NC NC 23 O 23 CTS CTS CTS CTS CTS CTS 24 NC 24 NC NC NC NC NC NC 25 NC 25 NC NC NC NC NC NC 9600 Baud 9600 Baud 19 13 7 I 26 BDSEL 12 Test Mode/ Packet Frame 27 I 27 RTS 8 NC RTS RTS RTS RTS 28 NC 28 NC NC NC NC NC NC 29 NC 29 NC NC NC NC NC NC 30 NC 30 NC NC NC NC NC NC 31 NC 31 NC 32 O 32 DSR 33 NC 33 NC 34 I 34 DTR 35 NC 35 NC 36 O 36 DCD_Out 1 37 I 37 Write Enable 14 38 I 38 μP _Reset 15 μP Reset 39 VCC 39 VCC 11 VCC 26 Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 6 9600 Baud/ Packet 9600 Baud Frame NC NC NC NC NC Hop Frame Hop Frame Hop Frame NC Hop Frame NC NC NC NC NC NC NC GI0 GI0 GI0 NC NC NC NC NC NC NC GO0 GO0 GO0 GI1 GI1 GI1 μP Reset μP Reset μP Reset μP Reset VCC VCC VCC VCC 4 Write Enable Write Enable 8 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 J1 Pin Type AC5124 Pin # # AC5124 Signal Name AC1524 AC3124 AC4424 AC4490 AC4486 AC4868 Pin # 16 AC1524 AC4424 AC3124 Signal Name Signal Name AC4490 AC4486 Signal Name AC4790 Signal Name AC4868 Signal Name 40 GND 40 GND GND GND GND GND GND I – Input to the transceiver O – Output from the transceiver NC – No Connection (though there is an internal connection in some instances, therefore, this pin should be left disconnected) Note: The 40 pin header (J1) on the SDK board maps directly (pin-for-pin) to the 40 pin connector (J3). Interfacing the AC DVK to RS232 Hardware The DVK serial board is defined as a DCE (Data Communications Equipment). DCE is wired to interface directly with DTE (Data Terminal Equipment). Typically, DTE is defined as a PC and DCE is defined as a peripheral. To interface DCE to other DCE or DTE to other DTE, a null modem is required. The null modem swaps pins to convert a DCE to a DTE and vice-versa. Normally, a null modem consists of a female and a male DB9 connector. A typical null modem configuration is shown below. Table 6: DTE, DCE and Null Modem Signal Definitions DCE Pin # DCE Signal Name DCE Direction DTE Pin # DTE Signal Name DTE Direction Null Modem Female DB9 Null Modem Male DB9 1 2 3 4 5 6 7 DCD TXD RXD DTR GND DSR RTS O O I I DCD RXD TXD DTR GND DSR RTS I I O O O I 1 2 3 4 5 6 7 I O 1 2 3 4 5 6 7 4 or NC 3 2 6 and 1 or NC 5 4 or NC 8 8 9 CTS RI O O 8 9 CTS RI I I 8 9 7 NC Interfacing the AC DVK to RS485 Hardware The SDK serial board has been designed to interface to RS-485 equipment. If such operation is desired, the COMM Select jumper should be set to RS485 Enable. The RS-485 circuitry used by the SDK board has been specially designed to negate the requirement for a DE/RE signal. Thus, the receiver is always enabled unless the transceiver has something to send to the OEM host. The OEM must ensure that the OEM host does not send data at the same time as the transceiver; otherwise a RS-485 contention occurs because the RS-485 hardware is half duplex. Table 7: RS-485 Header Pins RS-485 Pin Name Description A TRUE The non-inverted form of the serial data. This pin is at rest high. B INVERT The inverted form of the serial data (exact inversion of A TRUE). This pin is at rest low. GND GND Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 9 CONN-GUIDE-RAMP-AC-DVK-HW Ramp-AC RF DVK Hardware Version 1.0 RS-485 Pin Name Description +5V This is regulated 5V output from the serial board for general purpose use. A maximum of 100 mA should be drawn through this node. Power Requirements The serial board employs a National LM2940 linear regulator to regulate the incoming voltage to 5VDC. Due to heat dissipation limitations and current requirements, a maximum of 10VDC should be present at connector J4. A minimum of 5.5V should also be present at the connector. Americas: +1-800-492-2320 Option 2 Europe: +44-1628-858-940 Hong Kong: +852-2923-0610 wireless.support@lairdtech.com www.lairdtech.com/ramp 10 CONN-GUIDE-RAMP-AC-DVK-HW
DVK-AC4490-200A 价格&库存
很抱歉,暂时无法提供与“DVK-AC4490-200A”相匹配的价格&库存,您可以联系我们找货
