FVS.03.250.CLCE31
FVS.03.250.CLCE31
    LEMO(雷莫)
    CONN INLINE PLUG COAX PIN CRIMP
FVS.03.250.CLCE31 数据手册
HIGH PRESSURE CONNECTORS ® ® Precision modular connectors to suit your application Since it’s creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 50’000 connectors The modular design of the LEMO range provides over 50’000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 106 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System (not shown in this catalogue) This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are approved. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications exceed the requirements of the RoHS directives (2002/95/EC) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. LEMO guarantees that its connectors are free of mercury, cadmium, lead, hexavalent chromium and polybromide biphenyl (PBB), polybromide diphenyl ether (PBDE), or DecaBDE. www.lemo.com ® ® 03 Series This series of connectors stems from the series 00 and has been specifically developed for applications where the connection must be guaranteed under very high pressure. The push-pull latching system has been replaced by a screw coupling system with watertightness maintained by compression of an O-ring in FPM (Viton®) according to the triangular shaped cavity principle. There are multiple application possibilities, from aerospace to the petroleum industry. After cable assembly, the rear part must be covered with an adhesive heatshrink boot in order to ensure watertightness on the cable side. 03 series connectors provide the following main features: – coaxial 50 Ω type – multipole with 2, 3 or 4 contacts – 360° screening for full EMC shielding – rugged housing for extreme working conditions – working pressure that can exceed 60 bars in mated conditions Multipole Type (302, 303, 304) Models (page 3) Vacuumtight models (page 5) Straight plugs Straight plugs FVG FVG FVG FVG Fixed sockets Fixed sockets Free sockets PVG HVG HWG PVG HRG HTG PVG Coaxial Type (50 Ω) Models (page 6) Vacuumtight models (page 8) Straight plugs Straight plugs FVN FVN FVS FVR Fixed socket Fixed sockets Free sockets PVN HVP HVL HVR HVW www.lemo.com 1 ® ® Part Numbering System Plug FV G . 03 . 302 . C L A C 27 Free socket PV G . 03 . 302 . C L L C 27 Variant: (page 10) Cable ø Collet type: C = cable collet E = crimping K = oversized cable collet HV G . 03 . 302 . C Fixed socket L L P V V = vacuumtight Model: (page 3-8) Sealing epoxy resin: P = Araldite® S = Stycast® Alignment key: (page 9) (only for multipole) Contact: (page 10) Series: 03 Insulator: L = PEEK Insert configuration: – Multipole (page 9) – Coax (page 9) Housing: (page 9) Part Number Example Straight plug with cable collet: FVG.03.302.CLAC27 = straight plug with key (G) and cable collet, 03 series, multipole type with 2 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 2.7 mm diameter cable. Free socket: PVG.03.302.CLLC27 = free socket with key (G) and cable collet, 03 series, multipole type with 2 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts, C type collet for 2.7 mm diameter cable. Fixed socket: HVG.03.302.CLLPV = fixed socket, nut fixing, with key (G), 03 series, multipole type with 2 contacts, outer shell in chromeplated brass, PEEK insulator, female solder contacts, sealed with Araldite® epoxy resin. Part Section Showing Internal Components (multipole) Straight plug Fixed socket 1 outer shell 2 3 4 5 6 7 8 9 earthing crown retaining ring hexagonal nut locking washer insulator female contact o-ring epoxy resin 1 outer shell 9 4 5 3 2 6 8 7 1 1 6 11 5 2 11 10 4 7 11 9 8 3 2 coupling nut 3 collet nut 4 centre-piece 5 insulator 6 male contact 7 earthing cone 8 collet 9 compression ring 10 circlip 11 o-ring 2 www.lemo.com ® ® Models (multipole type) Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Standard Endurance Humidity Temperature range Salt spray corrosion test Protection index 2) > 1000 cycles IEC 60512-5 test 9a up to 95% at 60° C -20° C, +200° C > 144 h IEC 60512-6 test 11f > IP68 IEC 60529 Resistance to hydrostatic pressure 2) ~ 60 bars 1) IEC 60512-7 test 14d Climatical category 20/200/21 IEC 60068-1 Note: 1) in order to perform correctly and withstand the pressure, cable assembly shall be made according to instruction we recommand. See page 11. 2) For mated plug and socket. Characteristics Value Standard Section Insulation resistance (new) Insulation resistance 3) Shell electrical continuity at 10 MHz Shielding efficiency at 1 GHz Contact resist. 4) ø A = 0.5 mm ø A = 0.7 mm Contact resist. 4) > 1012 Ω > 1010 Ω 5.0 mΩ > 100 dB > 80 dB ≤ 8.7 mΩ ≤ 6.1 mΩ IEC 60512-2 IEC 60512-2 IEC 60512-2 IEC 60169-1-3 IEC 60169-1-3 IEC 60512-2 IEC 60512-2 test 3a test 3a test 2f test 2a test 2a Note: 3) after humidity test: 21 days at 95% RH according to IEC 60068-2. 4) after 5000 mating cycles and the salt spray test according to IEC 605126 test 11 f. FVG Straight plug, key (G) or key (B), cable collet Part number 33.7 FVG.03.30●.CLAC27 FVG.03.30●.SLAC27 FVG.03.30●.CLAC31 FVG.03.30●.SLAC31 ø 11.8 25.5 Cable ø (mm) min. max. 2.4 2.4 2.7 2.7 2.6 2.6 3.0 3.0 Note: ● = insert configuration (page 9) S5 S 11 FVG Straight plug, key (G) or key (B), cable collet and nut for fitting a bend relief Part number 38.5 ø 11.8 30.3 S6 FVG.03.30●.CLAC27Z FVG.03.30●.SLAC27Z FVG.03.30●.CLAC31Z FVG.03.30●.SLAC31Z Cable ø (mm) min. max. 2.4 2.4 2.7 2.7 2.6 2.6 3.0 3.0 Note: ● = insert configuration (page 9). The bend relief must be ordered separately (page 10) S 11 FVG Straight plug, key (G) or key (B) and oversize cable collet Part number FVG.03.30●.CLAK35 FVG.03.30●.CLAK40 FVG.03.30●.CLAK45 FVG.03.30●.CLAK50 38.7 ø 11.8 30.5 S7 www.lemo.com S7 S 11 Cable ø (mm) min. max. 3.1 3.6 4.1 4.6 3.5 4.0 4.5 5.0 Note: ● = insert configuration (page 9) Correspond to K type of collet. Also available with nut for fitting a bend relief. 3 ® ® FVG Straight plug, key (G) for cable crimping Part number Cable ø (mm) max. FVG.03.30●.CLAE44 FVG.03.30●.SLAE44 FVG.03.30●.CLAE52 FVG.03.30●.SLAE52 34.7 ø 11.8 26.5 4.3 4.3 5.1 5.1 Note: ● = insert configuration (page 9) S 11 PVG Free socket, key (G) and cable collet Part number 36.7 PVG.03.30●.CLLC27 PVG.03.30●.CLLC31 ø 11.8 32.7 S5 Cable ø (mm) min. max. 2.4 2.7 2.6 3.0 Note: ● = insert configuration (page 9) S 11 PVG Free socket, key (G), cable collet and nut for fitting a bend relief Part number 41.5 PVG.03.30●.CLLC27Z PVG.03.30●.CLLC31Z ø 11.8 37.5 S6 Cable ø (mm) min. max. 2.4 2.7 2.6 3.0 Note: ● = insert configuration (page 9). The bend relief must be ordered separately (page 10) S 11 PVG Free socket, key (G) and oversize cable collet Part number 52.7 ø 11.8 48.7 S7 4 S7 S 11 PVG.03.30●.CLLK35 PVG.03.30●.CLLK40 PVG.03.30●.CLLK45 PVG.03.30●.CLLK50 Cable ø (mm) min. max. 3.1 3.6 4.1 4.6 3.5 4.0 4.5 5.0 Note: ● = insert configuration (page 9) Correspond to K type of collet. Also available with nut for fitting a bend relief. www.lemo.com ® ® Vacuumtight models (multipole type) These sockets models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratoryequipment, aviation, etc. These models are identified by a letter «P» or «S» at the last but one character of the reference. The Stycast® sealant can be used over a larger temperature range than the Araldite® sealant. All these models are available in a watertight or vacuumtight version. Vaccumtight models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range Salt spray corrosion test Value Standard > 1000 cycles IEC 60512-5 test 9a up to 95% at 60° C -20° C, +100° C > 144h IEC 60512-6 test 11f M7x0.5 Climatical category Leakage rate (He) 1) Max. operating pressure 2) ø 11 ø 10.2 HVG.03.30●.CLLPV HVG.03.30●.SLLPV HVG.03.30●.CLLSV HVG.03.30●.SLLSV 6.5 maxi Sealing resin Araldite® Araldite® Stycast® Stycast® Panel cut-out (page 11) Note: ● = insert configuration (page 9) HWG Fixed socket, key (G), hexagonal flange, nut fixing, vacuumtight 21 S 11 6 ø 11.8 ø 10.2 Part number 6.5 maxi S 6.3 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b 60 bars IEC 60512-7 test 14d Note: 1) only for vacuumtight models. 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. Part number S9 Standard S9 6 S9 Value HVG Fixed socket, key (G) or key (B), round flange, nut fixing, vacuumtight 22 M7x0.5 Characteristics HWG.03.30●.CLLPV HWG.03.30●.CLLSV Sealing resin Araldite® Stycast® Panel cut-out (page 11) Note: ● = insert configuration (page 9) HRG Fixed socket, key (G), hexagonal flange, nut fixing, no flats on fixing thread, vacuumtight 22 M7x0.5 S 11 6 ø 10.2 ø 11.8 Part number 6.5 maxi S9 HRG.03.30●.CLLPV HRG.03.30●.SLLPV HRG.03.30●.CLLSV HRG.03.30●.SLLSV Sealing resin Araldite® Araldite® Stycast® Stycast® Panel cut-out (page 11) Note: ● = insert configuration (page 9) M7x0.5 HTG Fixed socket, key (G), nut fixing, long shell S9 ø 11 ø 10.2 26 Part number HTG.03.30●.CLLSV Sealing resin Stycast® S9 Panel cut-out (page 11) Note: ● = insert configuration (page 9) www.lemo.com 5 ® ® Models (coaxial type) Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Standard Endurance Humidity Temperature range Salt spray corrosion test Protection index 2) > 1000 cycles IEC 60512-5 test 9a up to 95% at 60° C -20° C, +200° C > 144 h IEC 60512-6 test 11f > IP68 IEC 60529 Resistance to hydrostatic pressure 2) ~ 60 bars 1) IEC 60512-7 test 14d Climatical category 20/200/21 IEC 60068-1 Note: 1) in order to perform correctly and withstand the pressure, cable assembly shall be made according to instruction we recommand. See page 11. 2) For mated plug and socket. Characteristics Value Insulation resistance (new) Insulation resistance 3) Shell electrical continuity at 10 MHz Shielding efficiency at 1 GHz Contact resist. 4) ø A = 0.5 mm ø A = 0.7 mm Contact resist. 4) Max. working frequency > 1012 Ω > 1010 Ω 5.0 mΩ > 100 dB > 80 dB ≤ 8.7 mΩ ≤ 6.1 mΩ 500 MHz Standard Section IEC 60512-2 test 3a IEC 60512-2 test 3a IEC 60512-2 test 2f IEC 60169-1-3 IEC 60169-1-3 IEC 60512-2 test 2a IEC 60512-2 test 2a For coaxial type Note: 3) after humidity test: 21 days at 95% RH according to IEC 60068-2. 4) after 5000 mating cycles and the salt spray test according to IEC 605126 test 11 f. FVN Straight plug, cable collet Part number 29.5 FVN.03.250.CLAC27 FVN.03.250.SLAC27 FVN.03.250.CLAC31 FVN.03.250.SLAC31 ø 11.8 21.2 S 4.5 Cable group 4 4 3 3 Cable assembly (page 11) S 11 FVN Straight plug, cable collet and nut for fitting a bend relief Part number 38.5 ø 11.8 30.3 FVN.03.250.CLAC27Z FVN.03.250.SLAC27Z FVN.03.250.CLAC31Z FVN.03.250.SLAC31Z Cable group 4 4 3 3 Cable assembly (page 11) S6 S 11 Note: The bend relief must be ordered separately (page 10) FVS Straight plug for cable crimping Part number 35.3 FVS.03.250.CLAE24 FVS.03.250.CLCE24 FVS.03.250.CLCE31 ø 11.8 26.5 S 5.5 6 Cable group 1 1 3-4 Cable assembly (page 11) S 11 www.lemo.com ® ® FVR Straight plug with brazing ferrule Part number 32.9 FVR.03.250.SLAV16B FVR.03.250.SLAV20B ø 11.8 24.6 Cable ø (mm) max. 1.55 1.95 Cable assembly (page 11) Note: The shell of the connector is in stainless steel AISI 316L. S 11 PVN Free socket and cable collet Part number Cable group 36.7 PVN.03.250.CLLC27 PVN.03.250.CLLC31 ø 11.8 32.7 S 4.5 www.lemo.com 4 3 Cable assembly (page 11) Note: Also available with nut for fitting a bend relief (page 10). S 11 7 ® ® Vacuumtight models (coaxial type) These sockets models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratoryequipment, aviation, etc. These models are identified by a letter «P» or «S» at the last but one character of the reference. The Stycast® sealant can be used over a larger temperature range than the Araldite® sealant. All these models are available in a watertight or vacuumtight version. Vaccumtight models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range Salt spray corrosion test Value Standard > 1000 cycles IEC 60512-5 test 9a up to 95% at 60° C -20° C, +100° C > 144h IEC 60512-6 test 11f Climatical category Leakage rate (He) 1) Max. operating pressure 2) S 11 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b 60 bars IEC 60512-7 test 14d 6 ø 11.8 ø 10.2 S9 6.5 maxi HVR.03.250.CLLPV HVR.03.250.SLLPV HVR.03.250.CLLSV HVR.03.250.SLLSV Sealing resin Araldite® Araldite® Stycast® Stycast® Panel cut-out (page 11) HVP Fixed socket, round flange, nut fixing, vacuumtight 21 M7x0.5 Standard Note: 1) only for vacuumtight models. 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. Part number S9 6 ø 11 ø 10.2 Part number S9 Value HVR Fixed socket, hexagonal flange, nut fixing, vacuumtight 21 M7x0.5 Characteristics HVP.03.250.CLLPV HVP.03.250.CLLSV Sealing resin Araldite® Stycast® 6.5 maxi Panel cut-out (page 11) Part number ø 13.9 24.2 M10x0.75 HVL Free socket, for device overmolding HVL.03.250.NLL S 11 ø 19.9 18 HVW Free socket, for device overmolding, large shell M10x0.75 28 Part number HVW.03.250.NLL Note: Vacuumtightness is achieved after customer overmolding. S 11 8 www.lemo.com ® ® Alignment Key Alignment Key and Polarized Keying System for Multipole Types α Nb of keys G B 1 2 Angles Front view of a socket Model 03 series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position and the contact type (male or female). α Series Contact type 03 Plug Socket 0° 60° male male female female Insert configuration Test voltage (kV rms)1) Contact-shell Rated current (A)1) 2 Test voltage (kV rms)1) Contact-contact 3 Impedance (Ω) 3 AWG max. 2 Cable group 1 ø A (mm) 4 Number of contacts 4 250 1 0.7 1-3-4 – 50 2.1 2.10 4.0 302 2 0.5 – 30 – 1.0 0.95 5.0 303 3 0.5 – 30 – 0.8 0.95 3.0 304 4 0.5 – 30 – 0.8 0.95 2.0 øA 1 Reference Coaxial, multipole Male solder contacts Female solder contacts Coaxial 03 Multipole Note: 1) Test voltage measured according to IEC 60512-2 test 4a standard. Housings Ref. C S Outer shell and collet nut Latch sleeve + earthing crown Other metallic components Material Surf. treatment Material Surf. treatment Material Surf. treatment Brass Stainless steel chrome – brass/bronze brass/bronze nickel nickel brass brass nickel nickel Remarks For multipole and coaxial For multipole and coaxial Note ● ● Note: detailed characteristics of these materials and treatments are presented in the Unipole-Multipole catalogue. ● First choice alternative ● Special order alternative www.lemo.com 9 ® ® Contacts Contact type Ref. A C L Remarks Male solder Male crimp Female solder For multipole and coaxial For coaxial For multipole or coaxial type sockets Variant Bend relief for models with collet Need to be ordered Dim. (mm) Cable ø max. min. Type Code Need to be ordered separately Z C C C C 27 31 27 31 GMB.00.025.DG GMB.00.028.DG GMD.00.025.DG GMD.00.028.DG 2.8 3.1 2.8 3.1 2.5 2.8 2.5 2.8 Z K K K K 35 40 45 50 GMA.0B.030.DG GMA.0B.035.DG GMA.0B.040.DG GMA.0B.045.DG 3.4 3.9 4.4 5.2 3.0 3.5 4.0 4.5 Ref. 03 Collet Note: The «GMD» are thin bend reliefs (for very flexible cables). The last letter «G» of the part number indicates the grey colour of the bend relief. Accessories and Tooling For accessories and tooling, please contact us. 10 www.lemo.com ® ® Panel cut-outs Panel Cut-outs HWG HRG, HTG, HVG, HVP, HVR 13 6.4 +00.1 ø 7.1+00.1 13 ø 7.1+00.1 Mounting nuts torque Component Retaining nut Hexagonal nut Coupling nut Torque (Nm) 0.25 2.00 2.00 1N = 0.102 kg Cable assembly Assembly instructions In order to ensure the sealing of plugs and sockets on the cable side, it is imperatively necessary to complete their assembly by realizing it with an adapted technique. We recommend the fitting of an heatshrink boot with inner melting coating of type ATUM (manufactured by the RAYCHEM company) or similar. This heatshrink boot is not provided with the connector. Please consult us. Connector L T Series 03 S Type 250 302/303/304 302/303/3041) ø contact A (mm) Cable stripping lengths 0.7 0.5 0.5 Cable stripping lengths (mm) L S T 6 6 13.5 2.5 2.5 – 3 3 2.5 Note: the tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. 1) for FVG model with cable crimping. Recommended coaxial cables Recommended cables for coaxial types Standard IEC 96-2 CCTU 10-01A Cable group MIL-C-17 3 RG.174 A/U 50.2.1 1 4 1 4 RG.178 B/U RG.188 A/U RG.196 A/U RG.316 /U 50.1.1 50.2.3 50.1.2 50.2.2 www.lemo.com KX 3A KX 38 KX 21A KX 22A Reference CCX.50.RG1.74AU27N CCX.50.RG1.74U25N CCX.50.RG1.78BU18M CCX.50.RG1.88AU24B CCX.50.RG1.96AU20B CCX.50.RG3.16BU26M Imp. (Ω) 50 ± 2 Ω 50 ± 2 Ω 50 ± 2 Ω 50 ± 2 Ω 50 ± 2 Ω 50 ± 2 Ω 11 ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 12 www.lemo.com LEMO complete product range B K • Unipole Multipole S • • E F 00 01 0A 3T 4A 4M 3K. 1D 93C Y 05 5G 2G 2C L • • • H R N 03 V W U F P D K/S 01 DIN • • • Coaxial 50 Ω Coaxial 75 Ω Multi Coaxial Mixed Coax + LV Triaxial 50 Ω Triaxial 75 Ω Mixed Triax + LV • Quadrax High Voltage Multi High Voltage Mixed HV + LV Fibre Optic Multi Fibre Optic Mixed FO + LV Thermocouple Fluidic Multi Fluidic Mixed Fluidic + LV Most frequently used in darker colour • included in this catalogue B Series Keyed S Series K Series Keyed E Series F Series Keyed 00 Series 01 Series 0A Series 3T Series 4A Series 4M Series Keyed 3K.93C Series Keyed 1D Series Y Series 05 Series 5G Series Keyed 2G Series Keyed 2C Series L Series Keyed H Series R Series Keyed N Series Keyed 03 Series Keyed V Series W Series Keyed U Series Keyed Cable assembly K/S Series Keyed REDEL F Series REDEL P Series Keyed REDEL D Series 01 Series Keyed VAA Series SAA Series TAA Series No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 2108 1967 DC Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Trading (Shanghai) Co., Ltd LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 redelemo@lemo.hu ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com JAPAN LEMO Japan Ltd 4-10-3, Takaido Higashi, Suginami-ku, Tokyo, 168-0072 Tel: (+81 3) 53 44 39 33 Fax: (+81 3) 53 44 39 35 lemoinfo@lemo.co.jp LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO S.A. Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.03.LEN.P1008 LEMO
FVS.03.250.CLCE31 价格&库存
很抱歉,暂时无法提供与“FVS.03.250.CLCE31”相匹配的价格&库存,您可以联系我们找货
