SFT-10-RA-R35-MPA
SFT-10-RA-R35-MPA
    LUMINUS(朗明纳斯)
    LED
SFT-10-RA-R35-MPA 数据手册
SFT-10 Product Datasheet SFT-10 LED Chipset in SMT and Starboard Configurations Features: • Matched R/CG/B Chipset with 1.0mm2 emitting area designed for mid to high currentdensity 0.2” / 0.3” Pico projection applications Table of Contents • Thermally efficient SMT Package: Rth J-C = 3.0º C/W Technology Overview. . . . . . 2 • Available either in “Standard” (SMT) or Pre-Mounted “Starboard” Configurations Understanding SMT Test Specifications. . . . . . . . . . . . . . 2 • Available “Starboard” Packaging Configuration allows ease of evaluation and/or immediate system integration Ordering / Bin Kits. . . . . . . 3 - 5 Standard Test Condition. . . . 6 Optical & Electrical Characteristics. . . . . . . . . . . . . 7 Absolute Maximums . . . . . . . 8 Characterization . . . . . . . 9-12 • 100% surface emission for high collection efficiency and low optical losses • Wide color gamut with the most desireable dominant wavelengths: Red-Amber 613 nm, Converted Green (filtered spectrum) 555nm, and Blue 455 nm • Single emitting area per color allows for efficiency of collection with simplified optics • Environmentally friendly: RoHS and REACH compliant • Characterized correlation between “Test” and real-world Display applications are provided. Thermal Resistance . . . . . . . 13 Mechanical Dimensions.13-15 Solder Profile . . . . . . . . . . . . . 16 Applications Packing and Shipping Information . . . . . . . . . . . 17-18 • Specifically engineered for stand alone, embedded, or battery-assisted projection display applications. History of Changes. . . . . . . . 19 • Entertainment / Stage Lighting • Medical / Life Science • Industrial • Transportaion / Beacons • High performance illumination 1 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datsheet Technology Overview Luminus Devices’ SFT series of illuminators is an innovative small form factor solid-state light source created for applications requiring high current density in a small area. With its thermally effiicent package, the SFT-10 chipset allows the end-product to deliver all the benefits of small, high performing solid state light sources. The SFT series is environmentally friendly (Mercury-free), enables instant start and re-start with no wait time, high reliability, and long life requiring no end-user or field replacement. Response time is quick enabling frame-by-frame color control with compatible ASIC control chipsets for projection applications. Innovative Packaging Technology Environmental Benefits Thermal management is critical in high power LED applications. With a low thermal resistance from junction SFT-10 LEDs can be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Reliability SFT-10 has passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in high power / small form factor / high current applications pico applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus SFT-Series LEDs are ready for even the most demanding applications. (Please refer to Luminus’ Reliability application note for more information.) Understanding SMT Test Specifications Every Luminus LED is tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing of SMT LEDs The Luminus SFT series of products are measured in such a way that allows high volume / fast paced (single pulse) production but accurate measurement that correlates with real world operating conditions. Luminus makes available to it’s customers correlation curves (page 8) that allow one to predict with significant accuracy performance in typical “Display” applications. 2 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datsheet Ordering Information (SMT Configuration)1,3 Ordering Part Number 1,3 SFT-10-RA-F35-MPA Min Flux Bin 2 Color 1A Red Amber SFT-10-RA-F35-MPB 1B SFT-10-CG-F35-MPA 2A Converted Green SFT-10-CG-F35-MPB SFT-10-CG-F35-MPC SFT-10-B-F35-EPA 2B 2C 4A Blue SFT-10-B-F35-EPB 4B Description Configuration Red-Amber LED consisting of a 1.0 mm2 die mounted on a small 3.5 x 3.5mm high-performance package with directional indicator. Converted Green consisting of a 1.0 mm2 die Blue die mounted on a small 3.5 x 3.5mm high-performance package driving a Green Phosphor Platelet, with directional indicator. Blue LED consisting of a 1.0 mm2 die mounted on a small 3.5 x 3.5mm high-performance package with directional indicator. Ordering Information (Starboard Configuration)1, 3, 4 Ordering Part Number 1,3 Min Flux Bin 2 Color SFT-10-RA-R35-MPZ SFT-10-RA-R35-MPA SFT-10-RA-R35-MPB SFT-10-CG-R35-MPA SFT-10-CG-R35-MPB SFT-10-CG-R35-MPC 1Z Red Amber 1A 1B Converted Green SFT-10-B-R35-EPA 2A 2B 2C 4A Blue SFT-10-B-R35-EPB 4B Description Configuration Red-Amber LED consisting of a 1.0 mm2 die in a small 3.5 x 3.5mm package mounted on a thermally efficient and pedestal, common cathode designed starboard. Converted Green LED consisting of a 1.0 mm2 die with Green Phosphor Platelet in a small 3.5 x 3.5mm package mounted on a thermally efficient and pedestal, common cathode designed starboard. Blue LED consisting of a 1.0 mm2 die in a small 3.5 x 3.5mm package mounted on a thermally efficient and pedestal, common cathode designed starboard. Note 1: Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) Note 2: See Bin Kit and Flux bin definitions on page 5. Note 3: Bin Kits are defined by a group of flux or power bins. Only one flux / power bin will be shipped in each indivdiual pack or reel. Each shipment will contain reels of different allowed bins for a specific orderable part number (See page 5) Indivdual Flux or Power bins are not orderable Note 4: Starboard Configuration are available for sample quantity only. For additional quantity, contact Luminus representitive. SFT nn Product Family SFT: Small FlatTop windowless format Note : Ordering Part Number Nomenclature XXXX XXX Chip Area Color 10: 1.0 mm2 RA = Red - Amber CG = Converted Green B= Blue Package Configuration F35: 3.5mm x 3.5mm See Mechanical Drawing section R35: SFT-10 mounted on Starboard Starboard only in sample quantity XYZ Bin Kit 1 See page 5 for bin kit definition A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLES: SFT-10-CG-F35-MPC is comprised of Converted Green Flux Bins 2C, 2D, 2E , and 2F, 3 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA USA SFT-10 Product Datsheet PACKAGE CONFIGURATIONS Package Configuration 1 Type Picture Description Standard configuration F35 SMT A 1.0 mm2 die mounted on a small 3.5 x 3.5mm high-performance package with directional indicator. Pre-Mounted Configuration. R35 The standard SFT-10 SMT Package pre-mounted on a Luminus thermally efficient and pedestal, common cathode designed copper 19.9 x 19.9mm starboard. See page 15. STARBOARD Starboard only in sample quantity. Contact Luminus representitive for additional requirements. Starboard requires electrical isolation in most system designs. Starboard backside is connected to LED cathode. Note 1: The packaging configuration must be specified within the orderable part number. If not specified, or invalid, the order may be rejected or default to the “F35” (Standard) configuration. Ordering Part Number Nomenclature SFT nn Product Family SFT: Small FlatTop windowless format XXXX XXX Chip Area Color 10: 1.0 mm2 RA = Red - Amber CG = Converted Green B= Blue Package Configuration2 F35: 3.5mm x 3.5mm See Mechanical Drawing section R35: SFT-10 mounted on Starboard Starboard only in sample quantity XYZ Bin Kit 1 See page 5 for bin kit definition Note 1: A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLES: SFT-10-CG-F35-MPC is comprised of Converted Green Flux Bins 2C, 2D, 2E , and 2F, Note 2: Starboard only in sample quantity. Contact Luminus representitive for additional requirements. 4 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA USA SFT-10 Product Datsheet SFT-10 Bin Kit1 and Flux Bin3,4 Definitions Note: Please refer to ordering part number table on page 3 for Bin Kit availability Red -Amber Flux Bins Bin 1Z Bin 1A Bin 1B Bin 1C Bin 1D Bin 1E Bin 1F Bin 1G Bin 1H Red -Amber Bin Flux Range (lm) 80 - 90 90 - 100 100 - 110 110 - 120 120 - 130 130 - 145 145 - 155 155 - 170 170 - 185 þ þ þ þ þ Conv Green Flux Bins Bin 2A Bin 2B Bin 2C Bin 2D Bin 2E Bin 2F Bin 2G Bin 2H Conv Green Bin Flux Range (lm) 200 - 215 215 - 240 240 - 260 260 - 285 285 - 305 305 - 325 325 - 350 350 - 380 þ þ þ þ þ þ þ þ SFT-10-RA-F35-MPA SFT-10-CG-F35-MPC SFT-10-CG-F35-MPD Blue Power Bins Bin 4A Bin 4B Bin 4C Bin 4D Bin 4E Bin 4F Bin 4G Bin 4H Blue Optical Power Range (W/mm2) 0.65 0.70 0.70 0.75 0.75 0.85 0.85 0.95 0.95 1.05 1.05 1.15 1.15 1.25 1.25 1.35 þ þ þ þ þ þ þ SFT-10-B-F35-EPC SFT-10-B-F35-EPD þ Wavelength Dominent Bin2 Definitions Color Bin Minimum WLD (nm) Maximum WLD (nm) Red-Amber R1 609 615 Red-Amber R2 615 621 Blue B1 449 455 Blue B2 455 460 Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux / power bin will be shipped in each individual pack or reel. Each shipment will contain reels of different allowed bins for a specific orderable part number. Individual Flux or Power bins are not ordereable. Note 2: Wavelength bins are not orderable. Wavelength bins are displayed in product label. Note 3: Packaging configuration must be specified in purchase order. Otherwise, order will either be rejected or default to the “F35” (Standard) configuration. For “StarBoard” configuration, “R35” should be used as package configuration code. Refer to Ordering Part Number Nomenclature on Page 4. Note 4: SFT-10 LEDs are tested according to the process outlined on page 6. Devices are sorted and packed by flux bin. Not all flux bins are populated. Contact your local LDI representative for current production population. Note 5: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. 5 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA USA SFT-10 Product Datsheet STANDARD TEST CONDITION All performance metrics of the SFT-Series of LED’s are characterized from a single current “PULSE” 1, 2, 3 The pulse duration is 20ms, and the applied current is 0.7A. Rise and Fall times of the signal are negligible. Applied Current if A Time - t (ms) Note 1: Environmental temperature is assumed to be Ambient. (25C typ) Note 2: Due to the brief nature of this test, Tj (Junction Temperature) is assumed to be ambient or approx 25C. Note 3: Luminus maintains a tolerance of +/- 6% on flux measurements 6 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA USA SFT-10 Product Datasheet Optical & Electrical Characteristics General Characteristics Symbol Red -Amber Converted Green Blue* Unit 1.0 1.0 1.0 mm2 1.0 x 1.0 1.0 x 1.0 1.0 x 1.0 mm x mm Emitting Area Emitting Area Dimensions Performance at Standard Test Conditions (See definition on p5) Peak Luminuous Flux 1,2,5 typ Φv 120 259 34 lm Peak Radiometric Flux 1,2 typ Φr 0.42 0.55 0.88 W Dominant Wavelength min λdmin 609 545 449 typ λd 613 555 455 max λdmax 621 565 461 16 98 19 nm FWHM- Spectral bandwidth at 50% of Φv typ Chromaticity Coordinates 6,7 typ x 0.66 0.33 0.14 CIE x typ y 0.32 0.56 0.04 CIE y min VF min 2.2 2.5 2.5 typ VF 2.5 3.0 3.0 max VF max 3.0 3.6 3.6 Forward Voltage V Correlated Performance in Typical Display Application (2.5A/mm @ 40C) [Reference Only]. See curves starting on p8. 2 Reference Drive Current typ Reference Duty Cycle typ Luminous Flux typ Radiometric Flux Dominant Wavelength FWHM -Spectral bandwidth at 50% of Φv Chromaticity Coordinates 6,7 Forward Voltage IF 2.5 2.5 2.5 A 25 50 25 % Φv 300 650 100 lm typ Φr 1.1 1.4 2.0 W typ λd 613 555 453 15 99 19 typ typ x 0.66 0.32 0.14 typ y 0.33 0.55 0.04 typ VF 3.6 3.5 3.4 nm V Note 1: All ratings are based on standard testing conditions unless specified otherwise. Note 2: Parameters rated at Standard Test condition as defined on page 6. Note 3: Duty Cycle used to specify device ratings under Pulsed operation. SFT-Series of LEDs can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 4: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds. Note 6: CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1. Note 7: For Reference only. 7 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet Optical & Electrical Characteristics Absolute Maximum Ratings Red Amber Converted Green Blue Unit Absolute Minimum Current (CW or Pulsed)1 200 200 200 mA Absolute Maximum Current (CW)2 2.5 3.0 3.0 Symbol Absolute Maximum Reverse Drive Drive Current (CW or Pulsed) 0, REVERSE CURRENT OPERATION IS NOT ALLOWED A Absolute Maximum Current (Pulsed) 2,3 (Frequency > 240 Hz, duty cycle 240 Hz, duty cycle =10%, t= 1ms) 4.0 4.0 4.0 110 150 150 -40 / +100 -40 / +100 -40 / +100 Absolute Maximum Junction Temperature 4 Storage Temperature Range Tjmax C o Note 1: Product performance and lifetime data is specified at recommended forward drive currents. Sustained operation at or near absolute minimum currents may result in a reduction of device performance and device lifetime compared to recommended forward drive currents. Note 2: Sustained operation above maximum currents is not recommended and will result in a reduction of device lifetime compared to specified maximum forward drive currents. Device lifetimes will depend on junction temperature. (See Reliability Application Note, APN-001444 for product lifetimes as function of junction temperature.) Please refer to lifetime de-rating curves (available from Luminus ) for further information. Note 3: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds. Note 4: Sustained operation at Absolute Maximum Operating Junction Temperature (Tjmax) will result in reduced device life time. 8 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA Preliminary SFT-10 Product Datasheet Normalized Luminous Flux vs. Forward Current (Ths= 25oC, If = Pulse) SFT-10-RA vs. Tj (If = 0.7A Pulse) SFT-10-RA SFT-10-CG SFT-10-CG SFT-10-B SFT-10-B 9 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA Preliminary SFT-10 Product Datasheet Relative Forward Voltage vs. Forward Current (Ths= 25oC, If = Pulse) SFT-10-RA vs. Tj (If = 0.7A Pulse) SFT-10-RA SFT-10-CG SFT-10-CG SFT-10-B SFT-10-B 10 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA Preliminary SFT-10 Product Datasheet RELATIVE DOMINANT WAVELENGTH vs. Forward Current (Ths= 25oC, If = Pulse) SFT-10-RA vs. Tj (If = 0.7A Pulse) SFT-10-RA SFT-10-CG SFT-10-CG SFT-10-B SFT-10-B 11 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet SFT-Series Optical Spectrum (Typical) 1 Angular Intensity Distribution (Typical) 1 SFT-10-RA SFT-10-CG SFT-10-B Note 1: Data is recorded using standard test conditions and tolerances as described on page 6. 12 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet Thermal Resistance Typical Thermal Resistance RJ-C1, 2 3.0º C/W Note 1: Thermal resistance values are based on FEA model results correlated to measured Rθj-hs data. Note 2: System Thermal Characteristics will be dependent on customer-side thermal strategy. Note 3: For optimal results, Luminus recommends customer PCB Design in accordance with suggestion provided by the Luminus application note, “Design Guidelines for SFT Chipset Assembly”. Electrical Pinout / Solder Pad Layout Note: Layout is common to all colors. For recommended solder profiles, see page 16 Optimal LED performance is dependent on a proper system design. Please review the Luminus application note, “Design Guidelines for SFT Chipset Assembly.” Contact Luminus for more detail. 13 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet Mechanical Dimensions - SFT-10 [Red / Blue] Mechanical Dimensions - SFT-10 [Converted Green] Notes: Converted Green differs from RED/BLUE in only the emitting surface is slightly larger than the underlaying die. 14 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet Mechanical Dimensions - “Starboard” Package Configuration Notes: Dimensions shown are of bare Starboard. For full detail, please see DWG 400845 available from your local Luminus represenative or web site. This Starboard is not electrically isolated. It is active and connected to the LED cathode. Starboard requires electrical isolation is most customer designs. Please see application note APN 15 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet SOLDER PROFILE INFORMATION 16 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet SHIPPING / PACKAGING INFORMATION ITEM Reel Packaging 250 pcs / Reel Box Packing Spec 5 reels per box = 1250 pcs per Box Box Dimension 225 x 245 x 65mm 65 mm 225 mm m 245 m Box Diagram Reel Diagram Tape Dimensioning Diagram and Table Dimension Ao B0 K0 P0 P1 P2 T E1 F D0 D1 W 17 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Spec (mm) 3.80 +/- 0.10 4.00 +/- 0.10 1.20 +/- 0.10 4.00 +/- 0.10 8.00 +/- 0.10 2.00 +/- 0.05 0.30 +/- 0.05 1.75 +/- 0.10 5.50 +/- 0.05 1.55 +/- 0.05 1.55 +/- 0.05 12.00 +/- 0.01 Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet REEL PACKAGING Confidential © 2013 Luminus Devices, Inc. All rights reserved. 4 HUMIDITY CARD The Humidity Indicator is included within each Anti-static bag. If Humidity indicator is triggered replace desiccant and/ or pre-bake prior to system assembly. LDI recommends all SFT-series LED are stored “SEALED” until time of use. See Application Note. LABEL Label Fields: • CPN: Customer orderable Part Number (as defined on P3) • MPN: Manufacturer Part Number (Internal Luminus use) • QTY: Quantity of Devices • Bin/Flux: Flux Bin • Bin/Voltage: Vf Bin (Internal Luminus use) • Bin/Color: Color or Wavelength • MFG INFO: Luminus Internal Use 18 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA SFT-10 Product Datasheet History of Changes Rev 1 Description of Change 07/21/2017 Release version Removed “Preliminary” Updated flux and wavelength bin tables The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may have in such information. This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and other countries. 19 PDS-002823 Rev 01 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA
SFT-10-RA-R35-MPA 价格&库存
很抱歉,暂时无法提供与“SFT-10-RA-R35-MPA”相匹配的价格&库存,您可以联系我们找货
