ABS17LI1
ABS17LI1
    MGCHEMICALS
    FILAMENT GREEN ABS 0.07" 1KG
ABS17LI1 数据手册
Premium 3D Printer Filament—ABS ABS Description The Premium 3D Printer Filament—ABS is made of high purity acrylonitrile butadiene styrene (ABS) pellets with a tight diameter tolerance. Applications & Usages The ABS filament is preferred by engineers and professionals because of its high temperature resistance, machinability, flexibility, and strength. ABS is easily soluble and welded in acetone. Benefits and Features  1.75 mm and 3.00 mm diameters  Low diameter variance  Vivid and unique colors such as Skin, Gold, Silver, Glow in the Dark, and so on 3D-Filament Processing Parameters Processing Parameters Working Temperature Bed Temperature Temperature 230–240 °C [446–464 °F] 90–110 °C [194–230 °F] a) Values may vary depending on the printer type, environmental conditions, and color of filament. Adjust print temperatures by 5 °C until ideal flow and bed adhesion is obtained. 3D-Filament Properties Quality Control Specific Gravity Method ASTM D 792 @ 23 °C Value 1.05 g/cm3 Physical Properties Tensile Strength % Elongation Flexural Strength Flexural Modulus Izod Impact Strength Hardness a) UL Flammability Rating Method ASTM D 638 " ASTM D 790 " ASTM D 256 ASTM D 785 Value 45 N/mm2 [6 500 lb/in2] 25% 77 N/mm2 [11 000 lb/in2] 2 650 N/mm2 [384 000 lb/in2] 18 000 g·cm/cm 116 R Scale UL-94 HB a) Rockwell hardness scale Date: 06 January 2016 / Ver. 1.02 Page 1 of 4 Premium 3D Printer Filament—ABS ABS Thermal Properties Melt Flow Index Vicat Softening Temperature Heat Distortion Temperature Method ASTM D 1238 @200 °C, 5 kg load ASTM D 1238 @220 °C, 10 kg load ASTM D 1525 @50 °C/h, 3 mm ASTM D 648, Annealed ASTM D 648, Unannealed Value 1.6 g per 10 min 22 g per 10 min 105 °C [221 °F] 95 °C [203 °F] 85 °C [185 °F] Storage and Shelf Life Store between 18 to 27 °C [65–80 °F] and protect from direct heat or sunlight. Keep sealed in an air tight container, away from humidity. Shelf Life Unopened package Opened package Value 1 y from date of purchase Variable depending on storage conditions Health and Safety Please see the Premium 3D Printer Filament-ABS Safety Data Sheet (SDS) for more details on transportation, storage, handling and other security guidelines. Environmental Impact: This product doesn’t have any known environmental toxicity. This product meets the European Directive 2011/65/EU Annex II (ROHS); recasting 2002/95/EC. Health and Safety: This product is not considered to be hazardous for human health under normal use. It is widely used in the packing and food industry. HMIS® RATING NFPA® 704 CODES HEALTH: 0 FLAMMABILITY: 1 PHYSICAL HAZARD: 0 1 0 PERSONAL PROTECTION: Approximate HMIS and NFPA Risk Ratings Legend: 0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe) Date: 06 January 2016 / Ver. 1.02 Page 2 of 4 0 Premium 3D Printer Filament—ABS ABS Packaging and Supporting Products Available Colors Translucent White Black Red Yellow Green Blue Orange Purple Grey Pink Brown Gold Silver Glow in the Dark Skin Navy Lime Available Sizes Diameter Filament Length 0.25 kg spools 0.50 kg spools 1.0 kg spools 1.75 mm 3.00 mm 105 m 32.5 m 210 m 65 m 420 m 130 m Spool Weight Dimensions Inner diameter Outer diameter Width 0.25 kg 0.50 kg 1.00 kg 32 mm 32 mm 57 mm 160 mm 160 mm 180 mm 57 mm 57 mm 92 mm Diameter Spool Weight kg Net Volume L qt Net Weight kg lb 1.75 mm or 3.00 mm 0.25 0.50 1.00 0.238 0.476 0.952 0.252 0.503 1.01 0.25 0.50 1.0 0.55 1.1 2.2 Note: Some colors are not available in all sizes. Use the 3D filament Part Selection Tool for ABS on the MG Chemical web site or click here. Date: 06 January 2016 / Ver. 1.02 Page 3 of 4 Premium 3D Printer Filament—ABS ABS Supporting Products     3D Printing Masking Tape, Cat. No. MAS100-15, MAS200-15 3D Printing Polyimide Tape, Cat. No. POL100, POL200 Acetone, Cat. No. 434-1L, 434-4L d-Limonene, Pure Grade: Cat. No. 433-1L, 433-4L Technical Support Contact us regarding any questions, improvement suggestions, or problems with this product. Application notes, instructions, and FAQs are located at www.mgchemicals.com. Email: support@mgchemicals.com Phone: +1-800-340-0772 (Canada, Mexico & USA) +1-905-331-1396 (International) Fax: +1-905-331-2862 or +1-800-340-0773 Mailing address: Manufacturing & Support 1210 Corporate Drive Burlington, Ontario, Canada L7L 5R6 Head Office 9347–193rd Street Surrey, British Columbia, Canada V4N 4E7 Warranty M.G. Chemicals Ltd. warranties this product for 12 months from the date of purchase by the end user. M.G. Chemicals Ltd. makes no claims as to shelf life of this product for the warranty. The liability of M.G. Chemicals Ltd. whether based on its warranty, contracts, or otherwise shall in no case include incidental or consequential damage. Disclaimer This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Date: 06 January 2016 / Ver. 1.02 Page 4 of 4
ABS17LI1 价格&库存
很抱歉,暂时无法提供与“ABS17LI1”相匹配的价格&库存,您可以联系我们找货
