MTCMR-G-F4
MTCMR-G-F4
    MULTI-TECHSYSTEMS
    Module
    MODEM GPRS QUAD BAND GSM GLOBAL
MTCMR-G-F4 数据手册
MultiModem iCell ® Intelligent GPRS Cellular Modem Benefits • Intelligent Universal IP stack • Enhanced M2M functionality • Programmable GPIO ports • Carrier approved The MultiModem® iCell intelligent GPRS cellular modem offers standards-based quad-band GPRS performance. This ready-to-deploy, standalone modem provides wireless data communication and integrates seamlessly with virtually any application. The intelligence of the embedded Universal IP™ stack allows for automatic/persistent connectivity for mission critical applications and enhanced M2M functionality. The MultiModem iCell intelligent cellular modem is based on industry-standard open interfaces and can be desktop or panel mounted. Features • GPRS Class 10 • Quad-band 850/900/1800/1900 MHz • Intelligent Universal IP stack for enhanced machine-to-machine functionality • Event monitoring and reporting via integrated GPIO ports • Supports Short Message Service such as text and PDU mode, point-to-point (MT/MO) and cell broadcast • Circuit-switched data up to 14.4K bps • RS-232 interface supports DTE speeds to 115.2K bps • USB 2.0 full speed interface (supported in a future firmware release, currently RS-232 only) • SMA antenna connector and SIM socket • Desktop or panel mounting • FCC, PTCRB and R&TTE certified • AT command compatible • Two-year warranty Highlights Specifications Applications. The MultiModem iCell intelligent cellular modem with GPRS support is ideal for applications which periodically need to send or receive data over a wireless network. Packet Data Features Universal IP for Enhanced M2M Connectivity. Multi-Tech’s Universal IP stack consists of a common set of TCP/IP networking protocols and M2M applications implemented using a standard AT command interface. Universal IP provides developers a common programming interface effectively future proofing their application as new cellular technologies are introduced. Some of the benefits of Universal IP are Automatic/Persistent Connectivity, Device Monitor, Event Monitoring/Reporting, Ping & TCP Keep Alive and Wake-up on Caller ID/Wake-up on Ring. Reduces Development Time. The MultiModem iCell intelligent cellular modem can make your existing and next generation device communication-ready without requiring any hardware changes to its design. It actually provides faster time-to-market because it relieves the burden and expense of obtaining PTCRB and RF approvals. Multiple Interface Options. The MultiModem iCell intelligent cellular modem is designed around a broad range of interface options including RS-232; USB (supported in a future firmware release) and GPIO to provide you with seamless connectivity for your application. Each interface option offers unique features and benefits related to the technology it supports. Comprehensive Service and Support. The Multi-Tech commitment to service means we provide a two-year product warranty and service that includes technical support, 24-hour web site and ftp support. Description Intelligent GPRS Modem Region Global 850/900/1800/1900 MHz GPRS Modem 900/1800 MHz Default Includes US Style Power Plug Includes Euro Style Power Plug Includes UK Style Power Plug * Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. † Circuit Switched Data/Fax Features Asynchronous, transparent & non-transparent up to 14.4K bps, MNP2 & V.42bis SMS Features Text & PDU, Point-to-Point, cell broadcast Universal IP Features TCP/IP features: DNS resolve, FTP client, Ping, POP3 client, PPP (dial-out), SMTP client, TCP RAW client & server, UDP RAW client & server, PAP, CHAP Connectors RF Antenna: 50 ohm SMA female RS-232: DB-9 female USB: USB Type B (future firmware release) Power: 2.5mm miniature screw GPIO: 6-pin Molex female with ESD protection SIM: Standard 3V SIM receptacle Power Requirements 9V to 32VDC GPIO Functions Pin 1-2: Programmable digital input/output Pin 3-4: Programmable digital input/output or ADC Pin 5: ADC Digital inputs: 5V tolerant TTL/CMOS levels; digital outputs: 3.3V high; ADC inputs: 0 to 3.3V rail; Output current: 2mA max Physical Description 4.9" w x 1.1" h x 3.5" d; 8 oz (12.4 cm x 2.8 cm x 8.9 cm; 227 g) Ordering Information Product MTCMR-G*† Ordering Codes -F4 -ED -NAM -EU -GB/IE GPRS Class 10, PBCCH support Coding Schemes: CS1 to CS4 Embedded TCP/IP stack All build options support 850/900/1800/1900 MHz cellular connectivity. Standard builds default to 850/1900 MHz while the builds that include a -ED in the ordering code default for 900/1800 MHz. Environment Operating: -30º to +70º C Storage: -40º to +85º C Humidity: 20% to 90% non-condensing Certifications CE Mark, R&TTE EMC: FCC Part 15, 22, 24; EN 55022, EN 55024, EN 301 489-1, EN 301 489-7, EN 301 511; RSS 132, 133,102 Safety: cUL 60950-1, UL 60950-1; EN 60950-1, AS/NRZ60950-1 Network: PTCRB Made in Mounds View, MN, U.S.A. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: MultiModem, Universal IP, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. World Headquarters Tel: (763) 785-3500 (800) 328-9717 www.multitech.com 5/10 86002099 EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Copyright © 2010 by Multi-Tech Systems, Inc. All rights reserved. Multi-Tech Systems (EMEA) France Tel: +(33) 1 49 19 22 06
MTCMR-G-F4
物料型号:MTCMR-G
器件简介:iCell智能GPRS调制解调器是一款标准的四频GPRS性能设备,提供即插即用的独立调制解调器,可与几乎所有应用无缝集成。
引脚分配: - RF天线:50欧姆SMA母头 - RS-232:DB-9母头 - USB:USB Type B(未来固件版本支持) - 电源:2.5mm小型螺丝 - GPIO:6针Molex母头带ESD保护 - SIM:标准3V SIM插座
参数特性: - GPRS 10类 - 四频850/900/1800/1900 MHz - 智能通用IP堆栈,增强机器对机器功能 - 通过集成GPIO端口进行事件监控和报告 - 支持短信服务,如文本和PDU模式,点对点(MT/MO)和小区广播 - 电路交换数据高达14.4K bps - RS-232接口支持DTE速度达115.2K bps - USB 2.0全速接口(未来固件版本支持,目前仅RS-232) - FCC、PTCRB和R&TTE认证 - 兼容AT命令 - 两年保修
功能详解: - 智能通用IP堆栈 - 增强的M2M功能 - 可编程GPIO端口 - 运营商认证
应用信息:iCell调制解调器适用于需要通过无线网络定期发送或接收数据的应用。
封装信息:物理尺寸为4.9英寸宽x 1.1英寸高x 3.5英寸深;重量8盎司(12.4厘米x 2.8厘米x 8.9厘米;227克)。
环境规格:工作温度范围为-30º至+70º C,存储温度范围为-40º至+85º C,湿度为20%至90%非凝结。
MTCMR-G-F4 价格&库存
很抱歉,暂时无法提供与“MTCMR-G-F4”相匹配的价格&库存,您可以联系我们找货
