NJM12901
SINGLE SUPPLY QUAD COMPARATOR
■ GENERAL DESCRIPTION
The NJM12901 is single-supply quad voltage comparator,
which can operate from 2V supply. The features are low input
offset voltage, low input bias current and low current
consumption. The NJM12901 compare the input signal to 0V
( ground ) due to the Darlington PNP input stage.
The package lineup is DIP, DMP and others compact, so that
the NJM12901 is suitable for any kind of signal comparator.
■ FEATURES
● Operating Voltage
● Open Collector Output
● Bipolar Technology
● Package Outline
■ PACKAGE OUTLINE
( +2V~+14V )
DIP14,DMP14,EMP14,SSOP14
■ PIN CONFIGURATION
PIN FUNCTION
1.B OUTPUT
2.A OUTPUT
3.V
4.A –INPUT
5.A +INPUT
6.B –INPUT
7.B +INPUT
8.C -INPUT
9.C +INPUT
10.D -INPUT
11.D +INPUT
12.GND
13.D OUTPUT
14.C OUTPUT
■ EQUIVALENT CIRCUIT ( 1/4 Shown )
Ver.2003-03-19
-1-
NJM12901
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
V
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
15
14
-0.3~+14
( DIP14 ) 700
( DMP14 ) 300
( EMP14 ) 300
( SSOP14 ) 300
-40~+85
-50~+125
UNIT
V
V
V
mW
˚C
˚C
■ ELECTRICAL CHARACTERISTICS
( V+=5V,Ta=25˚C )
PARAMETER
Operating Voltage
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Common Mode Voltage Range
Large Signal Voltage Gain
Response Time
Output Sink Current
Output Saturation Voltage
Leakage Current
Operating Current
-2-
SYMBOL
Vopr
VIO
IIO
IB
VICM
AV
tR
ISINK
VSAT
ILEAK
ICC
TEST CONDITION
RS=0Ω,VO=1.4V
RL=15kΩ
RL=5.1kΩ
VIN =1V,VIN =0V,VO=1.5V
VIN =1V,VIN =0V,ISINK=3mA
VIN =0V,VIN =1V,VO=5V
RL=∞
MIN.
2
0~3.5
6
TYP.
1
5
30
106
0.5
10
80
0.1
0.8
MAX.
14
4
50
200
300
1.0
1.8
UNIT
V
mV
nA
nA
V
dB
µs
mA
mV
µA
mA
Ver.2003-03-19
NJM12901
■ TYPICAL CHARACTERISTICS
Ver.2003-03-19
-3-
NJM12901
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2003-03-19
很抱歉,暂时无法提供与“NJM12901D1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.14720
- 200+1.60920
- 500+1.55520
- 1000+1.52280
