NJM2256M
NJM2256M
    NISSHINBO(日清纺)
    SOP-20
    IC VIDEO SGNL SUPERIMPOSER 20DMP
NJM2256M 数据手册
NJM2256 VIDEO COLOR SUPERIMPOSER ■ GENERAL DESCRIPTION NJM2256 is the multi-functional color super-imposer IC for videobase band (Y, R-Y, B-Y), Various type of Y, R-Y, B-Y output signals can bemade by the digital controlled signals. The signal control at the base band, made it possible on operation with less extermal parts, as well as for non adjustment on operation. NJM2256 can be operated much higher switching speed comparing to NJM2247. ■ PACKAGE OUTLINE NJM2256M ■ FEATURES ● 5V single Power Supply ● 8 Types Color Super-imposer ● Burst Flag Insert Function ● Y Inversion, C Inversion Function ● NTSC / PAL Matching ● Non Operational Adjustment ● Less External Parts ● Higher switching speed can be made comparing to NJM2247 ● Package Outline DMP20 ● Bipolar Technology ■ RECOMMENDED INPUT CONDITIONS ● Y Signal 0.7VP - P ● R-Y Signal 1.0VP - P ● B-Y Signal 0.7VP - P ● Control Voltage ● Low Level 0 to 0.25V ● High Level 4.75 to 5V ■ PIN CONFIGURATION NJM2256M Ver.2004-02-17 -1- NJM2256 ■ CONTROL PIN CHARACTERISTICS PIN NO. PIN FUNCTIONS 3 4 5 3 4 5 10 12 14 15 16 19 20 (V+=5V) THRESHOLD LEVEL (V) SINK / SOURCE CURRENT (µA) LOW HIGH 0V 5V R G B 0.7 0.8 -500 500 (at C Inversion) 2.5 2.6 -100 100 C Inversion HBF Pulse NTSC / PAL Clamp Pulse Character Pulse Y Inversion BLK Pulse 3.5 0.5 0.7 2.5 0.5 0.4 0.4 4.5 2.0 0.8 2.8 0.9 0.8 0.8 -200 -2 0 -2 -0.5 -0.5 -0.5 400 1 150 0 0 0 0 ■ BLOCK DIAGRAM -2- Ver.2004-02-17 NJM2256 ■ INFORMATIONS Following four points are the outstanding function of the NJM2256. These functions are to go through three input (Y, R-Y, B-Y) signals control by ten control pins. 1. Color Superimpose DC Level of each equivalent colors shall be supplied to Y, R-Y and B-Y inputs. 2. Burst Flag Insertion 150 mV burst flag shall be added to R-Y, B-Y input signals. Burst flag is selected by the NTSC / PAL switch. 3. C Inversion The color phase of the picture shall be inverted for one hundred and eighty degrees. The color phase of the imposed character shall not be altered. This function shall be proceeded when inverting the burst flag, and at the same time, the imposed character level shall be inverted too. 4. Y Inversion It is the brightness level inversion. The imposed character color shall not be changed. This function shall be proceeded the switching Y signal output to the inverter side. NJM2256 Fig.1 Video Camera Application Ver.2004-02-17 -3- NJM2256 ■ EQUIVALENT CIRCUIT PIN NO. PIN FUNCTION 6 B-Yin 7 B-Yout G 8 R-Yin B 9 R-Yout PIN NO. PIN FUNCTION 1 Yout 2 V+ 3 R 4 5 -4- INSIDE EQUIVALENT CIRCUIT INSIDE EQUIVALENT CIRCUIT Ver.2004-02-17 NJM2256 ■ EQUIVALENT CIRCUIT PIN FUNCTION PIN NO. 10 13 14 PIN NO. PIN FUNCTION 15 Clamp Pulse 16 Character Pulse INSIDE EQUIVALENT CIRCUIT C Inversion 11 12 INSIDE EQUIVALENT CIRCUIT GND HBF Pulse BF Level NTSC / PAL Ver.2004-02-17 17 Yin 18 Inversion Set up Correction 19 20 Y Inversion BLK -5- NJM2256 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25°C) SYMBOL RATINGS UNIT + Supply Voltage V 8 V Power Dissipation PD 350 mW Operating Temperature Range Topr -20 to +75 Storage Temperature Range Tstg -40 to +125 °C °C ■ ELECTRICAL CHARACTERISTICS PARAMETER CONTROL PIN SYMBOL 3 TEST CONDITION MIN. TYP. MAX. UNIT 12 18.5 26 mA 4 5 10 12 14 15 16 19 20 Operating Current Icc (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) Terminal Sink Current 1 I17 (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) V 17 = 2.5V Current when application 0 10 µA Terminal Sink Current 1 I6 (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) V 6 = 3.0V Current when application 0 6 µA Terminal Sink Current 3 I8 (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) V 8 = 3.0V Current when application 0 6 µA Terminal Voltage 1 Terminal Voltage 2 Terminal Voltage 3 Terminal Voltage 4 Terminal Voltage 5 Y Non Inversion Voltage Gain Frequency V1 V7 V9 V13 V18 (0)(0)(0)(0)(0)(5)(0)(0)(0)(0) (0)(0)(0)(0)(0)(5)(0)(0)(0)(0) (0)(0)(0)(0)(0)(5)(0)(0)(0)(0) (0)(0)(0)(0)(0)(5)(0)(0)(0)(0) (0)(0)(0)(0)(0)(5)(0)(0)(0)(0) 1 7 9 13 18 1.68 2.18 2.18 0.23 1.68 1.92 2.42 2.42 0.37 1.92 V V V V V GYP DGP (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) V (YIN) = 1VP-P, 1MHz GYP (6MHz) – GYP (1MHz) -0.5 -1 0 0 0.5 1 dB dB Differential Gain DPP (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) V (YIN) = 1VP - P, Standard Staircase -3 0 3 % Differential Phase Y Inversion Voltage Gain Frequency DPP -3 0 3 deg GYN GFYN (0)(0)(0)(0)(0)(0)(0)(0)(0)(0) ( ) (0)(0)(0)(0)(0)(0)(0)(0)(5)(5) (0)(0)(0)(0)(0)(0)(0)(0)(5)(5) -2.3 -2 -1.3 -0.1 0.3 1 dB dB Differential Gain DGN (0)(0)(0)(0)(0)(0)(0)(0)(5)(5) Differential Phase DPP (0)(0)(0)(0)(0)(0)(0)(0)(5)(5) Inversion Block Level BLN (0)(0)(0)(0)(0)(0)(5)(0)(5)(5) (0)(0)(0)(0)(0)(0)(5)(0)(5)(5) 1 Voltage: a 1 Voltage: b (0)(0)(0)(0)(0)(0)(5)(0)(5)(0) 1 Voltage: c GR-Y (0)(0)(0)(0)(0)(0)(5)(0)(0)(0) V (R-YIN) = 1VP - P, 1MHz -0.5 BFRP (0)(0)(0)(0)(0)(0)(5)(0)(0)(0) (0)(0)(0)(5)(5)(0)(5)(0)(0)(0) 9 Voltage: d 9 Voltage: e BFRP = e - d 135 BFRN (0)(0)(0)(5)(5)(0)(5)(0)(0)(0) 9 Voltage: f BFRN = f - d GR-Y (0)(0)(0)(0)(0)(0)(5)(0)(0)(0) Burst Level Non Inversion BFHP Burst Level Inversion BFRN Open Voltage Open Voltage Open Voltage Open Voltage Open Voltage V (YIN) = 0.6VP - P, 1MHz GYN (6MHz) - GYN (1MHz) V (YIN) = 0.5VP - P, Standard Staircase 8 % -3 0 3 deg BLN = a - b 0.59 0.68 0.77 V BLK = c - b -0.1 0 0.1 V 0.5 dB 150 165 mV -165 -150 -135 mV V (B-YIN) = 1VP - P, 1MHz -0.5 0 0.5 dB (0)(0)(0)(0)(5)(5)(5)(0)(0)(0) (0)(0)(0)(0)(0)(5)(5)(0)(0)(0) 7 Voltage: g 7 Voltage: h 135 150 165 mV (0)(0)(0)(5)(5)(5)(5)(0)(0)(0) 7 Voltage: i -165 -150 -135 mV R-Y Switching Speed (X)(0)(0)(0)(0)(0)(5)(5)(0)(0) X = 1MHz 5VPP Rectangular Wave *100 nS B-Y Switching Speed (X)(0)(0)(0)(0)(0)(5)(5)(0)(0) X = 1MHz 5VPP Rectangular Wave *100 nS Inversion BLK R-Y Voltage Gain Burst Level Non Inversion Burst Level Inversion B-Y Voltage Gain BFRP = g - h BFRN = g - i -8 *Remark 1) *Item indicates design assurance rating. -6- Ver.2004-02-17 NJM2256 ■ ELECTRICAL CHARACTERISTICS PARAMETER CONTROL PIN SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT 3 4 5 10 12 14 15 16 19 20 Character Output Level 1 C Inversion White Y R-Y B-Y Yellow Y R-Y B-Y Cyanoge Y R-Y B-Y Green Y R-Y B-Y Magenta Y R-Y B-Y Red Y R-Y B-Y Blue Y R-Y B-Y Black Y R-Y B-Y Character Output Level 2 C Inversion White Y R-Y B-Y Yellow Y R-Y B-Y Cyanoge Y R-Y B-Y Green Y R-Y B-Y Magenta Y R-Y B-Y Red Y R-Y B-Y Blue Y R-Y B-Y Black Y R-Y B-Y Ver.2004-02-17 ) MPWY MPWR MPWB MPYY MPYR MPYB MPCY MPCR MPCB MPGY MPGR MPCB MPMY MPMR MPMB MPRY MPRR MPRB MPBY MPBR MPBB MPPY MPPR MPPB (5)(5)(5)(0)(0)(0)(5)(5)(0)(0) (5)(5)(0)(0)(0)(0)(5)(5)(0)(0) (0)(5)(5)(0)(0)(0)(5)(5)(0)(0) (0)(5)(0)(0)(0)(0)(5)(5)(0)(0) (5)(0)(5)(0)(0)(0)(5)(5)(0)(0) (5)(0)(0)(0)(0)(0)(5)(5)(0)(0) (0)(0)(0)(0)(0)(0)(5)(5)(0)(0) (0)(0)(0)(0)(0)(0)(5)(5)(0)(0) 1 9 7 1 9 7 1 9 7 1 9 7 1 7 7 1 9 7 1 9 7 1 9 7 Voltage: A, MPWY = A - V1 Voltage: B, MPWR = B - V9 Voltage: C, MPWB = C - V7 Voltage: A, MPYY = A - V1 Voltage: B, MPYR = B - V9 Voltage: C, MPYR = C - V7 Voltage: A, MPCY = A - V1 Voltage: B, MPCR = B - V9 Voltage: C, MPCB = C - V9 Voltage: A, MPGY = A - V1 Voltage: B, MPGR = B - V9 Voltage: C, MPGB = C - V7 Voltage: A, MPMY = A - V1 Voltage: B, MPMR = B - V9 Voltage: C, MPMB = C - V7 Voltage: A, MPRY = A - V1 Voltage: B, MPRR = B - V9 Voltage: C, MPRB = C - V7 Voltage: C, MPBY = A - V1 Voltage: B, MPBR = B - V9 Voltage: C, MPBB = C - V7 Voltage: A, MPPY = A - V1 Voltage: B, MPPR = B - V9 Voltage: C, MPPB = C - V7 630 -16 -14 472 13 --165 409 -232 28 252 -197 -117 378 155 77 220 186 -72 156 -53 127 -20 -14 -12 700 0 0 525 33 -146 455 -209 50 280 -176 -97 420 176 97 245 209 -50 175 -33 146 0 0 0 770 16 14 578 53 -127 501 -186 72 308 -155 -77 462 197 117 270 232 -28 194 -13 165 20 14 12 mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV 1 9 7 1 9 7 1 9 7 1 9 7 9 9 7 1 9 7 1 9 7 1 9 7 Voltage: A, MNWY = A - V1 Voltage: B, MNWR = B - V9 Voltage: C, MNWB = C - V7 Voltage: A, MNYY = A - V1 Voltage: B, MNYR = B - V9 Voltage: C, MNYB = C - V7 Voltage: A, MNCY = A - V1 Voltage: B, MNCR = B - V9 Voltage: C, MNCB = C - V7 Voltage: A, MNGY = A - V1 Voltage: B, MNGR = B - V9 Voltage: C, MNGB = C - V7 Voltage: A, MNMY = A - V1 Voltage: B, MNMR = B - V9 Voltage: C, MNMB = C - V7 Voltage: A, MNRY = A - V1 Voltage: B, MNRR = B - V9 Voltage: C, MNRB = C - V7 Voltage: A, MNBY = A - V1 Voltage: B, MNBR = B - V9 Voltage: C, MNBR = C - V7 Voltage: A, MNPY = A - V1 Voltage: B, MNPR = B - V9 Voltage: C, MNPB = C - V7 630 -16 -14 472 -53 127 409 186 -72 252 155 77 378 -197 -117 220 -232 28 156 13 -165 -20 -14 -12 700 0 0 525 -33 146 455 209 -50 280 176 97 420 -176 -97 245 -209 50 175 33 -146 0 0 0 770 16 14 578 -13 165 501 232 -28 308 197 117 462 -155 -77 270 -186 72 194 53 -127 20 14 12 mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV mV ) MNWY MNWR MNWB MNYY MNYR MNYB MNCY MNCR MNCB MNGY MNGR MNGB MNMY MNMR MNMB MNRY MNRR MNRB MNBY MNBR MNBR MNPY MNPR MNPB (5)(5)(5)(0)(0)(0)(5)(5)(0)(0) (5)(5)(0)(5)(0)(0)(5)(5)(0)(0) (0)(5)(5)(5)(0)(0)(5)(5)(0)(0) (0)(5)(0)(5)(0)(0)(5)(5)(0)(0) (5)(0)(5)(5)(0)(0)(5)(5)(0)(0) (5)(0)(0)(5)(0)(0)(5)(5)(0)(0) (0)(0)(5)(5)(0)(0)(5)(5)(0)(0) (0)(0)(0)(5)(0)(0)(5)(5)(0)(0) -7- NJM2256 NJM2256 ■ APPLICATION NOTES I / O Explanation ● Supply Voltage V+ GND ● Input Signals Y R-Y B-Y ● Output Signals Y R-Y B-Y -8- 5V 0.7VP - P 1.0VP - P 0.7VP - P 0.7VP - P 1.0VP - P 0.7VP - P 2 11 17 8 6 1 9 7 Ver.2004-02-17 NJM2256 ■ APPLICATION NOTES I / O Explanation ● Control Pin Low=0V, HIGH=5V R 3 G 4 Superimposed color adjustment B 5 Clamp Pulse 15 Character Pulse 16 Y, R-Y, B-Y signal process pulse input HBF Pulse 12 BLK Pulse 20 C Inversion 10 Color difference, brightness inverting pin Y Inversion 19 NTS / PAL Switch 14 ● Adjusting Pin (Normally open → non adjustment) BF level 13 Burst flag insert level adjusting pin. Inversion set up correction 18 Y inversion signal level adjusting pin. 1. Input Signal Superimposed color level shall be determined by the following standard signal level. 0.7VP - P Y R-Y 1.0VP - P B-Y 0.7VP - P The character output standard level on the specification shall be determined through calculation out of 75% of superimposed color level. (In order to avoide the clipping of the encoding signal, the character output level is determined to lower level) ● The character output level converting expression The basic expression ER - EY = 0.70ER - 0.59EG - 0.11EB EB - EY = - 0.30ER - 0.59EG + 0.89EB EY = 0.30ER + 0.59EG + 0.11EB From standard level and practical input level, each color signal level imposed in R-Y, B-Y and Y signals are as in the following. VR - Y = 0.75 × 1 [VP - P] × ER – Y / 1.4 = 0.375ER - 0.316EG - 0.059EB VB - Y = 0.75 × 0.7 [VP-P] × EB – Y / 1.78 = - 0.088ER - 0.174EG + 0.263EB VY = 0.75 × 0.7 [VP - P] × EY / 1 = 0.158ER + 0.310EG + 0.058EB (ER, EG, EB, LOW 0, HIGH 1) 2. Clamp Pulse During the interval of blanking, input the pulse through clamp pulse pin 20 the blanking level (0 level) of input signal (Y, R-Y, B-Y) is to be fixed at the bias point within the IC. Note) The pulse width of clamp pulse shall be set more than 3 µs. (see figure 2) Flg. 2 Clamp Pulse Width Ver.2004-02-17 -9- NJM2256 3. Character Color adjustment Superimposed color adjustment of the character can be determined in eight different colors, by choosing R, G, B input levels. (LOW 0V, HIGH 5V) R G B COLOR 5 5 5 5 5 0 White Yellow 0 0 5 5 5 0 Cyan Green 5 5 0 0 5 0 Magenta Red 0 0 0 0 5 0 blue Black Character Color Selecting Code 4. Character Insertion Pulse informations from outside character generater shall be given input at the character pulse pin 16 . During the period of pulse process, the selected color level shall be inserted into each Y, R-Y, B-Y. 5. Burst Flag Insertion Inputting burst period pulse at the HBF pin 12 , the burst flag (150mV) can be inserted in the B-Y, R-Y signals. At the same time, by putting NTSC / PAL switch 14 , the burst flag can be altered to NTSC or PAL system. NTSC / PAL SWITCH 14 R-Y Signal B-Y Signal LOW 0V (PAL) HIGH 5V (NTSC) +150mV -150mV non insertion -150mV Burst Flag Inserting Flg.3 Burst Flag Inserting Example - 10 - Ver.2004-02-17 NJM2256 6. C Inversion The color phase of the picture shall be inverted for one hundred and eighty degrees setting C inversion pin 10 . It is applied that the reference signal (burst flag) shall be inverted into one hundred and eighty degrees at the time of de-coding. Superimposed character color do not change at the picture inversion. C INVERSION PIN 10 Burst LOW 0V HIGH 5V Non Inversion Inversion C Inversion Form 7. Y Inversion The brightness of the picture shall be inverted by setting Y inversion 19 . It is that Y signal shall be inverted by the inverter, and then blanking period signal shall be adjusted to the black level with blanking pulse. Figure 4. Y Inversion Output Example Y INVERSION PIN 19 Y Output LOW 0V HIGH 5V Non inversion Inversion Y Inversion Form 8. Adjusting pin (1) BF Level Pin 13 It is the burst flag minor adjusting pin. The burst level shall be adjusted at the open voltage, 0.3V level adjustment. Therefore, the most recommended on operation with the open condition, as it has been controlled st 135 at 165 mV (burst level) on specification. (2) Inversion Set Up Correction Pin 18 It is the minor adjusting pin of Y inversion signal level. The inverting black level shall be adjusted at the open voltage, 1.8V level adjustment. Therefore, the most recommended on operation with the open condition, as it has been controlled with 0.59 to 0.77 V (inverting black level) on specification. Ver.2004-02-17 - 11 - NJM2256 9. Pulse Timing The pulse input timing should be proceeded as in the following. ■ TYPICAL APPLICATION NJM2256 - 12 - Ver.2004-02-17 NJM2256 ■ APPLICATION This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes an unstable pin voltage. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2004-02-17 - 13 -
NJM2256M 价格&库存
很抱歉,暂时无法提供与“NJM2256M”相匹配的价格&库存,您可以联系我们找货
