NJM2519A
RF Modulator for VHF Band
DESCRIPTION
The NJM2519A is a RF modulator IC especially designed for VHF
PACKAGE OUTLINE
band RF modulator and consists of video clamp circuit, white clip circuit,
video AM modulator and audio FM modulator, built into one chip.
FEATURES
NJM2519AM
• Operating Voltage 5V
• VHF Oscillator on chip
• Regulator on chip
• Bipolar Technology
• Package Outline: DMP8
OSC
REG OUT
VCC
AUDIO IN
BLOCK DIAGRAM
8
7
6
5
RF OSC
REGULATOR
AUDIO FM
MODULATOR
MIXER
CLAMP &
1
2
3
4
RF OUT
GND
VIDEO IN
4.5MHz
TANK
WHITE CLIP
-1-
NJM2519A
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Supply Voltage
VCC
Power Dissipation
PD
Input Voltage
Operating Temperature Range
Storage Temperature Range
VI
Topr
Tstg
Ratings
7
300
(TA=25°C)
Unit
V
mW
-0.3 to VCC
-20 to +75
-40 to +125
RECOMMENDED OPERATING VOLTAGE RANGE
Parameter
Condition
Operating Voltage
Symbol
VCC
ELECTRICAL CHARACTERISTICS
Parameter
Condition
Symbol
Operating Current
No video/audio input signal,
ICC
Video Output Level
VO
Video input signal(Pin1)=0.5VPP
(Note 1)
Video Modulation Depth
mp
(Note 1)
Video Limiter Modulation Video input signal(Pin1)=1.0VPP
mpmax
Depth
(Note 1)
Differential Gain
DG
Staircase
DP
Differential Phase
Staircase
Picture-to-sound Ratio
PS
(Note 1)
Sound FM Modulation
Deviation of fs per 100mV
βb
Sensitivity
Audio input signal(Pin7)=0.05VPP
Audio Distortion
THD
1kHz sine wave
Audio Signal-to-noise
Sound Modulation 60%
ASN
Ratio
1kHz sine wave
Maximum Sound FM
Audio input signal(Pin7)=1.0VPP
msmax
Modulation
1kHz sine wave
V
°C
°C
Min.
4.5
Typ.
5.0
Max.
5.5
(TA=25°C)
Unit
V
(VCC=5V,TA=25°C)
Max.
Unit
19.1
mA
Min.
11.5
Typ.
15.3
(83)
86
(89)
dBu
(70)
76
(82)
(88)
94
(98)
±3
±3
deg
(13)
16
(19)
dB
0.51
KHz/mV
0.3
60
dB
700
(Note 1) Because AC characteristics largely depends on application circuit, these parameters are specified
by the DC characteristics as shown in next page.
-2-
NJM2519A
DC ELECTRICAL CHARACTERISTICS (VCC=5V,TA=25°C, otherwise noted. All measurements performed in
the DC test circuit are shown in next page)
Parameter
Condition
(Note 2) Symbol Min.
Typ.
Max.
Unit
Video Output Signal
Gvv1=Gvvh-Gvvl
Gvv
48
108
mV
Amplitude 1
Mp=((Gvv-Mw)/Gvv)x100
Mp
66
78
where Mw=Mwh-Mwl
Video Limiter Modulation Mpmax=((Gvv-Wc)/Gvv)x100
Mpmax
85
94
98
Depth
(Note 2) where Wc=Wch-Wcl
Ps=20log(Gvv/(Gva/2))
Ps
8
18
dB
(Note 2) Explanation of symbols
Vv
Voso : OSC output voltage at Pin8
Gvvh : RF OUT output voltage at Pin1
OSC(Pin8) input = Voso+0.3V
Gvvl :
Mwh :
Mwl : RF OUT output voltage at Pin1
OSC (Pin 8) input = Voso-0.3V,VIDEO IN(Pin3) input=Vv + 0.41V
Wch : RF OUT output voltage at Pin1
OSC (Pin 8) input = Voso+0.3V,VIDEO IN(Pin3) input=Vv + 0.75V
Wcl
Gva : RF OUT output level at Pin1(4.5MHz Sine wave [peak to peak])
OSC(Pin8) input = Voso+0.6V
VIDEO IN output voltage at Pin3
OSC(Pin8) input = Voso-0.3V
OSC (Pin 8) input = Voso+0.3V,VIDEO IN(Pin3) input=Vv + 0.41V
OSC (Pin 8) input = Voso-0.3V,VIDEO IN(Pin3) input=Vv + 0.75V
-3-
NJM2519A
VC
AC TEST CIRCUIT
AUDIO IN
10p
0.1u
0.1u
7
6
5
RF OUT
GND
VIDEO IN
4.5MHz
TANK
VCC
REG OUT
OSC
8
0.1u
AUDIO IN
1n
1
2
3
4
1n
1n
0.1u
68p
75
RF OUT
VIDEO IN
VCC
6
5
GND
VIDEO IN
4.5MHz
TANK
REG OUT
7
RF OUT
OSC
8
0.1u
0.1u
VCC
1n
AUDIO IN
DC TEST CIRCUIT
1
2
3
4
1n
1n
68p
-4-
NJM2519A
TERMINAL CHARACTERISTICS
Typ.DC
No.
Symbol
Voltage (V)
Equivalent Circuit
Function
6
1
RF OUT
1
4
RF Signal Output
2
2
GND
GND
6
3
VIDEO IN
1.9
3
Video Signal Input
2
6
4
4.5MHz
TANK
4.5MHz Tank Coil
for Sound FM
Modulation Circuit
4
2.9
2
6
5
AUDIO IN
0.035
Audio Signal Input
5
2
6
VCC
Power Supply
-5-
NJM2519A
No.
Symbol
Typ.DC
Voltage (V)
Equivalent Circuit
Function
6
7
REG OUT
7
4
Regulator Output
2
6
8
OSC
2.2
8
2
-6-
RF Oscillator Pin
NJM2519A
TYPICAL CHARACTERISTICS
TA=25°C
VCC vs ICC
VCC vs VIDEO OUTPUT LEVEL
30
90
89
88
87
Vo [ dBuV ]
ICC [ mA ]
25
15
10
86
85
84
83
5
82
81
0.0
2.0
4.0
VCC [ V ]
6.0
4.5
8.0
5.5
6.0
6.5
7.0
USA3ch(61.25MHz)
VCC [ V ]
VCC vs VIDEO MODULATION DEPTH
USA4ch(67.25MHz)
VCC vs AUDIO FM SENSITIVITY
90
0.70
88
0.65
86
0.60
βb [ kHz/mV ]
84
mp [ % ]
5.0
82
80
78
76
0.55
0.50
0.45
0.40
74
0.35
72
0.30
70
4.5
5.0
5.5
VCC [ V ]
6.0
6.5
7.0
USA3ch(61.25MHz)
4.5
5.0
5.5
6.0
6.5
7.0
VCC [ V ]
USA4ch(67.25MHz)
-7-
MEMO
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
很抱歉,暂时无法提供与“NJM2519AM#”相匹配的价格&库存,您可以联系我们找货
