Winbond W681388
Single Programmable Extended CODEC/SLIC
T
he W681388 implements a single channel FXS telephone
line interface optimized for short loop applications. It integrates
SLIC (Subscriber Line Interface Circuit) functionality with a
programmable CODEC and a DC-to-DC controller. The SLIC
supports internal ringing up to 90 VPK (5 REN at 4 kft), ideal
for customer premise equipment (CPE). The CODEC can be
configured for μ-law/A-law or 16-bit linear PCM encoding and
supports a comprehensive set of signaling capabilities
required to supervise and control both telephone lines. These
include tone generation (including ring tones), DTMF
generation and detection as well as FSK and metering pulse
generation. An on-chip pulse width modulation (PWM) driver
allows the control of DC-to-DC conversion for the line.
Programmable impedance and transhybrid balancing allow for
worldwide deployment.
APPLICATIONS
Analog Telephone Adapter
Voice enabled DSL Modems
Voice enabled Cable Modems
Residential VoIP Gateways / Routers
Integrated Access Devices
Fiber to the Premise/Home (FTTP/H)
Optical Network Terminals (ONT)
Set Top Boxes
Wireless Local Loop
PBX
Conditioning
Signaling
Z matching
& TransHybrid
Metering Pulse
Generation
PCM Filters
Ringing
Generation
DTMF
Generation
Gain Adjust
FSK
Generation
DTMF
Detection
Ring Trip
Detection
Loop
Supervision
Loopback
Control
Loop Closure
Detection
Line
Diagnostic
Mode
Control
Sigma/delta
ADC
Line Monitor
ADC
Performs complete BORSCHT functions for a single channel
with a single device
Internal balanced ringing up to 90VPK (5REN up to 4kft)
Integrated Power Management
▫ Integrated DC-DC controller regulates battery voltage to
minimize power dissipation in all operating modes
Programmable linefeed characteristics
▫ Ringing frequency, amplitude, cadence
▫ Trapezoidal and Sinusoidal waveforms
▫ Two-wire AC impedance, transhybrid balance
▫ Constant Current feed (20 to 41mA)
▫ Ring trip and loop closure thresholds
Programmable signal generation
▫ DTMF generation and detection
▫ Metering pulse generation (12/16kHz)
▫ Enhanced Caller ID (FSK) generation (Type I and Type II)
▫ Tone generation (up to four simultaneous)
▫ G.711 μ-Law/A-Law / 16-bit linear PCM audio
Loop test and diagnostics support
▫ Integrated loopback modes
▫ Realtime linefeed monitoring
▫ On-chip temperature sensor
PCM and SPI bus digital interfaces
▫ PCM Master and Slave modes supported
On-chip PLL for flexible clocking options including 1MHz / 2MHz
3.3V operation
Small Footprint Packages: LQFP-48, QFN-48
Tone
Generation
Sigma/delta
DAC
Line Feed
DACs
FEATURES
Loop Supervision
DC / DC
Control
DC feed
Algorithm
PCM
SPI
Thermal
Supervision
PLL
DC/DC Supervision
W681388
Revision 1.1 - 01/2008
Application Example: Analog Telephone Adapter (ATA) supporting 1 voice port
Analog
Discrete
Front End
Protection
t/r
PCM
W681388
Control
Single
Programmable
Extended
CODEC
Ethernet
SPI
VoIP
Processor
BENEFITS
TAC
RAC
TDC
RDC
TVE
BAT
RVE
TIN
TIP
VDD1
VDD1
NC1
DC-DC Converter
48 47 46 45 44 43 42 41 40 39 38 37
RIP
RIN
OTAPS
OTAPF
GND1
OTANF
OTANS
NC2
NC3
TEST
INT
CS
1
36
2
35
3
34
4
33
5
32
W681388
48-Lead QFN/LQFP
6
7
31
30
8
29
9
28
10
27
11
26
12
25
CR
CT
VREF1
VREF2
IREF
GND2
VDD2
High integration reduces overall system BOM and
footprint
Low power consumption for battery-backup and other
power sensitive applications
High programmability reduces real-time software
overhead
Extensive line sensing enables diagnostics support
W681388 ORDERING INFORMATION
DCL
DCH
RESET
Part Number
Package
Notes
GND2
W681388DG
LQFP-48
Pb-Free
W681388YG
QFN-48
Pb-Free
NC4
PCMR
FS
BCLK
VDD3
PCMT
VDDL
GND3
DCP
DCN
SDI
SDO
SCLK
13 14 15 16 17 18 19 20 21 22 23 24
Note: For more details on the W681388, please refer to Winbond America’s web site at: http://www.winbond-usa.com
© 2008 All Rights Reserved
Printed in the U.S.A
W681388
很抱歉,暂时无法提供与“W681388DG TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+43.58880
- 200+17.39880
- 500+16.81560
- 1000+16.52400
