IL 711-2B
IL 711-2B
    NVECORP
    DIP-8
    DGTL ISO 2.5KV 2CH GEN PURP 8DIP
IL 711-2B 数据手册
IL711/712 ISOLOOP® High Speed Dual Digital Isolator Functional Diagram Features · +5V/+3.3V or +5V only CMOS/TTL Compatible · High Speed: 110 MBaud · 2500VRMS Isolation (1 min) · 2 ns Typical Pulse Width Distortion · 4 ns Typical Propagation Delay Skew · 10 ns Typical Propagation Delay · 30 kV/us Typical Transient Immunity · 2 ns Channel to Channel Skew · 8-pin PDIP and 8-pin SOIC Packages · UL1577 Approved (File # E207481) · IEC 61010-1 Approved (Report # 607057) IL711 Isolation Applications IL712 · ADCs and DACs · Digital Fieldbus · RS485 and RS422 · Multiplexed Data Transmission · Data Interfaces · Board-To-Board Communication · Digital Noise Reduction · Operator Interface · Ground Loop Elimination · Peripheral Interfaces · Serial Communication · Logic Level Shifting Description NVE's family of high-speed digital isolators are CMOS devices created by integrating active circuitry and our GMR-based and patented* IsoLoop® technology. The IL711 and IL712 are two channel versions of the world's fastest digital isolator with a 110 Mbaud data rate. These devices offer true isolated logic integration in a level not previously available. All transmit and receive channels operate at 110 Mbd over the full temperature and supply voltage range. The symmetric magnetic coupling barrier provides a typical propagation delay of only 10 ns and a pulse width distortion of 2 ns achieving the best specifications of any isolator device. Typical transient immunity of 30 kV/µs is unsurpassed. The IL711 has two transmit channels; the IL712 has one transmit channel and one receive channel. The IL712 operates in full duplex mode making it ideal for many field bus applications. PROFIBUS and RS485 configurations are achieved by combining the IL711/12 and the IL710, which together meet the overall propagation delay specification. The IL711 and IL712 are available in 8-pin PDIP and 8-pin SOIC packages and performance is specified over the temperature range of -40°C to +100°C without any derating. Isoloop® is a registered trademark of NVE Corporation * US Patent number 5,831,426; 6,300,617 and others NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® Absolute Maximum Ratings Parameters Storage Temperature Symbol TS Min. -55 Max. 175 TA -55 125 VDD1,VDD2 -0.5 7 Volts Input Voltage VI -0.5 VDD+0.5 Volts Output Voltage VO -0.5 VDD+0.5 Volts Drive Channel Output Current IO 10 mA Ambient Operating Temperature(1) Supply Voltage Lead Solder Temperature (10s) ESD Units o C o C o 280 2kV Human Body Model C Recommended Operating Conditions Parameters Ambient Operating Temperature Symbol TA Min. -40 Max. 100 Units o C VDD1,VDD2 VDD1,VDD2 3.0 5.5 Volts 4.5 5.5 Volts Logic High Input Voltage VIH 2.4 VDD Volts Logic Low Input Voltage VIL 0 0.8 Volts 1 Psec Supply Voltage (3.0/5.0 V operation) Supply Voltage (5.0 V operation) Minimum Signal Rise and Fall Times tIR,tIF Insulation Specifications Parameter Barrier Impedance Condition Min. Typ. >1014 ||3 7.036 (PDIP) 4.026 (SOIC) Creepage Distance (External) 240 VRMS Leakage Current Max. Units :__pF mm PA 0.2 60Hz Package Characteristics Parameter Capacitance (Input-Output)(5) Thermal Resistance Symbol CI-O Min. Typ. 2 TJCT TJCT (PDIP) (SOIC) Package Power Dissipation Max. Units pF o 150 240 PPD C/W C/W o 150 Test Conditions f = 1MHz Thermocouple located at center underside of package mW IEC61010-1 TUV Certificate Numbers: B 01 07 44230 001 (PDIP) B 01 07 44230 002 (SOIC) Classification as Table 1. Model IL711-2, IL712-2 IL711-3, IL712-3 Pollution Degree II II Material Group III III Max Working Voltage 300 VRMS 150 VRMS Package Type 8–PDIP 8–SOIC 9 9 UL 1577 Component Recognition program. File # E207481 Rated 2500Vrms for 1min. 2 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® Electrical Specifications Electrical Specifications are Tmin to Tmax unless otherwise stated. Parameter Symbol DC Specifications Quiescent Supply Current Quiescent Supply Current IL711 IL712 IL711 IL712 Logic Input Current 3.3 Volt Specifications 5 Volt Specifications Min. Min. IDD1 IDD 2 II Logic High Output Voltage VOH Logic Low Output Voltage VOL Switching Specifications Maximum Data Rate Max. 10 1.5 3.3 2 4 1.5 2 10 -10 VDD-0.1 VDD 0.8*VDD VDD-0.5 0 0.5 100 Max. 15 PA 2.5 5 3 6 mA mA 2.5 3 10 mA PA -10 VDD-0.1 VDD 0.8*VDD VDD-0.5 0.1 0.8 110 0 0.5 100 Test Conditions V IO =-20 PA, VI =VIH I = -4 mA, V =V V IO = 20 PA, VI =VIL I = 4 mA, V =V O 0.1 0.8 110 O MBd I 12 18 10 15 ns CL = 15 pF tPLH 12 18 10 15 ns CL = 15 pF Pulse Width Distortion(2) | tPHL- tPLH | PWD 2 3 2 3 ns CL = 15 pF Propagation Delay Skew(3) tPSK 4 6 4 6 ns CL = 15 pF Output Rise Time (10-90%) tR 2 4 1 3 ns CL = 15 pF Output Fall Time (10-90%) tF 2 4 1 3 ns CL = 15 pF kV/Ps Vcm = 300V ns CL = 15 pF 30 2 20 3 IH IL CL = 15 pF tPHL 20 10 I Propagation Delay Input to Output ( Low to High) |CMH| |CML| TCSK 10 Units Typ. 10 Pulse Width Propagation Delay Input to Output (High to Low) Transient Immunity (Output Logic High or Logic Low)(4) Channel to Channel Skew PW Typ. 8 ns 30 2 3 Notes: 1. 2. 3. 4. 5. Absolute Maximum ambient operating temperature means the device will not be damaged if operated under these conditions. It does not guarantee performance. PWD is defined as | tPHL– tPLH |. %PWD is equal to the PWD divided by the pulse width. tPSK is equal to the magnitude of the worst case difference in tPHL and/or tPLH that will be seen between units at 25OC. CMH is the maximum common mode voltage slew rate that can be sustained while maintaining VO > 0.8 VDD. CML is the maximum common mode input voltage that can be sustained while maintaining VO < 0.8 V. The common mode voltage slew rates apply to both rising and falling common mode voltage edges. Device is considered a two terminal device: pins 1-4 shorted and pins 5-8 shorted. 3 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® Application Notes: Dynamic Power Consumption Data Transmission Rates Isoloop£ devices achieve their low power consumption from the manner by which they transmit data across the isolation barrier. By detecting the edge transitions of the input logic signal and converting these to narrow current pulses, a magnetic field is created around the GMR Wheatstone bridge. Depending on the direction of the magnetic field, the bridge causes the output comparator to switch following the input logic signal. Since the current pulses are narrow, about 2.5ns wide, the power consumption is independent of mark-to-space ratio and solely dependent on frequency. This has obvious advantages over optocouplers whose power consumption is heavily dependent on its on-state and frequency. The approximate power supply current per channel for The reliability of a transmission system is directly related to the accuracy and quality of the transmitted digital information. For a digital system, those parameters which determine the limits of the data transmission are pulse width distortion and propagation delay skew. Propagation delay is the time taken for the signal to travel through the device. This is usually different when sending a low-to-high than when sending a high-to-low signal. This difference, or error, is called pulse width distortion (PWD) and is usually in ns. It may also be expressed as a percentage: PWD% = Maximum Pulse Width Distortion (ns) Signal Pulse Width (ns) x 100% For example: For data rates of 12.5 Mb PWD% = Power Supply Decoupling Both power supplies to these devices should be decoupled with low ESR 47 nF ceramic capacitors. For data rates in excess of 10MBd, use of ground planes for both GND1 and GND2 is highly recommended. Capacitors should be located as close as possible to the device. Signal Status on Start-up and Shut Down To minimize power dissipation, the input signals are differentiated and then latched on the output side of the isolation barrier to reconstruct the signal. This could result in an ambiguous output state depending on power up, shutdown and power loss sequencing. Therefore, the designer should consider the inclusion of an initialization signal in his start-up circuit. Initialization consists of toggling each channel either high then low or low then high, depending on the desired state. 3 ns 80 ns x 100% = 3.75% This figure is almost three times better than for any available optocoupler with the same temperature range, and two times better than any optocoupler regardless of published temperature range. The IsoLoop® range of isolators surpasses the 10% maximum PWD recommended by PROFIBUS, and will run at almost 35 Mb before reaching the 10% limit. Propagation delay skew is the difference in time taken for two or more channels to propagate their signals. This becomes significant when clocking is involved since it is undesirable for the clock pulse to arrive before the data has settled. A short propagation delay skew is therefore critical, especially in high data rate parallel systems, to establish and maintain accuracy and repeatability. The IsoLoop® range of isolators all have a maximum propagation delay skew of 6 ns, which is five times better than any optocoupler. The maximum channel to channel skew in the IsoLoop® coupler is only 3 ns which is ten times better than any optocoupler. Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. 4 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® Applications Isolated PROFIBUS / RS-485 RS-485 Truth Table D DE A B 1 0 Z Z 0 0 Z Z 1 1 1 0 0 1 0 1 R X X 1 0 5 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® IR Soldering Profile Timing Diagram Legend tPLH tPHL tPW tR tF Propagation Delay, Low to High Propagation Delay, High to Low Minimum Pulse Width Rise Time Fall Time IR Soldering Profile Recommended profile shown. Maximum temperature allowed on any profile is 260° C. 6 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com IL711/712 ISOLOOP® IL711-2 and IL712-2 (8-Pin PDIP Package) IL711-3 and IL712-3 (Small Outline SOIC-8 package) Ordering Information: use the following format to order these devices IL 711 -2 B TR7 Bulk Package Blank = Tube TR7 = 7’’ Tape and Reel TR13 = 13’’ Tape and Reel Supply Voltage Blank = 3.3/5.0 VDC B = 5.0 VDC Package -2 = PDIP -3 = SOIC (0.15’’) Valid Part Numbers IL 711-2 IL 711-2B IL 711-3 IL 711-3B IL 711-3BTR13 IL 711-3BTR7 IL 711-3TR13 IL 711-3TR7 IL 712-2 IL 712-2B IL 712-3 IL 712-3B IL 712-3BTR13 IL 712-3BTR7 IL 712-3TR13 IL 712-3TR7 Base Part Number 711 = 2 drive channels 712 = 1 drive and 1 receive channel Product Family IL = Isolators 7 NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.isoloop.com About NVE NVE Corporation is a world leader in the practical commercialization of "spintronics," which many experts believe represents the next generation of microelectronics — the successor to the transistor. Unlike conventional electronics, which rely on electron charge, spintronics uses electron spin to store and transmit information. Spintronics devices are smaller, faster, and more accurate, compared to charge-based microelectronics. It is the spin of electrons that causes magnetism. NVE's products use proprietary spintronic materials called Giant Magnetoresistors (GMR). These materials are made of exotic alloys a few atoms thick, and provide very large signals (the "Giant" in "Giant Magnetoresistor"). NVE has the unique capability to combine leading edge GMR materials with integrated circuits to make high performance electronic components. We are pioneers in creating practical products using this revolutionary technology and introduced the world's first GMR products in 1994. We also license spintronics/Magnetic Random Access Memory (MRAM) designs to world-class memory manufacturers. Our products include: · Digital Signal Isolators · Isolated Bus Transceivers · Magnetic Field Sensors · Magnetic Field Gradient Sensors (Gradiometer) · Digital Magnetic Field Sensors. NVE Corporation 11409 Valley View Road Eden Prairie, Mn 55344-3617 USA Telephone: (952) 829-9217 Fax: (952) 829-9189 Internet: www.nve.com e-mail: isoinfo@nve.com The information provided by NVE Corporation is believed to be accurate. However, no responsibility is assumed by NVE Corporation for its use, nor for any infringement of patents, nor rights or licenses granted to third parties, which may result from its use. No license is granted by implication, or otherwise, under any patent or patent rights of NVE Corporation. NVE Corporation does not authorize, nor warrant, any NVE Corporation product for use in life support devices or systems or other critical applications. The use of NVE Corporation’s products in such applications is understood to be entirely at the customer's own risk. Specifications shown are subject to change without notice. ISB-DS-001-IL711/2-F July 2002
IL 711-2B 价格&库存
很抱歉,暂时无法提供与“IL 711-2B”相匹配的价格&库存,您可以联系我们找货
