WRENCH,COMBO RATCHET 19mm
Combination Ratcheting Wrench19mm
Cat No:
0354-64
UPC No:
783310892908
Description
Compact reversible switch allows a 15° offset of the boxend for clearance of obstacles
Five-degree ratcheting design for versatility and ease of use in tight spaces
Polished chrome finish forsuperior corrosion resistance
Precision heads for accurate fastener fit
Hardened for durability and longer life
Exceeds ASME/ANSI specifications
Lifetime limited warranty
Note: This is not an insulated tool
Specifications
Application : For Versatility And Ease Of Use In Tight Spaces And Accurate Fastener Fit
Drive Size : 19.000 MM
Finish : Polished Chrome
Overall Length : 9-11/16 IN (24.600 CM)
Standard : ASME/ANSI
Type : Metric, Combination
Weight : 0.570 LB (0.260 KG)
很抱歉,暂时无法提供与“0354-64”相匹配的价格&库存,您可以联系我们找货
