BIT,STEP #14 (PKGD)
Kwik Stepper® Step Bits
Cat No:
36414
UPC No:
783310364146
Description
Unique split-tip design penetrates through steel faster
Resists walking or skidding, even on round surfaces
Balanced, double-flute construction requires less pressure, does the work for you
Designed and manufactured in USA.
Specifications
Capacity : Cut Up Through 3/8 IN (9.500 MM) Mild Steel, Copper, Brass,Aluminum, Wood, Plastic
and Laminates
Hole Size : 7/8 IN (22.200 MM), 1-1/8 IN (28.600 MM), 1.201 IN (32.500 MM), 1-7/32 IN (31.000
MM), 1-1/4 IN (31.800 MM), 1-3/8 IN (34.900 MM)
Maximum Material Thickness : 10 GA (3.500 MM)
Minimum Chuck Size : 3/8 IN (9.500 MM)
Overall Length : 3-7/8/ IN (85.700 MM)
Sub Brand : Kwik Stepper
Type : Multi Hole
很抱歉,暂时无法提供与“GSB12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+915.831381+118.78628
