Extract from the online
catalog
SACC-M12MSB-5SC SH
Order No.: 1513570
http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1513570
Sensor/actuator connector, male, straight, 5-pos., M12, shielded, Bcoded, spring-cage connection, metal knurl, cable cross section max.
8 mm
Product notes
WEEE/RoHS-compliant since:
02/14/2006
Commercial data
GTIN (EAN)
4
017918
946661
sales group
D124
Pack
1 pcs.
Customs tariff
85366990
Catalog page information
Page 383 (AX-2009)
http://
www.download.phoenixcontact.com
Please note that the data given
here has been taken from the
online catalog. For comprehensive
information and data, please refer
to the user documentation. The
General Terms and Conditions of
Use apply to Internet downloads.
Technical data
General data
Rated current at 40°C
4A
Rated voltage
60 V
Number of positions
5
Volume resistance
≤ 8 mΩ
PHOENIX CONTACT Inc., USA
http://www.phoenixcon.com
Page 1 / 4
Jan 6, 2011
SACC-M12MSB-5SC SH Order No.: 1513570
Insulation resistance
≥ 100 MΩ
Ambient temperature (operation)
-40 °C ... 85 °C (Male connector / female connector)
General characteristics
Coding
B - inverse
Surge voltage category
II
Pollution degree
3
Degree of protection
IP67
Contact material
CuSn
Contact surface material
Ni/Au
Contact carrier material
PA 66
Material of grip body
Zinc die-cast, nickel-plated
Material, knurls
Nickel-plated brass
Sealing material
NBR
Type of connection
Spring-cage conn.
Conductor cross section stranded min.
0.14 mm²
Conductor cross section stranded max.
0.5 mm²
Conductor cross section AWG/kcmil min.
26
Conductor cross section AWG/kcmil max
External cable diameter
4 mm ... 8 mm
Status display
No
Certificates / Approvals
Certification
CUL, UL
Page 2 / 4
Jan 6, 2011
Diagrams/Drawings
Functional drawing
Assembly of the shielded conductor
1) For straight version: 28 mm
Slide the pressure nut onto the cable, strip the cable, shorten
the shield, strip the cores. Thread the cores through the
housing and connect them. Screw the body of the connector
onto the housing. Tighten the pressure nut.
Dimensioned drawing
M12 x 1 male connector, straight, shielded
Schematic diagram
Pin assignment M12 male connector, 5-pos., B-coded, male
side
Page 3 / 4
Jan 6, 2011
Address
586 Fulling Mill Road
Middletown, PA 17057,USA
Phone (800) 888-7388
Fax (717) 944-1625
© 2010 Phoenix Contact
Technical modifications reserved;
Page 4 / 4
Jan 6, 2011
很抱歉,暂时无法提供与“81513570”相匹配的价格&库存,您可以联系我们找货
