IFIX EU145220
IFIX EU145220
    PIMORONI
    BIT SET ASSORTED W/CASE 97PC
IFIX EU145220 数据手册
  Macro Bit Set IFIX EU145220   Standard and Rare Bits for Standard and Rare Jobs     All the Torx, Phillips, Pozidriv, Clutch, Torq, Spline, Triwing, Square, Spanner, Hex, Flathead, and Triangle bits you'll need! 97 high quality 1/4" bits made out of CR-V steel Bits selected by iFixit techs, ensuring that you get all the bits you need and none that you don't. Elegant aluminum case with see-through window and labeled bit organizer means you'll always be able to find the right bit. Kit Contents:     1/4" Magnetic bit holder 1/4" Socket to 1/4" drive adaptor 1/4" Driver to 1/4" socket adaptor 97 bits in the following sizes: o Wing nut driver o Phillips #0, #1, #2 (x3), #3 o Flathead 2 mm, 3 mm, 4 mm, 5 mm, 6 mm, 7 mm, 8 mm o Torx T5, T6, T8, T10, T15, T20, T25, T27, T30, T35, T40 o Torx Security TR8, TR10 TR15, TR20, TR25, TR27, TR30, TR35, TR40 o Metric Hex 1.5, 2, 2.5, 3, 4, 5, 5.5, 6, 7, 8 mm o Metric Hex Security 2, 2.5, 3, 4, 5, 5.5, 6, 7, 8 o SAE Hex (Allen) 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4" o SAE Hex Security 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32" 1/4" o Clutch 1, 2, 3 o Torq 6, 8, 10 o Spline M5, M6, M8 o Triwing 1, 2, 3, 4 o Square (Robertson) 0, 1, 2, 3 o Spanner (snake eye) 4, 6, 8, 10 o Pozi-Drive (PZ) 0, 1, 2, 3 o Triangle 2 mm                                                          https://shop.pimoroni.com/products/macro‐bit‐set 4/17/2017
IFIX EU145220 价格&库存
很抱歉,暂时无法提供与“IFIX EU145220”相匹配的价格&库存,您可以联系我们找货
IFIX EU145220
    • 4+310.662104+40.26773
