SLG7NT41502VTR
SLG7NT41502VTR
    DIALOGSEMICONDUCTOR(戴乐格)
    UFQFN14
    INTEL CURIE MODULE, SILEGO POWER
SLG7NT41502VTR 数据手册
SLG7NT41502 CURIE BASED WEARABLE LS_ON Features Output Summary • 1 Output — Push Pull 2X • 1 Output — Open Drain NMOS 1X • 3 Outputs — Open Drain NMOS 2X Silego Technology, Inc. SLG7NT41502_DS_r104 SLG7NT41502_GP_r002 VDD 1 14 13 12 OPM2P6_DISCHARGE nBUTTON_IN 2 11 nBUTTON_MONITOR nEXIT_SHIPMODE 3 10 PG_IN POR_B 4 9 nPG_IN SHIPMODE_EN 5 8 GND 6 7 DISCHARGE_0 • Low Power Consumption • Pb-Free / RoHS Compliant • Halogen-Free • STQFN-14 Package DISCHARGE_1 Pin Configuration Silego SLG7NT41502 is a low power and small form device. The SoC is housed in a 1.6 x 2.0 mm STQFN package which is optimal for using with small devices. SHIPMODE_STROBE General Description STQFN-14 TOP VIEW Rev 1.04 Revised January 23, 2017 SLG7NT41502 CURIE BASED WEARABLE Pin Configuration Pin # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Pin Name VDD nBUTTON_IN nEXIT_SHIPMODE POR_B SHIPMODE_EN SHIPMODE_STROBE DISCHARGE_0 GND nPG_IN PG_IN nBUTTON_MONITOR OPM2P6_DISCHARGE DISCHARGE_1 LS_ON Type PWR Digital Input Digital Input Digital Input Digital Input Digital Input Digital Output GND Digital Input Digital Input Digital Output Digital Output Digital Output Digital Output Pin Description Supply Voltage Digital Input with Schmitt trigger Digital Input with Schmitt trigger Low Voltage Digital input Low Voltage Digital input Low Voltage Digital input Open Drain NMOS 2X Ground Digital Input with Schmitt trigger Digital Input with Schmitt trigger Open Drain NMOS 1X Open Drain NMOS 2X Open Drain NMOS 2X Push Pull 2X Ordering Information Part Number SLG7NT41502V SLG7NT41502VTR SLG7NT41502_DS_r104 Package Type V=STQFN-14 STQFN-14 – Tape and Reel (3k units) Page 2 2 SLG7NT41502 CURIE BASED WEARABLE Absolute Maximum Conditions Parameter Min. Max. Unit VHIGH to GND -0.3 7 V Voltage at input pins -0.3 7 V Current at input pin -1.0 1.0 mA Storage temperature range -65 125 °C Junction temperature -- 150 °C ESD Protection (Human Body Model) 2000 -- V ESD Protection (Charged Device Model) 1000 -- V Moisture Sensitivity Level 1 Electrical Characteristics (@ 25°C, unless otherwise stated) Symbol Parameter VDD Supply Voltage Operating TA Temperature IQ IA VO IO VIH Quiescent Current Active Current Maximal Voltage Applied to any PIN in High-Impedance State Maximal Average or DC Current (note 1) HIGH-Level Input Voltage (Note 2) SLG7NT41502_DS_r104 Condition/Note Static inputs and floating outputs PIN4 = 1; PIN14 = 1; DFF4 = 0 @VDD = 3.3V Static inputs and outputs PIN4 = 0; PIN14 = 0; DFF4 = 1 @VDD = 3.3V Static inputs and outputs PIN4 = 1; PIN14 = 1; DFF4 = 0 @VDD = 5.5V Static inputs and outputs PIN4 = 0; PIN14 = 0; DFF4 = 1 @VDD = 5.5V Static outputs PIN4 = 0; PIN14 = 1; DFF4 = 0 @VDD = 3.7V Static outputs PIN4 = 0; PIN14 = 0; DFF4 = 0 @VDD = 3.3V Static outputs PIN4 = 0; PIN14 = 1; DFF4 = 0 @VDD = 5.5V Per Each Chip Side Logic Input with Schmitt Trigger, at VDD=1.8V At temperature -45°C +85°C (note 1) Low-Level Logic Input, at VDD=1.8V At temperature -45°C +85°C (note 1) Logic Input with Schmitt Trigger, at VDD=3.3V At temperature -45°C +85°C (note 1) Min. 1.71 Typ. 3.6 Max. 5.5 Unit V -40 25 85 °C -- 1 -- -- 1 -- -- 1 -- -- 1 -- -- 50 -- -- 1.8 -- -- 50 -- -- -- VDD V -- -- 90 mA 1.27 -- VDD 0.98 -- VDD 2.13 -- VDD µA Page 3 3 µA V SLG7NT41502 CURIE BASED WEARABLE VIL VHYS IIH IIL VOH VOL LOW-Level Input Voltage (Note 2) Schmitt Trigger Hysteresis Voltage HIGH-Level Input Current LOW-Level Input Current HIGH-Level Output Voltage (note 1) LOW-Level Output Voltage (note 1) SLG7NT41502_DS_r104 Low-Level Logic Input, at VDD=3.3V At temperature -45°C +85°C (note 1) Logic Input with Schmitt Trigger, at VDD=5.0V At temperature -45°C +85°C (note 1) Low-Level Logic Input, at VDD=5.0V At temperature -45°C +85°C (note 1) Logic Input with Schmitt Trigger, at VDD=1.8V Low-Level Logic Input, at VDD=1.8V At temperature -45°C +85°C (note 1) Logic Input with Schmitt Trigger, at VDD=3.3V At temperature -45°C +85°C (note 1) Low-Level Logic Input, at VDD=3.3V At temperature -45°C +85°C (note 1) Logic Input with Schmitt Trigger, at VDD=5.0V At temperature -45°C +85°C (note 1) Low-Level Logic Input, at VDD=5.0V At temperature -45°C +85°C (note 1) 1.13 -- VDD 3.16 -- VDD 1.23 -- VDD -- -- 0.44 -- -- 0.52 -- -- 0.95 -- -- 0.69 -- -- 1.51 -- -- 0.78 0.273 -- 0.792 V Logic Input PINs; VIN = VDD -1.0 -- 1.0 µA Logic Input PINs; VIN = 0V -1.0 -- 1.0 µA 1.679 1.792 -- 2.861 3.201 -- 4.330 4.878 -- -- 0.007 0.010 -- 0.007 0.010 -- 0.002 0.010 -- 0.070 0.130 -- 0.079 0.130 Logic Input with Schmitt Trigger Push Pull, IOH = 100uA, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Push Pull, IOH = 3mA, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Push Pull, IOH = 5mA, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) Open Drain, IOL = 100uA, 1X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Push Pull, IOL = 100uA, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Open Drain, IOL = 100uA, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Open Drain, IOL = 3mA, 1X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Push Pull, IOL = 3mA, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) V Page 4 4 V V SLG7NT41502 CURIE BASED WEARABLE IOH IOL HIGH-Level Output Current (note 1) LOW-Level Output Current (note 1) SLG7NT41502_DS_r104 Open Drain, IOL = 3mA, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Open Drain, IOL = 5mA, 1X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) Push Pull, IOL = 5mA, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) Open Drain, IOL = 5mA, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) Push Pull & PMOS OD, VOH = VDD-0.2, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Push Pull & PMOS OD, VOH = 2.4 V, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Push Pull & PMOS OD, VOH = 2.4 V, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) Push Pull, VOL =0.15V, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Open Drain, VOL =0.15V, 1X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Open Drain, VOL =0.15V, 2X Driver, at VDD=1.8 V At temperature -45°C +85°C (note 1) Push Pull, VOL =0.4V, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Open Drain, VOL =0.4V, 1X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) Open Drain, VOL =0.4V, 2X Driver, at VDD=3.3 V At temperature -45°C +85°C (note 1) -- 0.040 0.070 -- 0.090 0.160 -- 0.101 0.160 -- 0.050 0.080 2.069 3.390 -- 11.278 21.634 -- 40.059 59.691 -- 1.52 2.840 -- 1.530 2.840 -- 3.060 5.680 -- 8.130 13.840 -- 8.130 13.850 -- mA mA 16.260 23.700 -- Push Pull, VOL =0.4V, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) 12.020 19.460 -- Open Drain, VOL =0.4V, 1X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) 12.030 19.460 -- Open Drain, VOL =0.4V, 2X Driver, at VDD=5.0 V At temperature -45°C +85°C (note 1) 24.060 38.920 -- Page 5 5 SLG7NT41502 CURIE BASED WEARABLE VACMP0 GACMP0 VHYST RPULL_UP RPULL_DOWN RDIS TCNT0 Analog Comparator Threshold Voltage Analog Comparator0 IN+ gain Analog Comparator Hysteresis Voltage (note 1) Internal Pull Up Resistance Internal Pull Down Resistance Discharge Resistance Counter0 Period (WS Ctrl) TDLY1 Delay1 Time TDLY2 Delay2 Time TDLY3 Delay3 Time TSU PONTHR POFFTHR Start up Time Power On Threshold Power Off Threshold Low to High transition, at temperature 25°C. Low to High transition, at temperature -40 +85°C (note 1) High to Low transition, at temperature 25°C High to Low transition, at temperature -40 +85°C (note 1) 3532.7 3582.9 3633.1 3519.7 3579.8 3644.2 mV 2948.8 2991.5 3034.2 2937.1 2988.1 3040.9 ACMP 0 -- 0.33 -- ACMP 0 -- 200 -- mV Pull up on PIN 2, 3 70 100 130 kΩ Pull down on PINs 5, 6 70 100 130 kΩ External resistor on PIN7, PIN12 and PIN13 270 -- -- Ω At temperature 25°C At temperature -40°C +85°C (note 1) At temperature 25°C At temperature -40°C +85°C (note 1) At temperature 25°C At temperature -40°C +85°C (note 1) At temperature 25°C At temperature -40°C +85°C (note 1) From VDD rising past PONTHR VDD Level Required to Start Up the Chip VDD Level Required to Switch Off the Chip 153.14 153.14 195.04 184.59 486.52 460.44 195.04 184.59 0.462 0.961 0.875 176.87 178.87 200.45 200.45 500.02 500.02 200.45 200.45 1.4 1.312 1.109 207.44 217.81 206.90 216.47 516.10 539.10 206.90 216.47 4.999 1.659 1.288 1. Guaranteed by Design. 2. No hysteresis for Low Voltage Digital Input SLG7NT41502_DS_r104 Page 6 6 ms ms ms ms ms V V SLG7NT41502 CURIE BASED WEARABLE Datasheet Revision 1.04 Programming Code Number 002 Locked Status L Part Code Revision Date V6 B 01/23/2017 The IC security bit is locked/set for code security for production unless otherwise specified. Revision number is not changed for bit locking. SLG7NT41502_DS_r104 Page 7 7 SLG7NT41502 CURIE BASED WEARABLE Package Drawing and Dimensions 14 Lead STQFN Package SLG7NT41502_DS_r104 Page 8 8 SLG7NT41502 CURIE BASED WEARABLE Tape and Reel Specification # of Package Type Pins STQFN 14L FC 0.4P Green 14 Max Units Nominal Package Size (mm) per reel 1.6x2.0x0.55 3000 Trailer A per box Reel & Hub Size (mm) Pockets 3000 178/60 100 Leader B Pocket (mm) Length Length Pockets (mm) (mm) 400 100 Width Pitch 8 4 400 Carrier Tape Drawing and Dimensions Package Type STQFN 14L FC 0.4P Green Pocket BTM Length (mm) Pocket BTM Width (mm) Pocket Depth (mm) Index Hole Pitch (mm) Pocket Pitch (mm) Index Hole Diameter (mm) Index Hole Index Hole to Tape to Pocket Tape Width Edge Center (mm) (mm) (mm) A0 B0 K0 P0 P1 D0 E F W 1.9 2.3 0.8 4 4 1.5 1.75 3.5 8 Refer to EIA-481 Specifications Recommended Reflow Soldering Profile 3 Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 1.76 mm (nominal). More information can be found at www.jedec.org. SLG7NT41502_DS_r104 Page 9 9 SLG7NT41502 CURIE BASED WEARABLE Silego Website & Support Silego Technology Website Silego Technology provides online support via our website at http://www.silego.com/.This website is used as a means to make files and information easily available to customers. For more information regarding Silego Green products, please visit our website. Our Green product lines feature: GreenPAK1 / GreenPAK2 / GreenPAK3/ GreenPAK 4 / GreenPAK 5: Programmable Mixed Signal Matrix products GreenFET1 / GreenFET3: MOSFET Drivers and ultra-small, low RDSon Load Switches GreenCLK1 / GreenCLK2 / GreenCLK3: Crystal replacement technology Products are also available for purchase directly from Silego at the Silego Online Store at http://www.silego.com/buy/ . Silego Technical Support Datasheets and errata, application notes and example designs, user guides, and hardware support documents and the latest software releases are available at the Silego website or can be requested directly at info@silego.com. For specific GreenPAK design or applications questions and support please send e-mail requests to GreenPAK@silego.com Users of Silego products can receive assistance through several channels: Contact Your Local Sales Representative Customers can contact their local sales representative or field application engineer (FAE) for support. Local sales offices are also available to help customers. More information regarding your local representative is available at the Silego website or send a request to info@silego.com Contact Silego Directly Silego can be contacted directly via e-mail at info@silego.com or user submission form, located at the following URL: http://support.silego.com/ Other Information The latest Silego Technology press releases, listing of seminars and events, listings of world wide Silego Technology offices and representatives are all available at http://www.silego.com/ THIS PRODUCT HAS BEEN DESIGNED AND QUALIFIED FOR THE CONSUMER MARKET. APPLICATIONS OR USES AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS ARE NOT AUTHORIZED. SILEGO TECHNOLOGY DOES NOT ASSUME ANY LIABILITY ARISING OUT OF SUCH APPLICATIONS OR USES OF ITS PRODUCTS. SILEGO TECHNOLOGY RESERVES THE RIGHT TO IMPROVE PRODUCT DESIGN, FUNCTIONS AND RELIABILITY WITHOUT NOTICE SLG7NT41502_DS_r104 Page 10 10
SLG7NT41502VTR 价格&库存
很抱歉,暂时无法提供与“SLG7NT41502VTR”相匹配的价格&库存,您可以联系我们找货
