KIT-14216
KIT-14216
    SPARKFUNELECTRONICS
    MICRO BOT KIT
KIT-14216 数据手册
  SparkFun micro:bot kit KIT-14216 Description: Robots are fun, and the micro:bit is the perfect controller for learning how to build and program robots! Combining the micro:bit with the SparkFun moto:bit carrier board creates a flexible, low-cost robotics platform for robot enthusiasts young and old! With the SparkFun micro:bot kit you will be able to create simple robots quickly without spending hours learning how to build and program your bot. Inside each micro:bot kit you will find all the components required to build your micro:bit into a robotics powerhouse; the only part that’s not included is the micro:bit itself. Simply add your own micro:bit to the provided moto:bit, assemble the kit, and you will be ready to start moving. The SparkFun micro:bot kit is a great way to get your feet wet in the world of robotics. The kit does not require any soldering and is recommended for anyone curious about robotics or the micro:bit platform. The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential! Note: The SparkFun micro:bot kit is available to pre-order and does NOT include a micro:bit board; we expect to start shipping units by early July. Adding a pre-order product to an order may cause a delay. Be sure to uncheck “ship complete order” in your cart to avoid delays in shipping in-stock items. Kit Includes:        1x SparkFun moto:bit 1x Shadow Chassis 3x SparkFun RedBot Sensor — Line Follower 2x Sub-Micro Servo 2x Hobby Gearmotor 2x Wheel — 65mm (Rubber Tire, Pair) 3x Jumper Wire — 3-pin, 6"                                                 https://www.sparkfun.com/products/14216 6‐26‐17
KIT-14216 价格&库存
很抱歉,暂时无法提供与“KIT-14216”相匹配的价格&库存,您可以联系我们找货
