KIT-14217
KIT-14217
    SPARKFUNELECTRONICS
    MICRO CLIMATE KIT
KIT-14217 数据手册
  SparkFun micro:climate kit KIT-14217 Description: The SparkFun micro:climate Kit is a full weather station kit that is built on top of the weather:bit carrier board. Unlike previous weather kits we’ve carried, the micro:climate kit includes our tried-and-true Weather Meters and Soil Moisture Sensor, so whether you’re an agriculturalist, a professional meteorologist or a hobbyist, you will be able to build a high-grade weather station powered by the micro:bit. You can even talk via wireless communication between two micro:bits with this kit to be able to monitor the weather without being exposed to it! Inside each micro:climate kit you will find all the components required to build your micro:bit into a go-to weather sensor; the only parts not included are two AA batteries and the micro:bit itself. Simply add your own micro:bit to the provided weather:bit, assemble the kit, and you will be ready to start sensing. The SparkFun micro:climate kit is a great way to get your feet wet in high-grade sensors — just not literally; that’s the weather:bit’s job! The kit does not require any soldering and is recommended for anyone curious about weathersensing technology or the micro:bit platform. The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential! Note: The SparkFun micro:climate kit is available to pre-order and does NOT include a micro:bit board; we expect to start shipping units by early July. Adding a pre-order product to an order may cause a delay. Be sure to uncheck “ship complete order” in your cart to avoid delays in shipping instock items. Kit Includes:         1x SparkFun weather:bit 1x Weather Meters 1x SparkFun Soil Moisture Sensor 1x SparkFun OpenLog 1x Waterproof Temperature Sensor 1x micro:bit Battery Holder - 2xAA 1x Pocket Screwdriver Set 10x Jumper Wire (12in. M/M)                                                  https://www.sparkfun.com/products/14217 6‐26‐17
KIT-14217 价格&库存
很抱歉,暂时无法提供与“KIT-14217”相匹配的价格&库存,您可以联系我们找货
