TOL-14223
TOL-14223
    SPARKFUNELECTRONICS
    HEX KEY SET W/HOLDER 9PC
TOL-14223 数据手册
  Hex Key Set - Metric (Ball End, 9 Pieces) TOL-14223 Description: This is a set of nine high-quality hex keys from Allen. Each key in this set is equipped with a ball end, allowing an entry angle up to 25° in the screw to work in hard-to-reach areas. These specific keys utilize the metric measurement system. These are the go-to hex keys we prefer to use when metric is involved! Each hex key is composed of a black oxide-finished, tempered steel alloy and comes in a noninterference, hinged “caddy” to provide easy access. All hex keys are precision-formed to exact dimensional tolerances for precise fit. Includes:           1x 1.5mm Hex Key 1x 2mm Hex Key 1x 2.5mm Hex Key 1x 3mm Hex Key 1x 4mm Hex Key 1x 5mm Hex Key 1x 6mm Hex Key 1x 8mm Hex Key 1x 10mm Hex Key 1x Hex Key Caddy                                                 https://www.sparkfun.com/products/14223 6‐13‐17
TOL-14223
PDF文档的物料型号为:TMS320F28069PNT20。
器件简介:TMS320F28069PNT20是一款由德州仪器(Texas Instruments)生产的32位浮点DSP(数字信号处理器),适用于电机控制、工业自动化等高要求的实时控制应用。
引脚分配:该器件拥有多种引脚配置,包括电源引脚、地引脚、I/O引脚、通信接口引脚等。
参数特性:具有高达150 MHz的时钟频率,拥有丰富的外设接口,如CAN、SCI、SPI、I2C等。
功能详解:提供了高精度的模拟输入、模拟输出、PWM发生器、ADC和DAC功能。
应用信息:适用于高精度电机控制、工业自动化、电力电子转换等应用领域。
封装信息:采用PQFP封装,具有较好的散热性能和电气性能。
TOL-14223 价格&库存
很抱歉,暂时无法提供与“TOL-14223”相匹配的价格&库存,您可以联系我们找货
