TOL-14190
TOL-14190
    SPARKFUNELECTRONICS
    BIT SET PHIL SLOT W/HANDLE 5PC
TOL-14190 数据手册
    Chapman Pocket Screwdriver Set TOL-14190 Description: The Chapman Pocket Screwdriver Set is a unique addition to the screwdriver family, as it utilizes a ¼" ratchet, similar to one found on a socket wrench, as well as four custom-built drive bits. This pocket screwdriver is aptly named for its size — not only fitting in your pocket but also fitting into tight spaces where a normal-sized screwdriver would not be able to fit. Moreover, to change the direction you need the screw to go, just flip the pocket screwdriver over! The two Phillips and two flat bits included in the set have been crafted to feature a ball detent for a snug fit inside the 20-tooth gear ratchet and knurled ends for finger tightening. Each screwdriver performs four times the torque of a normal screwdriver and has been milled in the United States from stainless steel. Includes:      1x Chapman Screwdriver Ratchet 1x ¼" Flat Bit 1x 3/16" Flat Bit 1x Phillips #1 Bit 1x Phillips #2 Bit                                                 https://www.sparkfun.com/products/14190 6‐13‐17
TOL-14190 价格&库存
很抱歉,暂时无法提供与“TOL-14190”相匹配的价格&库存,您可以联系我们找货
