PPTC061LFBN
PPTC061LFBN
    SULLINS
    6 位 接头 连接器 0.100"(2.54mm) 通孔 锡
PPTC061LFBN 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 648 INITIAL RELEASE 6/15/2005 TT B 736 DIM B LETTER, PINS WIDTH 6/19/2005 TT C 1126 UPDATE SPECIFICATIONS 6/12/2006 TT D 1533 10/18/2007 VJ E 1869 ADDED MIN/MAX CONTACT DEPTH DIM UPDATE MAX CONTACT DEPTH, TOLERANCE & NOTE, ADD SINGLE ROW PCB LAYOUT 12/23/2008 JH F E E A DUAL ROWS D A .100 2.54 .100 2.54 D .100 2.54 .040±.002 1.02±0.05 SINGLE ROW .1250 3.175 MIN CONTACT DEPTH C RECOMMENDED PCB LAYOUT SINGLE ROW .238±.008 6.05±0.20 MAX CONTACT DEPTH .040±.002 1.02±0.05 RECOMMENDED PCB LAYOUT DUAL ROWS SINGLE ROW DUAL ROWS .098 2.50 C .197 5.00 .335±.010 8.50±0.25 B A B .126±.012 3.20±0.30 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 7 .016±.002 0.40±0.05 .100±.002 2.54±0.05 .100±.002 2.54±0.05 A±.008 [ 0.20] B±.014 [ 0.35] *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 .016±.002 0.40±0.05 .030±.002 0.75±0.05 6 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 5 .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 12/15/08 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER FEMALE, 2.54mm CC, ST xPxCxxxLFBN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10492 SCALE: 16:1 2 E SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10492, P(N)PxCxxxLFBN-RC PRINT: 2/3/2009 A
PPTC061LFBN
1. 物料型号:文档中提到了物料型号的编码规则,例如xPxCxx xLFBN-RC,其中P代表排数,C代表引脚数,x代表其他特定信息。
2. 器件简介:文档列出了不同版本的修订历史,从2005年的初始发布到2008年的更新,包括尺寸变更和规格更新。
3. 引脚分配:提供了不同排数(单排和双排)的引脚分配表,包括引脚间距和引脚数。
4. 参数特性:文档详细列出了引脚间距、最大接触深度、最小接触深度等参数,以及材料规格,如绝缘材料、接触材料、电镀类型。
5. 功能详解:提供了推荐的PCB布局指南,包括单排和双排的布局建议。
6. 应用信息:文档中提到了电流额定值、绝缘电阻、接触电阻、耐电压、工作温度范围等电气特性。
7. 封装信息:包含了尺寸和公差信息,以及符合RoHS标准的声明。
PPTC061LFBN 价格&库存
很抱歉,暂时无法提供与“PPTC061LFBN”相匹配的价格&库存,您可以联系我们找货
