PRPN101PAEN
PRPN101PAEN
    SULLINS
    CONN HEADER 2MM SNGL STR 10POS
PRPN101PAEN 数据手册
3 2 1 62.00 64.00 66.00 68.00 70.00 72.00 74.00 76.00 78.00 32 33 34 35 36 37 38 39 40 80.00 78.00 76.00 74.00 72.00 70.00 68.00 66.00 64.00 62.00 60.00 58.00 56.00 54.00 52.00 50.00 48.00 46.00 44.00 42.00 40.00 38.00 36.00 34.00 32.00 30.00 28.00 26.00 24.00 22.00 20.00 14.00 801 E. MISSION RD. SAN MARCOS, CA 92069 SULLINS 60.00 31 48.00 25 58.00 46.00 24 30 44.00 23 56.00 42.00 22 54.00 40.00 21 29 38.00 20 28 36.00 19 52.00 34.00 18 27 32.00 17 50.00 30.00 16 26 28.00 22.00 12 26.00 20.00 11 15 18.00 14 16.00 9 10 24.00 18.00 14.00 8 13 16.00 12.00 7 12.00 10.00 8.00 8.00 10.00 6.00 4 6.00 6 4.00 3 B 4.00 5 A 2.00 DIMENSIONS 2 No. of Contacts A .Xß +- .XX +- 0.05 A X.ß +- .X +- 0.10 GENERAL TOLERANCE XX. +XXX. +X. +- 0.20 .XXX +SIZE UNIT A4 SCALE MM 6:1 2.80±0.20 2.00+-.015 4.00±0.20 2.00±0.20 C AC 500 V -40 Degrees C. - +105 Degrees C. Brass PBT,UL 94V-0 Overall Gold or Selective Plating Gold/Tin Dielectric Withstanding: Operating Temperature: Contact Material: Insulator Material: Contact Finish: B APPROVE CHECK DRAWN C DATE DATE DATE T0016 D PR_Nxx1PAEN PARTS NO. DWG. NO. TITLE the part number designates plating. Insert: P = Gold flash all over W = Selective Gold Flash / Tin on tail Z = 10u" selective Gold / Tin on Tail X = A30u" selective gold / Tin on tail E SHEET A REV. Contact Sullins Electronics for additional plating options available. Standard Part is: PBT Overall Gold Flash plating 5000 Mega Ohms min. 1 Amp E Current Rating: Insulator Resistance: SPECIFICATIONS D 0.50X0.50 +-0.05 To complete the part number, replace "xx" with number of contacts. The 3rd letter in B +-0.50 A +-0.10 2.00 +-0.10 B 11-27-02 Added information notes A 3 2 1
PRPN101PAEN 价格&库存
很抱歉,暂时无法提供与“PRPN101PAEN”相匹配的价格&库存,您可以联系我们找货
