PRPN111PARN
PRPN111PARN
    SULLINS
    CONN HEADER 2MM SNGL R/A 11POS
PRPN111PARN 数据手册
3 2 1 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 78 74 76 70 72 66 68 62 64 58 60 54 56 50 52 46 48 44 40 42 38 34 36 30 32 28 24 26 22 18 20 14 16 12 8 10 801 E. MISSION RD. SAN MARCOS, CA 92069 Sullins .XX +- A 0.05 .Xß +- GENERAL TOLERANCE XX. +XXX. +X. +- 0.20 .XXX +.X +- 0.10 X.ß +SIZE UNIT A4 SCALE MM 6:1 B +-0.50 A +-0.10 2.00 +-0.10 A 11-27-02 Added information notes 10 12 5 6 NO. OF DIMENSIONS B A CONTACTS 4 2 2 6 3 4 6 4 8 A B B APPROVE CHECK DRAWN 1.00 +-0.15 4.00±0.20 PBT,UL 94V-0 Overall Gold or Selective Plating Gold/Tin Insulator Material: Contact Finish: 2.00 +-0.15 Brass Contact Material: 2.80±0.20 500VAC -40 Degrees C. to +105 Degrees C. Dielectric Withstanding: Operating Temperature: Contact Sullins Electronics for additional plating options available. Standard Part is: PBT Overall Gold Flash plating 1 Amp 5000 Megohms min. E Current Rating: Insulator Resistance: SPECIFICATIONS D C DATE DATE DATE PARTS NO. DWG. NO. D PR_Nxx1PARN T0015 TITLE E SHEET A REV. To complete the part number, replace "xx" with number of contacts. The 3rd letter in the part number designates plating. Insert: P = Gold flash all over W = Selective Gold Flash / Tin on tail Z = 10u" selective Gold / Tin on Tail X = A30u" selective gold / Tin on tail 2.00±0.20 0.5 x 0.5 +-0.05 C 3 2 1
PRPN111PARN 价格&库存
很抱歉,暂时无法提供与“PRPN111PARN”相匹配的价格&库存,您可以联系我们找货
