SBH51-LPPE-D17-ST-BK
    SULLINS
    插件
    线对板针座 插件
SBH51-LPPE-D17-ST-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2364 INITIAL RELEASE 06/08/2011 LH F F B E E C 2.70 .106 4.30 .169 D D 2.00 .079 3.40 .134 2.50 .098 C 1.00 .039 1.00 .039 0.30 .012 C A A 1.00 .039 0.60 .024 1.00 .039 B A NOTES: 1. INSULATOR MATERIAL: LCP, UL 94V-0, BLACK. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1 AMP PER CONTACT. 5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 300V AC. 8. OPERATING TEMPERATURE: -40° C TO +125° C. 9. *PROCESSING TEMP.: 230° C FOR 60 SECS MAX. (260° C FOR 10 SECS MAX.) 10. MATES WITH SFM210 SERIES. RECOMMENDED PCB LAYOUT DRAWN 7 6 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 B TOLERANCES: ANGULAR: .X= .3 [.01] .XX= .20 [.008] .XXX= .100 [.0040] RoHS COMPLIANT 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 06/08/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 3 BOX HEADER, 1.00mm[.039"] CC/RS, ST SBH51-LP_E-D_ _-ST-BK CAGE CODE 54453 DWG. NO. 11774 SCALE: 8:1 SHEET 1 OF 1 2 1 REV A FILE NAME: Z:\ECO PENDING\2364, SBH51 BOX HEADER\11774, SBH51-LP_E-D_ _-ST-BK PRINT: 6/10/2011 A
SBH51-LPPE-D17-ST-BK 价格&库存
很抱歉,暂时无法提供与“SBH51-LPPE-D17-ST-BK”相匹配的价格&库存,您可以联系我们找货
    • 1+41.73120
    • 198+16.65360
    • 495+16.09200
    • 990+15.82200
    • 33+21.4620333+2.77804
