SBH51-LPSE-D41-SP-BK
    SULLINS
    SMD
    线对板针座 立贴
SBH51-LPSE-D41-SP-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2364 INITIAL RELEASE 06/08/2011 LH F F C E E 2.70 .106 1.00 .039 4.30 .169 B D D 2.00 .079 3.40 .134 3.60 .142 0.10[.004] 0.95 .037 2X 0.64±0.10 .025±.004 OPTIONAL SEE P/N CODING 6.16 .243 D 2X 0.80±0.05 .031±.002 A C A 0.56±0.05 .022±.002 C 1.00 .039 1.00 .039 0.30 .012 2.40 .094 7.00 .276 OPTIONAL SEE P/N CODING 0.80 .031 D B A NOTES: 1. INSULATOR MATERIAL: LCP, UL 94V-0, BLACK. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1 AMP PER CONTACT. 5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 300V AC. 8. OPERATING TEMPERATURE: -40° C TO +125° C. 9. *PROCESSING TEMP.: 230° C FOR 60 SECS MAX. (260° C FOR 10 SECS MAX.) 10. MATES WITH SFM210 SERIES. RECOMMENDED PCB LAYOUT DRAWN 7 6 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 B TOLERANCES: ANGULAR: .X= .3 [.01] .XX= .20 [.008] .XXX= .100 [.0040] RoHS COMPLIANT 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 06/08/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 3 BOX HEADER, 1.00mm[.039"] CC/RS, SMT SBH51-LP_E-D_ _-S_-BK CAGE CODE 54453 DWG. NO. 11775 SCALE: 5:1 SHEET 1 OF 1 2 1 REV A FILE NAME: Z:\ECO PENDING\2364, SBH51 BOX HEADER\11775, SBH51-LP_E-D_ _-S_-BK PRINT: 6/10/2011 A
1. 物料型号:SBH51-LP_E-D_ _-S_-BK,有多个变体,如SBH51-LP_E-D03-S-BK到SBH51-LP_E-D50-S-BK,每个型号都有不同的引脚数量和尺寸。
2. 器件简介:文档中没有提供详细的器件简介,但提到了与SFM210系列兼容。
3. 引脚分配:文档列出了不同型号的引脚数量和尺寸,例如SBH51-LP_E-D03-S-BK有3个引脚,SBH51-LP_E-D50-S-BK有50个引脚。
4. 参数特性: - 绝缘体材料:LCP, UL 94V-0, 黑色。 - 接触材料:磷青铜。 - 接触镀层:见型号编码。 - 电流额定值:每个接触1安培。 - 绝缘体电阻:最小1000兆欧。 - 接触电阻:最大20毫欧。 - 耐电压:300V交流。 - 工作温度:-40°C至+125°C。 - 加工温度:最高230°C持续60秒(或260°C持续10秒)。
5. 功能详解:文档中没有提供详细的功能详解
6. 应用信息:文档中没有提供具体的应用信息,但提到了与SFM210系列兼容。
7. 封装信息封装信息包括了不同型号的尺寸和引脚间距。
8. 其他:文档还包含了一些制造和设计注意事项,如推荐的PCB布局、公差、RoHS合规性等。
SBH51-LPSE-D41-SP-BK 价格&库存
很抱歉,暂时无法提供与“SBH51-LPSE-D41-SP-BK”相匹配的价格&库存,您可以联系我们找货
