SWR120-NPEG-S15-SM-BG
    SULLINS
    CONN HDR 1.25MM TIN 15POS SMD
SWR120-NPEG-S15-SM-BG 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2002 INITIAL RELEASE 7/17/2009 JH F F BACK VIEW FRONT VIEW E E CIRCUIT 1 A 1.25 .049 0.80 .031 3.60 .142 1.60 .063 D D 0.60 .024 3.00 .118 1.25±0.10 .049±.004 A±0.20[.008] 2.10 .083 RECOMMENDED PCB LAYOUT TOLERANCE: 0.10[.004] 4.45±0.25 .175±.010 3.70±0.25 .146±.010 B±0.25[.010] C B C B 0.30±0.05 .012±.002 4.70±0.25 .185±.010 A NOTES: 1. INSULATOR MATERIAL: NYLON6T, UL94V-0, COLOR:BEIGE. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: TIN OVERALL. 4. CURRENT RATING: 1 AMP. 5. VOLTAGE RATING: 125V AC/DC. 6. INSULATOR RESISTANCE: 100 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 500V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. 10. MATES WITH SWH120 SERIES SINGLE ROW HOUSING. 8 7 6 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 7/30/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. A WAFER, 1.25mm CC, 1 ROW, SM SWR120-NPEG-S_ _-SM-BG SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11294 SCALE: 10:1 2 A SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2002, wafer 120 series\11294, SWR120-NPEG-S_ _-SM-BG PRINT: 9/23/2009
SWR120-NPEG-S15-SM-BG 价格&库存
很抱歉,暂时无法提供与“SWR120-NPEG-S15-SM-BG”相匹配的价格&库存,您可以联系我们找货
