SWR201-NREN-S03-RL-WH 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2003
INITIAL RELEASE
7/17/2009
JH
F
F
0.50 .020
E
E
VIEW FROM
FRONT
VIEW FROM
BOTTOM
D
D
2.00±0.10 .079±.004
A±0.10[.004]
6.25±0.20 .246±.008
A±0.20[.008]
2.00±0.05 .079±.002
5.00±0.25 .197±.010
1.80±0.20 .071±.008
+0.10
+.004
0.70
.028
0.00
- .000
B±0.25[.010]
RECOMMENDED PCB LAYOUT
C
C
6.10±0.25 .240±.010
7.70±0.25 .303±.010
B
B
CIRCUIT 1
3.40±0.20 .134±.008
A
NOTES:
1. INSULATOR MATERIAL: NYLON66, UL94V-0, COLOR:WHITE.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: TIN OVERALL.
4. CURRENT RATING: 2 AMPS.
5. VOLTAGE RATING: 100V AC/DC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 10 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING VOLTAGE: 800V AC.
9. OPERATING TEMPERATURE: -25° C TO +85° C.
10. MATES WITH SWH201 SERIES SINGLE ROW HOUSING.
8
7
6
0.80±0.20 .031±.008
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR: 5
.X= .3 [.01]
.XX= .15 [.006]
.XXX= .050 [.0020]
SURFACE FINISH: 63 Ra
DRAWN
5
4
9/03/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
A
SWR201-NREN-S_ _-RL-WH
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
NAME
WAFER, 2mm CC 1ROW, RL
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
DATE
REV
11300
SCALE: 10:1
2
A
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\JH TEMP\11300, SWR201-NREN-S_ _-RL-WH PRINT: 9/25/2009
SWR201-NREN-S03-RL-WH 价格&库存
很抱歉,暂时无法提供与“SWR201-NREN-S03-RL-WH”相匹配的价格&库存,您可以联系我们找货
